Painted Hardware - Painting & Finish Work - Contractor Talk
Painted Hardware
Old 02-25-2011, 10:24 AM   #1
Peter74's Avatar
Trade: General/Framing
Painted Hardware
Hi Guys,
What is the best way to remove small remnants of paint that got onto the hardware? There has got to be a better way than using a cloth and paint thinnner. What is the quickest and fastest way? Thanks!
Pete
Peter74 is offline
Old 02-25-2011, 12:17 PM   #2
briancreary's Avatar
Rewards Points: 75
Re: Painted Hardware
First is to mask it off well so you don't have the problem to begin with. It does happen though (paint getting on stuff); and regular old Krud Kutter works fine if it's water borne. If it's oil, use mineral spirits, but be careful not to use something so corrosive that it takes the finish off the hardware, or dulls the finish. An ounce of pervention is always worth a pound of cure.
briancreary is offline
The Following User Says Thank You to briancreary For This Useful Post:
Peter74 (02-25-2011)
Old 02-25-2011, 12:20 PM   #3
Peter74's Avatar
Thanks!
Peter74 is offline
Old 02-25-2011, 05:21 PM   #4
A bit abrasive.
WisePainter's Avatar
Rewards Points: 1,000
denatured alcohol, with a light touch.
My advice: Hire a real painter to do it.
WisePainter is offline
Old 02-25-2011, 09:00 PM   #5
Peter74's Avatar
Thank you
Peter74 is offline
Old 02-25-2011, 09:42 PM   #6
boman47k's Avatar
Rewards Points: 2,006
I have soaked cabinet hardware that was painted in sopay water overnight to get latex off.
boman47k is offline
The Following User Says Thank You to boman47k For This Useful Post:
WisePainter (02-25-2011)
Old 02-25-2011, 10:18 PM   #7
A bit abrasive.
Originally Posted by Peter74 View Post
Thank you
my pleasure.
be careful with anything petroleum based that leaves a film like mineral spirits, hence the alcohol which evaporates instantly.
Old 02-26-2011, 09:59 AM   #8
Rewards Points: 75
Originally Posted by WisePainter View Post
my pleasure.
good point
Peter74 (02-26-2011)
Old 02-26-2011, 10:24 AM   #9
uselessknowledg's Avatar
dont get paint on them, thats usually the best way to get the paint off.
uselessknowledg is offline
The Following User Says Thank You to uselessknowledg For This Useful Post:
Old 02-26-2011, 10:31 AM   #10
boman47k's Avatar
, but sometimes on repaints, the paint is on the hardware before you even start. Not just specks but covered in paint.
Then is time for soap, water, and brush.
boman47k is offline
Old 02-26-2011, 01:38 PM   #11
Peter74's Avatar
Boman, you wouldn't use paint thinner? The paint is water based. You think just soap water and a brush is all you need? Pete
Peter74 is offline
Old 02-26-2011, 01:47 PM   #12
Painter/Rehaber
Dustyrose's Avatar
Trade: Painter
Rewards Points: 250
I use glass cleaner and a soft rag. Paint comes right off.
No harsh fumes and will not damage the paint on the walls and trim.
On older hardware with old paint I have had some luck with glass cleaner and 000 stealwool.
Politics is the art of preventing people from taking part in affairs which properly concern them. Paul Valery
Dustyrose is offline
The Following User Says Thank You to Dustyrose For This Useful Post:
Old 02-26-2011, 02:19 PM   #13
boman47k's Avatar
I see no need for thiner on latex/waterbased.
I let the hinges and handles soak over night and mostly used my fingers and a small stiff cleaning brush and/or rag for the hard to get to details. The paint becomes very loose.
boman47k is offline
Where do you buy your hardware? aghdonmc Windows, Siding and Doors 5 02-04-2011 07:45 AM
Heavy Duty hardware for bi-fold closet doors jfman Finish Carpentry 4 01-30-2011 11:07 PM
Thin Brick over Painted Concrete Tommy C Masonry 5 08-27-2009 07:33 AM
PVC or Painted Coil? CharlesD Windows, Siding and Doors 9 08-23-2009 07:37 PM
Free Commercial Hardware Spec Writing adamrumm Commercial Construction 0 10-29-2008 03:55 PM
