Post-a-Quote - Page 9 - Painting & Finish Work - Contractor Talk
Post-a-Quote
Old 02-11-2014, 08:18 PM   #161
THINKPAINTING's Avatar
Re: Post-a-Quote
Originally Posted by donb1959
Peeling paint to be removed by wet scrapeing
Home to be pressure washed using low pressure
Ground area to be protected using poly
Poly to be bagged and removed from site each day according to RRP rule
Loose window glazing to be removed, and replaced with new glaze
Any areas of soft wood to be repaired using "Rock hard" epoxy wood putty
90% of home will require priming before topcoat
Contractor will attempt to tighten bead board ceiling on front porch
Bead board ceiling will be caulked
All areas requireing caulking will be caulked
Cement foundation / columns /front porch floor to be painted
Front retaining wall to be painted
Driveway retaining wall not included in quote
Stained front door to be sanded/restained, and 1 coat poly
wrought iron gate to be painted
Porch floor in rear to be painted
Primer used to be Sherwin Williams Exterior oil base primer
Top coat used to be Sherwin Williams "Super Paint" flat sheen on siding
Top coat used to be Sherwin Williams "Super Paint" gloss sheen on trim
Paint used on all masonary to be "Loxon" masonary paint
Paint used on wrought iron to be all purpose enamel
Home to receive 1 primer coat
Home to receive 2 top coats
PLEASE NOTE: Shutters are in bad shape, they will be painted, but prep work will be at a minimum so as not to disturb shutters a great deal.
Materials: 18 gals siding paint
10 gals oil primer
5 gals trim paint
3 gals ceiling paint
4 gals masonary paint
2 cases caulking
1 qt wood putty
2 rolls plastic sheating
Material Cost: $2,290.00
Labor: $11,350
TOTAL PRICE: $ 13,640
Approximate START DATE: June 28
Approximate JOB DURATION: Approx-3men, 24 days
Wow my labor for a 3 man crew for 28 days minimum would be $28,800.
www.thinkpainting.net
THINKPAINTING is offline
Old 02-11-2014, 08:24 PM   #162
BamBamm5144's Avatar
Trade: Everything Exterior, Mostly Roofing.
Rewards Points: 2,786
Re: Post-a-Quote
Wow that's cheap. I would never want to be a painter.
$472 a day to be split among three people? So like $160 a day before taxes. What are you paying guys. How do you make any profit?
BamBamm5144 is offline
Old 02-12-2014, 09:29 PM   #163
"Buy Quality, Cry Once"
donb1959's Avatar
Trade: Paint Contractor www.brabhams.net
Re: Post-a-Quote
Your employees make 9300.00 a month?
www.brabhams.net
donb1959 is offline
Old 02-13-2014, 01:00 AM   #164
Particulate Filter
Metro M & L's Avatar
Trade: Flooring
Rewards Points: 1,484
Re: Post-a-Quote
Looks like hes billing labor at 42 an hour. Very reasonable. 15 an hour plus 30% in taxes and workers comp. Add in some benefits like a vaction and maybe a bare bones health plan and your labor cost is at 25 pretty quickly and then overhead another five an hour. So he might be making 25% on his labor.
Metro M & L is offline
Old 02-14-2014, 12:53 AM   #165
donb1959's Avatar
Re: Post-a-Quote
Yes, byt what he said was
So thats him paying his employees $9333.00 monthly
www.brabhams.net
donb1959 is offline
Old 02-14-2014, 05:00 PM   #166
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 452
Re: Post-a-Quote
Working someone 28 days a month would require overtime. For a typical 5 day week, 28 days is about 6 weeks.
Warren is offline
Old 02-15-2014, 09:13 PM   #167
Re: Post-a-Quote
3 men for a day is a 24 hr day yes? So what ever your hourly rate is per hour per man per man day times the number of days. If I'm billing out at say $47 dollars an hour per man hr per 8 hrs per man day is $376 x 3 = $1,128 x 28 days-- the original post I replied to said 3 men at 28 days which would be $31,584. I replied with my minimum. Number which is related to my break even costs.
Old 03-14-2014, 09:46 PM   #168
Nail Driving Fool
Robinson1's Avatar
Rewards Points: 1,333
Re: Post-a-Quote
1700 sq foot church.
Block exterior, 2 exterior doors, 14 windows.
Paint all exterior surfaces including steeple on 12/12 pitch roof, soffits, all trim work.
Bid $2800
Lost bid, too high.
Robinson1 is offline
Old 03-14-2014, 10:05 PM   #169
Particulate Filter
Trade: Flooring
Re: Post-a-Quote
Bid $2800
Lost bid, too high.
god couldnt afford it.
Old 03-14-2014, 10:08 PM   #170
Particulate Filter
Trade: Flooring
Re: Post-a-Quote
Bid $2800
Lost bid, too high.
" I was like hey, Llama you stiffed me on the tip. He said Gunga Gunga Galunga. When you die on your death bed you will receive eternal consciousness. So I got that going for me."
Old 03-15-2014, 05:43 PM   #171
Nail Driving Fool
Robinson1's Avatar
Re: Post-a-Quote
So you think that is too high?
Old 03-15-2014, 08:14 PM   #172
Particulate Filter
Trade: Flooring
Re: Post-a-Quote
No I think itz chump change to put your life at risk working for people who, in general, make their living by using god to get money from their congregation. My local super church just had a carwash and raffle to buy the pastor a new cadillac. Give me fricking break.
Old 03-15-2014, 08:28 PM   #173
Nail Driving Fool
Robinson1's Avatar
Re: Post-a-Quote
I know where you are coming from but its not that bad here. Mostly small country churches with less than 100 members.
But yeah, I just knew I was going to get that job. Some idiot bid it for $1000 and provided paint.
