Priming Over Oil - Painting & Finish Work - Contractor Talk
Priming Over Oil
Old 07-10-2015, 11:02 AM   #1
Pbpaints's Avatar
Trade: painter
Rewards Points: 172
Priming Over Oil
Can anyone recommend a water based primer that will bite to semigloss. Yes we will sand first but it is a residential building and i do not want to risk 1 the fumes and 2 someone rubbing against it.
Thanks
Pbpaints is offline
Old 07-10-2015, 11:09 AM   #2
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 16,775
Re: Priming Over Oil
Thanks
Not your question, but have you tried paints that bond to oil directly? I'm using Interlok by McCormick Paints. A regional brand and it's super stuff. Just have to clean the surfaces. Great for doors, too.
MarkJames is online now
Old 07-10-2015, 11:49 AM   #3
hdavis's Avatar
Rewards Points: 1,556
Glidden Gripper works.
hdavis is offline
The Following 3 Users Say Thank You to hdavis For This Useful Post:
Metro M & L (07-10-2015), Quality_PTG (07-13-2015), tedanderson (07-12-2015)
Old 07-10-2015, 12:59 PM   #4
Pbpaints's Avatar
Trade: painter
Rewards Points: 172
Even better if i can skip a step i would love that. I will look them up thanks
Pbpaints is offline
Old 07-10-2015, 01:00 PM   #5
Pbpaints's Avatar
Trade: painter
Rewards Points: 172
Oh yeah Glidden? Interesting i usually look down on there products.
Pbpaints is offline
Old 07-10-2015, 02:52 PM   #6
Particulate Filter
Metro M & L's Avatar
Trade: Flooring
Rewards Points: 1,468
As long as you sanded first, sherwin bomding primer would also work well. People have been super impressed by the gripper product since I started on the board six years ago.
Metro M & L is offline
Old 07-10-2015, 05:03 PM   #7
Renaissance Man
superseal's Avatar
Rewards Points: 5,838
zinsser 123...bonds to glass, formica, tile and all types of glossy surfaces.
supersealconstruction.com
superseal is offline
Old 07-10-2015, 05:28 PM   #8
EricBrancard's Avatar
Trade: Builder/Renovator
Rewards Points: 598
Insl-x Stix.
EricBrancard is offline
The Following 2 Users Say Thank You to EricBrancard For This Useful Post:
Danahy (07-13-2015), Pbpaints (07-10-2015)
Old 07-10-2015, 06:56 PM   #9
Pbpaints's Avatar
Trade: painter
Rewards Points: 172
All great info thanks, yes the insl-x is a product i have used in the past and always forget about it, thankyou
Pbpaints is offline
Old 07-10-2015, 09:07 PM   #10
kingcarpenter's Avatar
Trade: G.C./carpenter
Rewards Points: 544
Glidden gripper. Like you I used to shun their products until an old painter buddy of mine turned me on to the gripper. Used to paint apartments years ago to fill in and the pm bought nothing but Glidden. Lot of rerolling walls back then but they have improved a bunch. As Ive stated before you cant pull gripper off with a front end loader. As always prep is key. Will stick to plastic galv you name it. Good stuff in a lot of apps.
kingcarpenter is offline
The Following User Says Thank You to kingcarpenter For This Useful Post:
Old 07-10-2015, 11:05 PM   #11
aptpupil's Avatar
Rewards Points: 1,894
Gripper has been my go to for a while. Doesn't cover stains well, though.
aptpupil is offline
Old 07-12-2015, 03:03 PM   #12
The Ultimate Wire Hider
tedanderson's Avatar
Trade: A/V & Home Theater Installation
Rewards Points: 2,116
I've been a fan of the Gripper ever since someone turned me on to it. But from what I've experienced, any quality oil based primer will take either paint as long as you scrape off anything that is loose or peeling.
I'm always looking for the answer to my troubles at the bottom of a paint can.
tedanderson is offline
Old 07-12-2015, 04:36 PM   #13
Pbpaints's Avatar
Trade: painter
Rewards Points: 172
I am sorry i am priming over semigloss oil. I just read my question and left out that very important drtail. Is glidden gripper stil the go to product? Or should i just go with the insl-x?
Pbpaints is offline
Old 07-12-2015, 05:55 PM   #14
avenge's Avatar
Rewards Points: 112
The only way I go over oil base if the topcoat is going to be water base is I prime it with oil base. If you choose water base you have to dull the gloss.
avenge is offline
Old 07-12-2015, 06:23 PM   #15
aptpupil's Avatar
He said he would sand first. Fwiw i would sand then use Gripper.
aptpupil is offline
Old 07-12-2015, 07:23 PM   #16
hdavis's Avatar
That's what I do. Same thing going over old urethane. In old buildings, however, I'm stuck just cleaning it first so I don't trigger RRP.
hdavis is offline
Old 07-12-2015, 08:23 PM   #17
Pbpaints's Avatar
Trade: painter
Rewards Points: 172
Okay as i read everones input its got me thinking; what about just rubbing on a degreaser? Do you guys think i can go over the old oil semi gloss with just the degreaser and then paint with latex or degreaser to eliminate sanding then prime. Ultimately i know choice 2 is the best but in the interest of saving time i am just wondering if the degreaser by itself would work.
Pbpaints is offline
Old 07-12-2015, 08:55 PM   #18
avenge's Avatar
Rewards Points: 112
Degreaser won't work, they sell liquid de-glossers but they aren't always effective. You're looking for adhesion, to get that you want to dull the gloss. Water base primers that claim to stick to glossy surfaces will stick but only to an extent.
There's no way to properly do it without dulling if you're going to use a water base product regardless of what it is. The other question is how old is the oil base? It may contain lead.
avenge is offline
Old 07-12-2015, 10:47 PM   #19
Pbpaints's Avatar
Trade: painter
Rewards Points: 172
Thankyou for that, no i dought it contains lead it was definetly painted within the last 4 or 5 years.
Pbpaints is offline
Old 07-12-2015, 10:48 PM   #20
Pbpaints's Avatar
Trade: painter
Rewards Points: 172
I think i am just going to go with a light sanding with 150 grit. Prime with the behr gripper and 2 coats latex ben semigloss.
Pbpaints is offline
Miters and priming question Fishhook Windows, Siding and Doors 3 06-12-2013 09:10 PM
latex over oil no priming? zorikos Painting & Finish Work 24 01-03-2013 06:11 PM
Priming with textured ceilings iraachsen Painting & Finish Work 9 02-24-2012 03:01 PM
Priming MDF edges mpt1123 Painting & Finish Work 5 09-21-2008 07:08 PM
Self Priming Traps? mellison1 Plumbing 13 08-12-2008 10:47 PM
