Painting Bullnose Corners - Painting & Finish Work - Contractor Talk
Old 12-13-2010, 01:54 AM   #1
A. Spruce's Avatar
Trade: General Contractor - ret.
How do you guys marry one wall color with another at a bullnose corner? On a square corner it's easy to end one color and start another, how do you handle bullnose transitions with different colors?
I'm asking because I'm curious how you guys handle situations like this, it's not for the newly formed Craigslist company I've started, honest!
Seriously, I'm only asking - no ulterior motives.
A. Spruce is offline
Old 12-13-2010, 02:16 AM   #2
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Re: Painting Bullnose Corners
My painter uses SW Transitional paint. I think he said flat was the best for a smooth segue.
Angus
angus242 is offline
Old 12-13-2010, 02:26 AM   #3
A. Spruce's Avatar
My painter only uses Behr 2-in-1.
Old 12-13-2010, 02:41 AM   #4
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Crap. is that what the 2-1 stands for; 2 transitions, 1 paint.
Damn, now I get it
Angus
angus242 is offline
Old 12-13-2010, 02:47 AM   #5
A. Spruce's Avatar
LMAO!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!:cl ap:
Old 12-13-2010, 11:03 AM   #6
boman47k's Avatar
Rewards Points: 2,006
A few years ago, I think it was Slick (not sure) that showed a piece of bull-nosed bead that he drilled a hole in the center of for a pencil and slid it down the corner to mark a line.
boman47k is offline
Old 12-13-2010, 11:29 AM   #7
Life-Long-Learner
mc handyman's Avatar
Trade: Home Repair & Remodeling
Rewards Points: 150
Regardless of what paint we are using we will paint both walls their own colorand join them on the center of the bullnose. While both colors are still wet we then mix the two colors together in small container and blend them to an equally dominant shade. Then we take a 1" artist brush and blend the two colors. It may be necesarry to redo this a time or two until you find the right color fade.
If the HO wants a solid transition then you can simply paint he dominant color wall, tape the bullnose and then do the other color. I have found that this is not the best way in most cases because sometimes those bullnoses are not perfect and the different profiles up and down the corner really show when you see two different colors meeting up.
If you are afraid of criticism, you will die doing nothing.
mc handyman is offline
Old 12-13-2010, 12:12 PM   #8
aptpupil's Avatar
Rewards Points: 1,894
got any pictures?
aptpupil is offline
Old 12-13-2010, 12:57 PM   #9
A. Spruce's Avatar
Thank you all for your input.
The method that I've heard about, but not tried, is to paint both colors to the corner and leave a wet bead down the centerline of the corner, then use a "dry" roller and run it down the center of the corner, mixing the two colors together. This seems like a fast and good way to go about it. Thoughts?
Old 12-13-2010, 02:57 PM   #10
A bit abrasive.
WisePainter's Avatar
Rewards Points: 1,000
Choose the direction of the dominant room/color, drop roll of tape like a plumb line, paint. I've never considered "blending" colors on a bullnose, I like sharp lines and the wow factor expressed by my clients.
Not that it's wrong but crisp lines are the one thing a pro has over a H.O. paint job.
My advice: Hire a real painter to do it.
WisePainter is offline
The Following User Says Thank You to WisePainter For This Useful Post:
Gough (12-15-2010)
Old 12-13-2010, 03:30 PM   #11
Jeff
jkfox624's Avatar
Trade: master turd burglar
Rewards Points: 502
I dunno i kinda like the blended idea. As long as the colors aren't really drastic i think it could look neat if done right.
jkfox624 is offline
Old 12-13-2010, 03:38 PM   #12
Life-Long-Learner
Rewards Points: 150
I have seen guys do it a few times and it seems to work out well for them. I have tried it once but was unsattisfied with the results because the new roller didnt saturate right off the bat so it gave me kind of a un-even vertical comformity (if that makes sense?). Hell give it a try. I wonder if you could use that same technique but with a light brush to feather in the color?
