Painting Basement - Painting & Finish Work - Contractor Talk
Painting Basement
Old 03-04-2012, 11:24 AM   #1
Michael217's Avatar
Trade: Licensed Electrical Contractor
Rewards Points: 198
Painting Basement
I,m thinking of pressure washing a basement including ceiling and duck work then letting it dry and then painting the ceiling/walls with a airless sprayer. Will the paint hold or is this a bad idea? Ceiling is open with exposed framing.
Michael217 is offline
Old 03-04-2012, 12:52 PM   #2
shesbros's Avatar
Trade: Painting and Remodeling Contractor
Rewards Points: 249
Re: Painting Basement
pressure washing? Soaking the sub floor, framing, plumbing, furnace, hot water heater, electrical? Floor drain?
shesbros is offline
Old 03-04-2012, 02:21 PM   #3
Professional Tradesman
GPI's Avatar
Trade: Painting-Wallcoverings-Drywall-Carpentry
Rewards Points: 250
Is this CONTRACTOR TALK!!!!???????
Holy Smoke!
GPI is offline
Old 03-04-2012, 02:48 PM   #4
Michael217's Avatar
Rewards Points: 198
OK, let me try it this way. How does one prepare a basement ceiling/walls for painting with an airless sprayer? There is a lot of dirt/dust on the duck works etc.
Old 03-04-2012, 02:54 PM   #5
GPI's Avatar
Rewards Points: 250
Never tried painting a duck !!!!!!!!!!!!!!!!!!!!
GPI is offline
Old 03-04-2012, 02:58 PM   #6
mbobbish734's Avatar
Trade: Property Preservation & Remodeling
Oh a wise guy aye, I oughta
mbobbish734 is offline
The Following User Says Thank You to mbobbish734 For This Useful Post:
GPI (03-05-2012)
Old 03-04-2012, 10:47 PM   #7
Pete'sfeets's Avatar
Trade: house painting and miscellaneous repair
silly it's a basement who gives a flying cow patty if its dirty or done right, get the sprayer, and spray the dirt out, 'course you might want some waterproofing paint for the block walls and the paint the floor last , thats the time to clean. Don't bother painting the stained toilet, not worth the trouble. hope this helps.
If paint covers all sins ,,,then I guess I should be covered
Pete'sfeets is offline
Old 03-05-2012, 06:21 AM   #8
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 2,942
No to the pressure washer. Go with a shop vac.
Ohio painter is offline
The Following User Says Thank You to Ohio painter For This Useful Post:
fourcornerhome (03-05-2012)
Old 03-05-2012, 10:46 AM   #9
Particulate Filter
Metro M & L's Avatar
Trade: Flooring
Rewards Points: 1,484
Compressed air will also work well. In the past I have also used a landscape blower (open the doors so you dont kill yourself with monoxide).
Use oil primer and the best respirator you can find. Vaseline your cheeks; the fumes will melt your brain.
Metro M & L is offline
The Following 2 Users Say Thank You to Metro M & L For This Useful Post:
aptpupil (03-05-2012), mbobbish734 (03-05-2012)
Old 03-05-2012, 03:30 PM   #10
GPI's Avatar
Rewards Points: 250
I would also add, please shut off any pilots, you may melt more than just your brain.
GPI is offline
Old 03-05-2012, 03:42 PM   #11
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
I paint ducks all the time. You really need to get out more.
ohiohomedoctor is offline
Old 03-05-2012, 04:44 PM   #12
GPI's Avatar
Rewards Points: 250
Youre quacking me up!!!!!!!!!!!!!!!!
GPI is offline
Flooded Wooden Basement FremontREO General Discussion 20 09-04-2011 01:54 PM
Painting a Basement Floor Tech Dawg Painting & Finish Work 7 06-04-2011 09:50 AM
new tank location using PVC in basement? Benchwrench Plumbing 13 04-27-2011 06:38 PM
painting old basement davidanbess Painting & Finish Work 32 04-29-2009 07:59 PM
Painting and handyman, should I simplify? englishdave Business 9 04-14-2009 06:19 PM
