Putting Splatter On Walls - Painting & Finish Work - Contractor Talk
Old 11-02-2010, 09:31 PM   #1
Cjeff's Avatar
Trade: Renovations
My daughter wants to put paint splatters on her wall.
My concern is painting over it after, will the bumps show through? I expect they will.
Is there a way to deal with this before we paint the splatters, or before the next paint job?
Cjeff is offline
Old 11-02-2010, 09:51 PM   #2
Paint Dribblz's Avatar
Rewards Points: 25
Re: Putting Splatter On Walls
Just say no.
Paint Dribblz is offline
Old 11-02-2010, 11:41 PM   #3
A. Spruce's Avatar
Trade: General Contractor - ret.
If the wall has a decent texture to it already, the paint spatter isn't going to show up that much. You can also squirt new texture over the wall prior to repainting later if you're that concerned.
A. Spruce is offline
Old 11-03-2010, 07:10 AM   #4
NAV's Avatar
Trade: commercial building restoration
Rewards Points: 250
If you thin the paint down a lot the texture will be minimized.
NAV is offline
Old 11-03-2010, 07:06 PM   #5
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 8,485
Ding, ding, ding!!
-Paul
TextureMaster.com
Checkout my YouTube Channel with 90,000 Subscribers and over 13,000,000 views
My Latest Video: https://youtu.be/E23Y-fw4KCM
YouTube Channel: https://www.youtube.com/paulpeck
Twitter Facebook Instagram YouTube
Sir Mixalot is offline
Old 11-03-2010, 09:11 PM   #6
Sure, I can do that...
jlhaslip's Avatar
Trade: carpentry/renovations
Rewards Points: 196
How do you put on the second coat???
jlhaslip is offline
Old 11-03-2010, 11:12 PM   #7
Cjeff's Avatar
Trade: Renovations
Thin it down, excellent!!!!!!!!!!!!!!! Thanks
I was thinking a printable wallpaper, then you could just strip it off
Cjeff is offline
Old 11-04-2010, 12:12 AM   #8
jlhaslip's Avatar
Rewards Points: 196
At a commercial job I worked on once, the painter has a special paint that provided the 'splatter' effect. I think it was Latex paint with some gobs of oil based in it. As it came out of the sprayer, it separated and the splatter was created.
jlhaslip is offline
Old 11-04-2010, 07:36 AM   #9
NAV's Avatar
Rewards Points: 250
I believe you are referring to Multispec or Zolotone. The products are easy to apply if you have done it before but the affect is more like granite.
There are other options if you have a hopper sprayer - Tex-cote, UltraTex - by the name you know that they are texture coatings but the finish is highly washable and durable. They are used in hotels and offices.
NAV is offline
Old 11-04-2010, 02:34 PM   #10
Gough's Avatar
Trade: painting
My first painting job was with a guy who was also a theatre arts professor, and we also build a lot of theatrical sets together. His method for spattering was to thin the paint, use a fairly stiff brush, and a thick dowel (or chunk of broomstick). He'd shake off a fair bit of the paint over the work pot, then swing the brush against the dowel held in his other hand.
By the time she left for college, I had helped my daughter repaint her room so many times that it was noticably smaller :-)
Gough is offline
Bathroom Walls weeping... HELP hbl164 Painting & Finish Work 19 09-08-2016 11:40 AM
removing LARGE corner of basement walls and first floor. ApgarNJ Framing 59 06-04-2010 09:13 AM
Vapor Barrier with concrete block walls? pzeiler Insulation 0 04-21-2010 11:40 PM
smoke walls naptown CR Commercial Construction 18 09-11-2009 05:29 PM
Sanding Walls with 80 Grit Paper on Orbital Questions plazaman Painting & Finish Work 5 12-19-2008 04:01 PM