Old 12-13-2010, 03:41 PM   #13
Life-Long-Learner
Rewards Points: 150
Originally Posted by aptpupil View Post
got any pictures?
I do have some pictures but they are on my flashdrive that I can not find... maybe there is a thread for office organization???
I will post them once I find the flash.
The Following User Says Thank You to mc handyman For This Useful Post:
aptpupil (12-13-2010)
Old 12-13-2010, 04:48 PM   #14
A. Spruce's Avatar
If my brain is looking at it right, a roller has a random pattern to it, so as it smudges the two paints together, it's also giving an erratic pattern, not a straight line as a brush would. I suspect that mixing the two paints as mentioned earlier to wet the roller before making the smudge would produce a more even smudging from top to bottom.
I would think that using stark contrasting colors, a sharp demarcation line where one ends and the other begins would be best, but for similar colors such as an off white and an antique or Navajo white or beige come together a smudged line would be best.
Old 12-13-2010, 05:20 PM   #15
Ohiobuilder's Avatar
Trade: Homebuilder
Rewards Points: 77
We tape our corners with blue painters tape, leaves a nice crisp line with no bleed thru. I would like to see th mixing of the paints as well, that is being very creative!
Ohiobuilder is offline
Old 12-13-2010, 07:44 PM   #16
Life-Long-Learner
Rewards Points: 150
I always ask the homeowner what they would like to see. If the want a crisp line they get a crisp line. If they like the idea of blending the two colors that is what the get-unless the colors are two contrasting. Personally I see a bullnose as creating a continuation of a wall due to its radius unlike sharp corners where I see those as being stopping points.
Does anyone know around what time the use of the bullnose corner came into play? In my area I see allot of them in what was high end homes back in the 60's and 70's
Old 12-13-2010, 08:25 PM   #17
A. Spruce's Avatar
Bullnose started becoming popular around here in the 90's, maybe slightly earlier. I don't generally like it, but it can look nice in some homes.
Old 12-13-2010, 08:29 PM   #18
Construction Connoissuer
CCCo.'s Avatar
Trade: Construction Remodeling - Renovations Repairs
Location: Kirklin, IN "Proudly Serving Central Indiana Area"
Rewards Points: 1,320
Well,
Here's step one!
+ YouTube Video
Looks like someone finally found a use for these things
James Crow - Crow Contracting Company, LLC - Central Indiana Remodeling Contractor
Facebook l Youtube l Merchant Circle
Home, Kitchen & Bath Remodeling - ~ - Facility Maintenance & Repair Solutions
Want to contact us? - Call ~ 765.279.8271
CCCo. is offline
The Following 2 Users Say Thank You to CCCo. For This Useful Post:
dkillianjr (12-13-2010), Remodelor (12-13-2010)
Old 12-13-2010, 08:29 PM   #19
RCPainting's Avatar
Trade: Painting in Utah
We do a lot of them. Tape a straight line and spray it.
Here are some photos.
RCPainting is offline
Old 12-13-2010, 08:30 PM   #20
Remodelor's Avatar
Trade: Bath Remodeling
Rewards Points: 250
I would be very interested to see a transition on a bullnose corner. I think I've seen bullnose corners in one home in my entire life, and that was in Wichita. Been in over 200 homes in KC and haven't seen one yet.
Remodelor is offline
Bullnose Corners Carlos Carpentry 22 01-04-2010 08:57 PM
Problem in corners woodchuck2 Painting & Finish Work 28 08-01-2009 10:07 AM
Painting pre-formed metal corners... Halo Painting & Finish Work 1 12-28-2007 04:15 PM
Painting inside corners gtcway Painting & Finish Work 6 07-05-2006 08:20 PM
Baseboard for bullnose corners martincontracti Finish Carpentry 5 05-03-2006 08:52 PM
