ReFinishing Exterior Fiberglass Door - Painting & Finish Work - Contractor Talk
Old 06-01-2010, 04:29 AM   #1
randybelk@comca's Avatar
Trade: CONTRACTOR
Rewards Points: 25
Hi folks,
I got a request from a good friend/customer who has an older stained fiberglass front door that is starting to show its age.
The finish is fading off and sort of flaking.
I would say it was installed some 20 years ago. Door structurally is still great condition. It is set back in front porch. Doesnt catch hardly any sun.
Has no storm door installed.
They asked me if I would be willing to refinish the door, and I told them I would give it a shot.
I have gel stained NEW fiberglass doors before, but I have never tried to refinish one.
Can someone give me some tips as to how to remove the old finish as Im sure you wouldnt want to take a sander to it. (not being wood). They would like it restained and then polyeurathne or similiar.
I have noticed some other fiberglass stained doors in this area starting to do this as well. Knowing the proper way to refinish them would be of a help.
Thanks in advance,
Randy Belk
Athens, TN
randybelk@comca is offline
Old 06-01-2010, 07:15 AM   #2
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 102
Re: ReFinishing Exterior Fiberglass Door
Never done one, but I would bet that either laquer thinner or a paint remover would disolve the old finish without harming the fiberglass. A nylon scrub brush would be helpful to get into the graining.
pinwheel is offline
Old 06-02-2010, 01:02 AM   #3
CarlW's Avatar
Rewards Points: 75
Yeah, I have always thought it strange that nobody maintains their fiberglass doors..and some of them are expensive. I would treat is like a strip job. Lacquer thinner is the first thing I would try and will work well if enough of the actual finish is worn away. We have painted the doors and then stained over the paint but this is a last resort...best to strip it down to raw fiberglass and then stain. If you have stained new doors, you may notice a difference when staining doors that have been stripped....the stain will not bite in the same way and it is usually more of a challenge to get the stain to look right.
CarlW is offline
Old 06-02-2010, 08:25 AM   #4
mobjack68's Avatar
Trade: plastering, interior trim, laborer
If solvent will work, I would try lacquer thinner first...acetone next, go the solvent route.
If solvent is not efficient, use chemical stripper.. IF the fiberglass is textured?? go slow, allow only enough time for the stripper to dissolve some gunk, wash to stop the chemical action and come back to that spot later.
Strippers contain Methylene Chloride or something chemically close. This chemical is strong enough to soften the fiberglass, so some loss of detail will happen. There will be a very short time differential between the stripper "almost" working and the stripper working "too well"
test a small patch before firing the big guns....
Too old to be this useful, Too useful to be this old
mobjack68 is offline
Old 06-04-2010, 06:56 PM   #5
C & T Paint's Avatar
Trade: paint
No need to strip the door prim it with bm 46000 acrylic primer tinted a wood tone color then us the minwax gel stain with a graining tool on top of that and then a clear exterior water base poly on top of that.
C & T Paint is offline
Old 06-04-2010, 08:17 PM   #6
Trade: CONTRACTOR
Rewards Points: 25
Thanks C&T.. That sounds good. I don't need to worry about the Poly on the exterior? Just use Bm primer?
The door has wood grain finish now so would I still need to use a wood graining tool?
I am going to give it a try.
Thanks again.
Randy
Old 04-09-2015, 09:21 PM   #7
Directd1's Avatar
Trade: Handy-Man
Rewards Points: 4
Use the citrus stripper, its strong enough, but not enough to burn the fiberglass. Also, try not to pull the factory base coat of primer off.
Directd1 is offline
Old 04-09-2015, 09:50 PM   #8
avenge's Avatar
Rewards Points: 130
Really? This topic is almost 5 yrs old I would think he's got the project done.WTF
avenge is offline
Old 04-10-2015, 12:45 AM   #9
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
Good thing he's a "Handy-Man"
Must be higher up than your standard issue "handyman"
Originally Posted by tipitop View Post
That guy in video have mental issues plus eat hole turtle from some reason
m1911 is offline
Refinishing an exterior door - finish suggestions wanted Haydin Painting & Finish Work 4 08-19-2008 09:41 AM
Door install hell - customer angry HellisLikeNewrk General Discussion 17 06-04-2008 09:40 AM
Common Patio Door Problems adriand Remodeling 1 01-14-2007 01:27 AM
refinishing mahogany door ChuckEA Painting & Finish Work 6 07-03-2006 09:50 AM
Door hanging Nick H Carpentry 4 02-27-2006 02:22 AM
