Painting Over Splash Pattern - Painting & Finish Work - Contractor Talk
Old 05-01-2010, 09:38 PM   #1
Grand Rapids Remodeling
Paulie's Avatar
Rewards Points: 2,052
I've got a bathroom to paint so HO can sell. The current walls have a white base but a splash pattern where the HO just hurled paint off a brush to make a unconventional look. The problem is the splashes are raised by the amount of paint that dried. I'm thinking I'm going to have to skim the walls, sand and prime. Anybody have a better/faster way?
Paulie is offline
Old 05-01-2010, 09:43 PM   #2
frankster's Avatar
Rewards Points: 75
Re: Painting Over Splash Pattern
that would be my suggestion. Not much else you can really do with that kind of situation.
frankster is offline
Old 05-01-2010, 10:59 PM   #3
The Flooring Guy
cork-guy's Avatar
Trade: Flooring
Rewards Points: 250
You can try a chemical remover, but it will probably strip off the paint behind it as well; I'd just sand it down by hand.
Cork Flooring - Educational information on cork flooring for consumers
Cork Flooring Twitter | Cork Flooring Facebook | Ventless Fireplace
cork-guy is offline
Old 05-02-2010, 07:51 AM   #4
painterman's Avatar
Trade: Historic Restorations
Rewards Points: 288
Palm sander with #80 on it. Square up the sander to wall and sand away.
painterman is offline
Old 05-02-2010, 08:13 AM   #5
Paulie's Avatar
I thought about that but was worried that I'd rough up the paper on the drywall causing more work.
Paulie is offline
Old 05-02-2010, 09:13 AM   #6
Andrew M.'s Avatar
Rewards Points: 150
I would pole sand, skim coat.... PC drywall sander if you have one would be faster. I do not have that so I use my older 6" PC 97336 ,RA ROS [before B&D screwed up PC ]w. dust hook up if you want to use power tools. Latex that is thick will heatup and gum up the sand paper, the vacuum effect helps. I do not see a palm sheet sander helping much, need a more aggressive method and the larger the orbit the better.
Andrew M. is offline
The Following User Says Thank You to Andrew M. For This Useful Post:
Paulie (05-02-2010)
Old 05-02-2010, 09:23 AM   #7
CarlW's Avatar
Rewards Points: 75
If this is something that the homeowner is just trying to sell, then I would ask them if the wanted the painter to go through all this extra work in order to get the walls perfect. If you just hand sand the raised areas, that may be enough to make them happy...you may still see the bumps a little, but it may not look horrible. If you want perfection and need to skim coat then you are talking about extra labor and money that the homeowner may not feel necessary to spend for a house they just want to sell. I have found with projects like this that orbit sanding usually isn't enough....we always have to skim coat.
CarlW is offline
The Following User Says Thank You to CarlW For This Useful Post:
Paulie (05-02-2010)
Old 05-02-2010, 09:40 AM   #8
Steve Richards's Avatar
Trade: hack painting
I vote for skim coat too.
But you could also blow another (heavier) coat of texture to make it more uniform.
maybe not...might just be yet another headache.
Steve Richards is offline
The Following User Says Thank You to Steve Richards For This Useful Post:
Paulie (05-02-2010)
Old 05-02-2010, 01:06 PM   #9
Andrew M.'s Avatar
Rewards Points: 150
Saw a demo of using a rubber blade for the skim coat, might be easier if the surface is so irregular.
Paulie (05-02-2010)
Old 05-02-2010, 01:16 PM   #10
Paulie's Avatar
I already have the drywall mixer and such in the work van for tomorrow. I've already have a set price/sqft. for the job to cover what will have to happen to make walls flat again. High end job, smooth walls a must. Thanks for the responses, I kinda already knew my fate though. I keep saying I'm not a painter but I can't get away from it. In MI you never say no to a job!
Thanks, Paul B.
Paulie is offline
Old 05-02-2010, 04:23 PM   #11
Andrew M.'s Avatar
Rewards Points: 150
Should have said the proper term,"knock down knife"[not a painter either], 22-24" long, rubber blade.
Old 05-02-2010, 04:37 PM   #12
Paulie's Avatar
Thanks Andrew but I'm familiar with a knock down knife. I've done my share of skim coating with mud so I've got my blades and system down pat. I just was trying to get around the inevitable.
Paulie is offline
Old 05-03-2010, 01:46 PM   #13
Andrew M.'s Avatar
Rewards Points: 150
I personally have not used a knock down knife for skim coating. Do you think it is better than using metal?
What's wrong with Painting Contractors? JoshuaPaul Painting & Finish Work 75 01-12-2011 12:08 PM
Painting Shopping complex DenverPainting Painting & Finish Work 11 02-21-2010 07:13 PM
Tailored Painting DenverPainting New Member Introductions 3 11-29-2009 04:18 PM
Painting and handyman, should I simplify? englishdave Business 9 04-14-2009 06:19 PM
hydraulic pattern change mud runner Excavation & Site Work 1 11-05-2008 08:53 PM
