Removing Adhesives? - Painting & Finish Work - Contractor Talk
Removing Adhesives?
Old 05-07-2012, 01:04 PM   #1
Herminigilde's Avatar
Trade: Sustainable Builder/Remodel and Rehab
Rewards Points: 49
Removing Adhesives?
Today, I ripped out paneling from a basement to prep for paint. Most of it was glued to concrete block walls with spots of glue 2-5 inches across. Any suggestions for removing the spots of adhesive?
Tried Contractors Solvent, which was minimally effective. It will be days of scraping if I don't find something better, and although that means more income and muscles, I'm not to thrilled about the idea. Neither is the HO.
Thank you in advance.
Herminigilde is offline
Old 05-07-2012, 01:21 PM   #2
EcoBuilder's Avatar
Trade: Green Building and Remodeling
Rewards Points: 75
Re: Removing Adhesives?
Have you tried any citrus based adhesive solutions? I know those work really well on tape adhesives.
EcoBuilder is offline
Old 05-07-2012, 01:26 PM   #3
Rewards Points: 49
This is a citrus based solvent.
Any other suggestions?
Old 05-07-2012, 03:16 PM   #4
rondon's Avatar
Trade: carpenter
Rewards Points: 102
I have used a hest gun with a 2" wide puttty knive and it was rather effective.
rondon is offline
The Following User Says Thank You to rondon For This Useful Post:
Herminigilde (05-07-2012)
Old 05-08-2012, 05:31 PM   #5
Rewards Points: 49
A local contractor suggested (and loaned me his) oscillating tool with a rigid scraper blade. It worked well -- although I'm going to owe him a new scraper as the concrete is filing it down pretty fast.
The Following User Says Thank You to Herminigilde For This Useful Post:
We Fix Houses (05-08-2012)
Old 05-08-2012, 07:24 PM   #6
Pelican's Avatar
Trade: Painting/Wood finishing
Rewards Points: 81
I have seen caulk and adhesive remover before that you just squirt it on and it softens adhesives. Also you can look for a paint stripper that will melt it.
I don't make the rules, I just think them up and write them down.
Pelican is offline
Old 05-09-2012, 12:51 PM   #7
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Rewards Points: 7,510
Torch and putty knife?
ProWallGuy is offline
Old 05-09-2012, 12:54 PM   #8
SuperiorHIP's Avatar
Trade: Home Improvement Contractor
Rewards Points: 1,450
I second the heat gun and putty knife. Had some of those grip tape strips on some steps last year that would not budge. Tried the heat gun and 5 in 1 and it came off pretty easily.
SuperiorHIP is offline
high performance adhesives ?? parkers5150 Flooring 13 10-24-2010 11:24 AM
Blasting off two-component polyurethane adhesives iceblastservice Sandblasting 1 06-30-2010 11:32 PM
Removing concrete corner blocks!! Nail Ace Masonry 3 04-16-2010 09:53 PM
Removing studs from a load bearing wall. Russ25nys Framing 36 06-13-2009 08:52 PM
Experience with Adhesives Technology products? Dmax Consulting Masonry 1 01-01-2009 08:17 PM
