Poll: Edgework Or Roll First? - Painting & Finish Work - Contractor Talk
View Poll Results: What's your take?
Brush first 36 83.72%
Roll first 2 4.65%
Doesn't matter 4 9.30%
I spray all my walls, so ha! 1 2.33%
Voters: 43. You may not vote on this poll
Old 12-14-2010, 07:14 PM   #1
Remodelor's Avatar
Trade: Bath Remodeling
Rewards Points: 250
So long story short, my boss and I were debating whether or not it's okay to roll paint before cutting in. I said it makes no difference and claimed that you can roll first and then do your edgework. He says that some people claim that it's better to do your brushwork first and that I had to. I want to hear what you guys think.
Is either better or is it all the same?
By the way, "This is how it's been done for years" is not a reason
Remodelor is offline
Old 12-14-2010, 07:31 PM   #2
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 946
Re: Poll: Edgework Or Roll First?
I've done both, but He Who Signs the Checks is always right.
Tinstaafl is offline
The Following 3 Users Say Thank You to Tinstaafl For This Useful Post:
Framer53 (12-15-2010), Gough (12-14-2010), Remodelor (12-14-2010)
Old 12-14-2010, 07:39 PM   #3
Gough's Avatar
Trade: painting
Brush first, that's how I've done it for years. Seriously, I've always felt that it's better to brush, then roll, in order to leave stipple on as much of the wall as possible. While this may not have much of an impact with flat paints, I think it becomes more important with products with higher sheen.
We also make it a point to coordinate cutting with rolling, so we maintain a wet edge.
Gough is offline
The Following 6 Users Say Thank You to Gough For This Useful Post:
A. Spruce (12-14-2010), boman47k (12-14-2010), katoman (12-14-2010), Remodelor (12-14-2010), Sir Mixalot (12-14-2010), tcleve4911 (12-14-2010)
Old 12-14-2010, 07:52 PM   #4
Remodelor's Avatar
Rewards Points: 250
That's an interesting point about the stipple. I usually use BM paints and high quality rollers that level out so much you can't tell, however on this job we're using Behr which has no leveling quality whatsoever Still, it is a flat, grey paint that's going on ceilings in this instance.
Old 12-14-2010, 08:06 PM   #5
Trailer park boy
shanekw1's Avatar
Rewards Points: 371
For me the final coat is always cut in first, then rolled into a wet edge, for the reasons Gough pointed out.
"Industry without art is brutality"
shanekw1 is offline
Old 12-14-2010, 08:08 PM   #6
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 8,477
Yep! This what we do to tee. Although I'd rather just spray it.
-Paul
TextureMaster.com
Checkout my YouTube Channel with 90,000 Subscribers and over 13,000,000 views
My Latest Video: https://youtu.be/E23Y-fw4KCM
YouTube Channel: https://www.youtube.com/paulpeck
Twitter Facebook Instagram YouTube
Sir Mixalot is offline
The Following User Says Thank You to Sir Mixalot For This Useful Post:
TheBuildingFirm (12-14-2010)
Old 12-14-2010, 08:57 PM   #7
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 9,285
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
Old 12-14-2010, 09:40 PM   #8
ltd's Avatar
Trade: painting
cut then roll depending on wall if its smooth plaster or dry wall i cut about 6 feet then roll.texture walls i can go farther with out any hatbanding. also your not standing on a step ladder cutting next to freshly painted walls where you could bump into them.i watch those home shows where they roll first then cut and i think yea right.
ltd is offline
Old 12-14-2010, 09:43 PM   #9
David Festa
festerized's Avatar
Trade: Framing Contractor
Rewards Points: 2,030
I vote nun (none) of them.
Cut in
Spray
Back roll
Trim pre-painted before install
Caulk
touch up
Have a nice day
festerized is offline
Old 12-14-2010, 10:39 PM   #10
Gough's Avatar
Trade: painting
Cut in
Spray
Back roll
Caulk
touch up
Have a nice day
Really?
Spray ceilings (2X): spray walls (first finish coat only); pre-prime, sand, and apply one finish coat to trim before installation; install trim, fill, sand, and caulk; apply two coats of finish to trim; wait for all other trades to finish; apply finish coat (brush/roller) to walls. No touch up.
