Primer On Fiberglass Doors - Painting & Finish Work - Contractor Talk
Old 04-02-2016, 04:57 PM   #1
FrankSmith's Avatar
Rewards Points: 5,124
Does anyone know what the primer that comes on fiberglass doors is. Google is being no help. Thanks.
FrankSmith is offline
Old 04-02-2016, 06:07 PM   #2
avenge's Avatar
Rewards Points: 322
Re: Primer On Fiberglass Doors
You probably need to ask the manufacturer. But what difference does it make?
avenge is online now
Old 04-02-2016, 07:07 PM   #3
FrankSmith's Avatar
Because I want some. It receives stain very well for not being wood.
Old 04-03-2016, 09:15 AM   #4
SuperiorHIP's Avatar
Trade: Home Improvement Contractor
Rewards Points: 1,450
It could have a lot to do with the texture of the door material. When we prime raw fiberglass (columns) we use stix from insulx.
SuperiorHIP is offline
The Following User Says Thank You to SuperiorHIP For This Useful Post:
FrankSmith (04-03-2016)
Old 04-03-2016, 09:46 AM   #5
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 3,020
Curious, are you only needing to know what is on it so you can paint over it or are you thinking of re-priming it?
Ohio painter is online now
Old 04-03-2016, 10:51 AM   #6
FrankSmith's Avatar
I have a wood textured steal garage door on a project. It was ordered in a wood grain finish. From the street it just looks brown which isn't to good a look for the house. It either needs to get re stained or painted. My intention is to test some material for staining, give it a shot on the door. If it looks great awesome. If not, nothing is lost and it gets painted.
Old 04-03-2016, 02:52 PM   #7
I would have no idea of what could be used as a stain over steel.
Could one of those wood graining tools be used to recreate the wood grain look?
Old 04-03-2016, 06:39 PM   #8
FrankSmith's Avatar
The door has grain to it. Not the same as a fiberglass door but not that terribly different. Gel stain works on fiberglass doors and looks great. My opinion is if I use the same primer it will work very similarly.
Old 04-04-2016, 08:31 PM   #9
Its been a while but last set I did we primed with zinnser oil (tan and white can) and I had it tinted to a slight yellow color (wish I could tell you what color). It worked really well, the yellowish base color helped with whatever in the world I was trying to achieve.
Old 07-06-2020, 04:52 AM   #10
baritt's Avatar
Trade: Doors and Windows Manufacture
Rewards Points: 4
Hi guys, this is my experience with fiberglass painting and staining. I work for a fiberglass door manufacturer name Nova Doors and we use a water based product called TruCoat for painting and staining our fiberglass doors. It is made specifically for fiberglass doors so it doesn’t require any special primers, is super durable and lays down really smoothly. You can check more about them on Trucoat.us
baritt is offline
Installing grab bars in fiberglass tub shelf guy Kitchens & Baths 26 09-22-2015 01:42 AM
Fiberglass Pickup Caps RonMiller Contractor Swap 0 01-29-2013 01:46 PM
Mortar in Fireplace doors 6stringmason Masonry 8 07-12-2012 08:23 PM
Large Mirrored Doors Jschills Finish Carpentry 5 07-10-2012 06:11 PM
