Painting An Aging Lintel - Painting & Finish Work - Contractor Talk
Old 08-30-2019, 08:29 AM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 4,816
Normally I'd hit with emery cloth, before rust inhibitive primer and then finish with oil.
The steel of this one, if you look edge-on, has progressed into the layering phase.
What to push in the slivery voids is the question...?
artinall is offline
Old 08-30-2019, 09:30 AM   #2
hdavis's Avatar
Rewards Points: 4,894
Re: Painting An Aging Lintel
A small needle scaler.
hdavis is online now
artinall (08-30-2019)
Old 08-30-2019, 12:35 PM   #3
artinall's Avatar
Believe I need to fill the open areas, rather than removal.
Steel actually seems to be separating into think layers.
artinall is offline
Old 08-30-2019, 12:50 PM   #4
John the Builder
SmallTownGuy's Avatar
Rewards Points: 4,072
Get a rust converter product from auto parts store or HD.
Naval Jelly or whatever they carry.
Otherwise its gonna continue to scale and pop.
Fill smooth and prime after as needed.
SmallTownGuy is offline
The Following User Says Thank You to SmallTownGuy For This Useful Post:
Old 08-30-2019, 01:13 PM   #5
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 14,509
rust neutralizer. inject it with a syringe, or use chip brushes and wet in there. Protect yourself (eyes). Then fill, prime, paint.
MarkJames is offline
Old 08-30-2019, 01:42 PM   #6
hdavis's Avatar
It is separating. You won't get anything that will get in there and convert the rust if you don't get most if it off. Seal it, and the bit of moisture in there will keep it rusting for a short time.
It's only a matter of time no matter what you do.
Old 08-30-2019, 04:17 PM   #7
artinall's Avatar
Used rust converter on other things. Simply forgot about it...
artinall is offline
The Following User Says Thank You to artinall For This Useful Post:
SmallTownGuy (08-30-2019)
Old 08-30-2019, 05:51 PM   #8
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 1,956
What the hell are you people seeing that I don't see?
No link or photo.
Andy.
ScipioAfricanus is online now
Old 08-30-2019, 07:37 PM   #9
artinall's Avatar
No link or photo.
Andy.
Dropped in on your website -- and see you're more visual.
Unfortunately won't be able to share a pic on this one.
Picture deep scale rust on a brick-supporting lintel. Something you never want to have to replace.
artinall is offline
Old 08-30-2019, 08:21 PM   #10
tjbnwi's Avatar
Rewards Points: 4,314
Lintel needs to be replaced. Painting is not an option.
tjbnwi is online now
The Following 3 Users Say Thank You to tjbnwi For This Useful Post:
avenge (08-30-2019), griz (08-30-2019), hdavis (08-30-2019)
Old 08-30-2019, 09:27 PM   #11
hdavis's Avatar
Just a matter of time before the rusting starts cracking the brickwork, and the rusting is too advanced to stop it.
Old 08-30-2019, 10:59 PM   #12
artinall's Avatar
Appreciate the input.
Although I do think it can be swung. Might outlast me anyway.
High grade sealer across the entire wall pretty much stopped all movement (after pointing) that had been setting off step cracking. It hasn't shown signs of cracking in years. Water still beads. Eliminating so much expansion and contraction.
Even if stabilizing the mortar doesn't directly affect an ability to carry a load...treating the lintel has become more isolated.
artinall is offline
