Primer Failing Adhesion/tape/fingernail Test(?) - Painting & Finish Work - Contractor Talk
Old 12-24-2016, 05:11 PM   #1
Banger of Nails
Dullers's Avatar
Rewards Points: 66
Hi All,
Renovation carpenter/general with decent paint experience here. I normally hire my regular paint crew to do anything more than a little trim or a single room.
I think I'm struggling with primer adhesion. Can anyone weigh in and give me peace-of-mind that my paint will stick?
Surface: Vinyl "wallpaper" thoroughly glued to luan plywood wallboard
Primer: Zinsser CoverStain, oil
Paint: SW SuperPaint
Surface: Cabinets, various. Veneer, manufactured wood, etc.
Primer: SW Extreme Bond, latex
Paint: SW ProClassic
The cabinets are more concerning than the walls, but I'm curious on your input with both. I just did the tape/fingernail test today and it's been 48 hours since application. Temps are decent in the 50's/60's during the day.
The oil on walls still feels soft-ish, but doesn't seem to be flaking off. "Failed" the tape test. Does scrape off with a fingernail pressed hard enough. Didn't sand walls. Did clean with Simple Green.
The latex on cabinets bunched/streaked in one spot where I think I missed with my scuff-sand, medium grit sponges. Cleaned with Simple Green.
Not looking for the highest end finish (otherwise my paint crew would be stripping, spraying, etc).
Just looking for it to not flake & peel off in 6-12 months
Thx guys!
Cabinet Pics:
Wall Pics:
Cabinet Scratch Test
Cabinet Tape Test
Wall Scratch & Tape Test
Dullers is offline
Old 12-24-2016, 05:27 PM   #2
Gumshoe's Avatar
Trade: Painter
Rewards Points: 128
Re: Primer Failing Adhesion/tape/fingernail Test(?)
I like to avoid cleaners before priming. Even the no rinse cleaners like Soilax scare me. Any, and I mean any residue can be problematic. Sanding and removing the dust with plain warm water is what I normally do. Your primer selection is spot on. Topcoats as well. I will say that today's paint formulas really take some time to harden up to pass the fingernail test or the tape test. I've had coatings in the past fail for a week or so before the paint finally hardened up and cured enough to be acceptable. Just a few thoughts.......
Gumshoe is offline
The Following 2 Users Say Thank You to Gumshoe For This Useful Post:
Dullers (12-24-2016), PRP (12-24-2016)
Old 12-24-2016, 05:34 PM   #3
Banger of Nails
Dullers's Avatar
Rewards Points: 66
First post... did you register just now to respond? Thanks!! That's reassuring - I appreciate the input. Noted on the cleaner. A good water-and-rag wipedown would probably be fine, unless there's grime in the kitchen/bath.
Happy holidays!
Dullers is offline
Old 12-24-2016, 05:46 PM   #4
PRP's Avatar
Trade: Painting Contractor
Rewards Points: 132
Give it more time. Full cure time for oil is around 3 weeks and acrylics take 4 weeks. You mention daytime temps, is this place getting cold at night?
PRP is offline
The Following User Says Thank You to PRP For This Useful Post:
Old 12-24-2016, 05:50 PM   #5
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 2,470
For me Cover Stain OB has always exceeded expectations. I'd let it dry into the 3 rd day, see if it hardens up.
Just re-read. Simple Green can cause all sorts of problems. Hard to think 30:1 would do any serious cleaning ? So we put in more...right ? 1 oz to 30 oz is a good start. Must rinse with water ! Completely.
That 3 rd pic is contamination or grease ?
Any future spot or re-prime use BIN shellac based.
We Fix Houses is offline
The Following User Says Thank You to We Fix Houses For This Useful Post:
Old 12-24-2016, 06:49 PM   #6
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 2,958
I think you are spot on with your primers and finish paint. I would say give it more time to cure. As far a prep you can't go wrong with it getting it clean dry and dull.
Ohio painter is offline
The Following 2 Users Say Thank You to Ohio painter For This Useful Post:
Dullers (12-25-2016), VinylHanger (12-24-2016)
Old 12-24-2016, 07:44 PM   #7
VinylHanger's Avatar
Rewards Points: 12,940
Single Green leaves a residue, doesn't it? I use no-rinse TSP substitute and wipe it down and get the extra off.
VinylHanger is offline
The Following User Says Thank You to VinylHanger For This Useful Post:
Old 12-24-2016, 09:22 PM   #8
Gumshoe's Avatar
Trade: Painter
Rewards Points: 128
Happy holidays!
I'm an old-timer over on the DIY and Painttalk forums. Entering my 39th year in the painting biz.
Gumshoe is offline
Dullers (12-25-2016), hdavis (12-24-2016)
Old 12-25-2016, 01:12 AM   #9
Caslon's Avatar
Trade: State Licensed Painting Contractor
Rewards Points: 1,366
Hi All,
Wall areas don't get the wear and tear trim does. I would have saved myself some brain cells and used Zinsser's water based Bullseye 123, which would have adhered better than Cover Stain, which is used for exterior wood. As for the cabinets, if they have a lacquer type finish on them, that primer should stick ok. Just touch up nicks that will happen. For maximum hardness and adhesion, I would have used an oil based specialty primer such as XIM or a pigmented shellac.
