Quest For The Wire Brush - Painting & Finish Work - Contractor Talk
Old 06-10-2019, 07:26 PM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 1,030
Wire brushing my brushes, I've noticed how many quickly drop their metal bristles. That you have to chase down and try to pick up, or leave behind. And then there's the rust...
Who makes a brush that actually holds no-rust bristles?
artinall is offline
Old 06-10-2019, 07:46 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 2,448
Re: Quest For The Wire Brush
i think Purdy makes a ss cleaning brush.
griz is offline
The Following 2 Users Say Thank You to griz For This Useful Post:
artinall (06-10-2019), Idothat (06-10-2019)
Old 06-10-2019, 07:49 PM   #3
Idothat's Avatar
Trade: Home improvement of all types
Rewards Points: 1,220
I canít get the same wire brush two times in a row it seems like
I have had them with stainless steel bristles and, the plastic handled ones seem to not shed as bad
I Donít get a specific brand just whatever they have when I need one
Idothat is offline
The Following User Says Thank You to Idothat For This Useful Post:
Easy Gibson (06-17-2019)
Old 06-10-2019, 08:11 PM   #4
EricBrancard's Avatar
Trade: GC/Remodeling
Rewards Points: 986
I’ve been happy with this one.
https://www.woosterbrush.com/brushes...ers-comb-1832/
EricBrancard is offline
Old 06-11-2019, 07:39 PM   #5
Stelzer Painting Inc.
stelzerpainting's Avatar
Trade: 1721
Rewards Points: 544
I stopped using wire brushes to clean paint brushes a while ago. For years I'd look at the flared filaments on my paint brushes and wondered WTF? Until I started looking at what I was cleaning them with..every wire brush gets narled & bent and I'm dragging em through my nice brushes. Unless it's a brand new wire brush and you're careful to only brush in the direction of the filaments, you'll end up ratting out a brush after a while. I spent the first 20 years using wire brushes. Now it's nylon scrub brushes and wire combs. Brushes tend to hold up much better much longer.
Troy Stevens, Stelzer Painting Inc.
www.stelzerpainting.com
stelzerpainting is offline
Old 06-12-2019, 01:27 AM   #6
Caslon's Avatar
Trade: State Licensed Painting Contractor
Rewards Points: 1,366
The idea is to get whatever nearly dried paint accumulated at the ferrule of the brush gets loosened up during cleaning. What does it matter what accomplishes that? Old wire brush losing it? Buy a new one for next to nothing.
Caslon is offline
Old 06-17-2019, 01:19 PM   #7
Punching above his weight
Easy Gibson's Avatar
Trade: Gun for hire.
Rewards Points: 19,238
Originally Posted by EricBrancard View Post
This is the guy.
I think I'm only on my 4th or 5th one in 7 years. That's pretty good!
I just use it to get the the dry line that forms about halfway up the bristles if you let it sit for too long.
Also, it can be good for getting the edges of a roller cover that gets gumballs.
Easy Gibson is offline
The Following User Says Thank You to Easy Gibson For This Useful Post:
EricBrancard (06-18-2019)
Old 06-17-2019, 04:08 PM   #8
hdavis's Avatar
Rewards Points: 2,076
Plastic handled brushes seem to hold up the best.
Wire comb is my first step
hdavis is offline
Old 06-17-2019, 04:13 PM   #9
hdavis's Avatar
BTW, I'll usually buy a 3 pack of the small plastic handled brushes. One plastic, one brass, one stainless. Probably HD, but could be HF.
hdavis is offline
Old 06-17-2019, 08:10 PM   #10
I've only ever used that 3-pack for auto work. You can find virtually the same product at either HD or HF. They're also in the "hardware" section of dollar stores.
Actually, last time it was a 6-pack. 3 big, 3 little.
That tiny stainless jammy is one of my favorite tools. Still haven't really found a use for the plastic one.
hdavis (06-18-2019)
Old 06-17-2019, 08:58 PM   #11
Rewards Points: 986
Fingernails and teeth.
Old 06-18-2019, 01:49 PM   #12
Nothing better for asparagus than a plastic brush with a squirt of Fast Orange.
Old 06-19-2019, 07:12 PM   #13
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 2,976
I too find my slop sink with wire bristles laying in the bottom of it after cleaning brushes. My concern are the wires bristles getting down the drain and eventually clogging it.
The cheaper brushes with plastic handles seem to do better than the non rusting wire brushes, once they are bent out of shape just toss 'em.
In the summer months a wire brush is the only way to salvage a brush that has a build up of dried paint around the ferrule.
Ohio painter is offline
The Following User Says Thank You to Ohio painter For This Useful Post:
artinall (06-19-2019)
Old 06-19-2019, 08:53 PM   #14
artinall's Avatar
If you happen to be washing from a lawn spigot - there's bare foot potential.
Get what you're saying about the plastic although I recently got a plastic handled one that sheds and rusts. Its orange and an easy grip and that's about it.
I'll be trying the stainless purdy, as griz offered.
artinall is offline
Old 06-19-2019, 11:05 PM   #15
Caslon's Avatar
First sign of a cheap wire brush putting wire in your sink? Buy another one. $2.99. A wire brush is mainly to get off all the dried paint that has accumulated at the ferrule, before you use your hand and fingers to manually work out all the rest of the paint accumulated there. Using plastic gloves of course if cleaning out solvent paints.
A good trim brush worn in, taken care of, is a good thing. The bristles get just a little more stiff making it that much more precise when doing trim work.
Caslon is offline
The Following User Says Thank You to Caslon For This Useful Post:
Ohio painter (06-20-2019)
Old 06-20-2019, 12:57 PM   #16
artinall's Avatar
Originally Posted by Caslon View Post
First sign of a cheap wire brush putting wire in your sink? Buy another one. $2.99. ....
Which is why to get one that lasts and doesn't need replacing for a long while. No need to replace near as much...
Strongly agree. Have some several years old.
artinall is offline
The Following User Says Thank You to artinall For This Useful Post:
Old 08-27-2019, 05:25 AM   #17
skintscot's Avatar
Trade: Painter Decorator
Rewards Points: 76
Always go Purdy - best on the market IMO
skintscot is offline
Old 09-03-2019, 01:56 PM   #18
madmax718's Avatar
Trade: General
Rewards Points: 3,276
I bought what I thought was a brush cleaner. Turns out it was a comb for cats. Cleans brushes great!
madmax718 is offline
Old 09-05-2019, 06:57 PM   #19
Mordekyle's Avatar
Rewards Points: 6,090
Iíve used the comb used for inspection of cats and dogs for fleas.
Fine metal, close together, works well.
Mordekyle is offline