Gough is offline
Old 12-14-2010, 10:54 PM   #11
Teetorbilt's Avatar
Rewards Points: 2,000
What Itd calls 'hatbanding' we always called 'picture framing'. It can be noticed best with single coating and cheap paint.
A roller going over the cut-in will minimize the effect.
Albert Einstein
Teetorbilt is offline
Old 12-14-2010, 11:13 PM   #12
Also known as brush strokes.
-Paul
TextureMaster.com
Old 12-14-2010, 11:22 PM   #13
Teetorbilt's Avatar
Not brush strokes, more pigment where the two overlap. The wall appears lighter a few inches from trim and corners that were brushed. Rolling over the cut-in blends the paint and makes it less noticible.
Albert Einstein
Old 12-14-2010, 11:39 PM   #14
A. Spruce's Avatar
Trade: General Contractor - ret.
With Behr 2-in-1 there's no need to cut in at all.
+ YouTube Video
A. Spruce is offline
The Following 4 Users Say Thank You to A. Spruce For This Useful Post:
festerized (12-15-2010), jmiller (12-17-2010), Remodelor (12-15-2010), Sir Mixalot (12-14-2010)
Old 12-15-2010, 08:19 AM   #15
Steve Richards's Avatar
Trade: hack painting
Speaking as the resident hack...
I usually roll first (let it dry), then cut, cut again, then roll.
Rolling first shows me exactly where and what needs brush-work.
No sense cutting 3" on a ceiling that only needed 2" (and vice-versa), same with corners...
and especially true with bathrooms, closets, and anywhere else that's gonna need a lot of cutting.
I don't like cutting-in something and then later realizing that area could have been rolled. So I take any guesswork out.
But like Tin said...if whoever's signing the check wants me to cut first...I got no problem w/that either.
Steve Richards is offline
Old 12-15-2010, 09:18 PM   #16
native floridian
jfranklin's Avatar
Trade: Aluminum Contractor & Painting Contractor
Rewards Points: 75
well said
Screen Room, Pool Enclosure specialist
jfranklin is offline
Old 12-15-2010, 09:33 PM   #17
briancreary's Avatar
Rewards Points: 75
Mostly habit but I brush first. I like it too now that I think about it so that I know "what," to roll up to.
briancreary is offline
Old 12-15-2010, 11:53 PM   #18
Particulate Filter
Metro M & L's Avatar
Trade: Flooring
Rewards Points: 1,484
One of my old employee's used to roll first. Then he'd get giggly and hungry and couldn't work for ***** the rest of the day.
Metro M & L is offline
Old 12-16-2010, 11:58 PM   #19
SasquatchPaint's Avatar
Trade: Painting Contractor
In a high end situation we cut in then roll over the cuts with a hot dog roller to get the stipple really close to the corner. Then we roll the wall out. Of course just do one wall at a time to keep a wet edge.
Josh Schultz
http://www.sasquatchpainting.com
SasquatchPaint is offline
Old 12-17-2010, 01:42 AM   #20
Nouveau Eccentric
Diamond D.'s Avatar
Trade: masonry/hardscaping
Rewards Points: 3,384
Is the vote still on?
Sorry guys I didn't read the thread, I just voted.
I usually cut first, then roll. Just seems easier, to me.
I hate cutting, what, with my old eyes and all.
Get it out of the way, then blow in the rolling.
D.
OK, I went back to read.
Texture, sure I still try to get as close to the corner as possible.
I didn't see any thing about trim in OP, but, at least, prime and first finish coat before install. (back to my cutting comment, that's at least 3 less cuts, it's a no brainer.)
@ Steve, I think you should know by now, how wide YOU, have to cut?
D.
" ROCK YOUR WORLD "
fb
Diamond D. is offline
Marketing poll for contractors Dave Renneck Marketing & Sales 0 07-06-2010 09:46 AM
Super Bowl XLIV- Poll JonM Off Topic (Non Trade) 35 02-08-2010 12:30 PM
Screening underside of a deck, roll tension ideas? BACKWOODS General Discussion 3 01-10-2010 07:18 PM
How To Roll Up A Cord NC2X4 General Discussion 36 03-12-2009 07:03 AM
Roll roofing alternatives mikec Roofing 6 09-10-2008 05:09 AM