Give the Cover Stain time to harden. It may still fail the tape test, but walls aren't subject to nicks as much as trim.
Caslon is offline
The Following User Says Thank You to Caslon For This Useful Post:
Old 12-25-2016, 10:39 AM   #10
Philament's Avatar
Trade: Whatever the customer wants
Rewards Points: 2,236
I have no idea, but I'm giving two thumbs up for most detailed description of a problem.
Philament is offline
The Following User Says Thank You to Philament For This Useful Post:
Old 12-25-2016, 10:51 AM   #11
avenge's Avatar
Rewards Points: 298
With temps in the 50's and 60's it's going to take longer to cure, paint can take weeks to cure. I think you're fine with the chosen primers when prepped properly but I would have chosen something other than Simple Green.
avenge is offline
The Following User Says Thank You to avenge For This Useful Post:
Old 12-25-2016, 11:36 AM   #12
Banger of Nails
Dullers's Avatar
Rewards Points: 66
Thanks for all the responses! I appreciate you all taking time out of your holiday to weigh in.
Sounds like the general consensus is Simple Green was a poor choice and I'm expecting too much adhesion within only a few days, especially with the lower outside temps we have right now.
Given all your input, I feel pretty confident moving forward with how it's behaving so far and some minor adjustments. Thanks again and Merry Christmas!
Dullers is offline
Old 12-25-2016, 11:50 AM   #13
Banger of Nails
Dullers's Avatar
Rewards Points: 66
Gotcha. Thx! It is getting cold at night yes. 30's & 40's at night. 50's & 60's in the day. I'm in Central Coastal California right now. Palo Alto area.
Switching to water for sure. I think that streaking in the 3rd pic is from either the Simple Green residue, or I just missed scuffing/dulling that area with my sanding.
Right on! 39 years, wow. Thanks for your input
I used the oil based on the walls because I was worried about water based or other products loosening up the vinyl "wallpaper" glue. It's not common, but I've seen it happen. Particularly with topcoats/paints.
It does STINK though. Yikes.
Thanks for the advice. I'm not too far in at this point that I couldn't change products. I honestly haven't used SW Extreme Bond before. My SW rep recommended it. He said a lot of guys have been using it lately and had good success. I considered using the CoverStain on the cabinets too, since I've already got the oil going.
I would have to eat one can as I've already opened it.
Edit: I read over on PaintTalk.com forums a theory that SW's Extreme Bond is basically a ripoff/takeoff of 123 primer. Not sure what merit it has, but I wouldn't be surprised. 123 is my go to one-size-fits all primer.
Dullers is offline
Old 12-26-2016, 06:43 PM   #14
PNW Painter's Avatar
Trade: Painter
Rewards Points: 70
I've never had Adhesion issues with CoverStain and I've yet to use SW Extreme Bond. I'm guessing that the simple green is the likely issue, but the low temps will extend the cure time as well. Try running some fans.
I've also had great luck using Krud Kutter Deglosser to clean cabinets before they're sanded. For the final wiped own I just use a little bit of water.
PNW Painter is offline
The Following User Says Thank You to PNW Painter For This Useful Post:
Dullers (12-26-2016)
Old 12-26-2016, 08:59 PM   #15
Banger of Nails
Dullers's Avatar
Rewards Points: 66
I've gotta get on the Krud Kutter train. I see a lot of guys with it.
I need a couple sundries tmrw anyways. I'll grab a spray bottle and give it a go.
The deglosser can't hurt with my cabinet refinish!
Cheers
Dullers is offline
Old 12-27-2016, 04:07 PM   #16
sparehair's Avatar
Trade: Painting, flooring
Rewards Points: 1,482
Dry times double every ten degress below seventy. So if your at 50 at night, dry time to powder on the oil would be four days.
Sent from my SM-N910T using Tapatalk
sparehair is offline
The Following User Says Thank You to sparehair For This Useful Post:
Dullers (12-27-2016)
Old 12-27-2016, 04:47 PM   #17
Banger of Nails
Dullers's Avatar
Rewards Points: 66
That's a great rule of thumb
I like it, Thanks!
Dullers is offline
Old 12-27-2016, 07:50 PM   #18
avenge's Avatar
Rewards Points: 298
I like it, Thanks!
Don't know if that helps you any, your issue is cure time not dry time. Besides the only oil you used was Cover Stain that doesn't take 8 hours to dry, it takes 7 days for full adhesion/cure at 70 to 80 degrees.
avenge is offline
Carpenter Test BuiltByMAC Decks & Fencing 98 05-15-2017 07:14 AM
Primer for poplar builtins PBanks Painting & Finish Work 4 09-09-2016 11:50 AM
high build primer? 18delta Specialty Coatings 7 05-31-2016 07:40 PM
SW Multi-Purpose Primer instock Painting & Finish Work 5 11-12-2015 12:04 PM
New Primer was really bad! JenniferTemple Painting & Finish Work 14 11-02-2011 07:05 PM
