Pressurewashers - Painting & Finish Work - Contractor Talk
Pressurewashers
Old 03-27-2007, 09:22 PM   #1
bgpainter's Avatar
Pressurewashers
Hey guys,
I was wondering what do you think about Dewalt's Heavy-Duty 3750 PSI Gas Pressure Washer - DP3750 compared to CBA 3003 OMHP (M-I-T-M is the manifacturer)
The dewalt is about $1,000 and the CBA is about 1200. I used the dewalt before and like dit a lot but the CBA offers me better service coverage--it's through my local Sherwin Williams dealer. the dewalt is more powerfull--4gpm vs. 3 gmp (pressure is 3750 psi vs. 3000psi; 13hp vs. 9hp too--both Honda engines). I need it for cedar shingles powerwashing
Thanks for any input
bgpainter is offline
Old 03-27-2007, 10:17 PM   #2
bigchaz's Avatar
Trade: Wood Restoration/Refinishing
Rewards Points: 150
Re: Pressurewashers
The pressure isn't very important, as you will be turning it way down for wood
You'll be glad to go with a higher GPM. Will make your rinsing much quicker especially over a large surface such as shingles
bigchaz is offline
Old 03-27-2007, 11:00 PM   #3
Pro Painter
AAPaint's Avatar
Trade: Painting Contractor
Rewards Points: 1,000
Re: Pressurewashers
More GPM for sure. Other things to consider is will you be using a water spicket, or do you plan on pumping from a tank at times? You'll need a belt drive if it's the latter. Which brings an important point. Belt drive is always betta'.....are these belt or direct drive units? What type of pump does each have? The Mi-T-M machines are good units. I have one, it's a 13hp honda w/ 4gpm AR pump....good rig.
Pressure is the last thing to worry about.
Weathered Wood Restoration LLC
Deck Staining & Restoration Jacksonville, FL
Pressure Washing Jacksonville, FL
AAPaint is offline
Old 03-28-2007, 06:23 AM   #4
bgpainter's Avatar
Re: Pressurewashers
I thought along the exact same lines...thanks for the input
no idea on the pums...just wondering if the difference from 3 gpm to 4 gpm will be really noticeable?
it's a water spicket so I'll stay with the direct dirve (I am washing only a few houses a year)
Old 03-28-2007, 09:35 AM   #5
Deck Cleaner
PressurePros's Avatar
Trade: Deck Cleaning, Staining, Restoration
Re: Pressurewashers
very noticeable.
Ken Fenner
Pressure Washing PA
Roof Cleaning Services PA
PressurePros is offline
Old 03-28-2007, 01:02 PM   #6
Pro Painter
AAPaint's Avatar
Re: Pressurewashers
Pay attention to the pumps. Just because it has a honda motor doesn't mean it won't have a crap pump. I doubt that's the case if you go with the Mi-T-M machine. They come (usually) with AR or General pumps.
AAPaint is offline
Old 03-28-2007, 09:19 PM   #7
Professional Painter
Richard's Avatar
Trade: Owner/Operator
Re: Pressurewashers
Originally Posted by bgpainter View Post
Hey guys,
They're yellow
All joking aside, Dewalt is a good brand, a buddy of mine just picked up a 3000psi and it's so light, like 90lbs! He said it is a great machine all around...you wont be disappointed.
Richard is offline
