Paint For Skate Board Surace - Wood - Painting & Finish Work - Contractor Talk
Old 03-19-2010, 02:37 PM   #1
SamContract's Avatar
Trade: Woodworker
Smile
Hello,
I have a customer who has asked me to build some custom skateboard ramps for their children. I'm pretty handy with woodworking on the side so I decided to take on the job.
My biggest problem though is what to finish the ramps with. I have seen companies selling really expensive paint for ramps, but I'm looking for a generic version that will grip the wheels of the board and not create a slippery surface like a typical wood sealer like Thompson's would do. Preferably I'm looking for a one part polyurethane epoxy. Any advice would be greatly appreciated since I'm tight on my budget and I'm looking to finish it ASAP.
Thanks Sam.
SamContract is offline
Old 03-19-2010, 03:06 PM   #2
Project Manager HFH..
JumboJack's Avatar
Rewards Points: 2,004
Re: Paint For Skate Board Surace - Wood
Cover it with masonite board.
in texas with framing and cornish people will do it for 3.00 a foot. What do yall think about that? Just laber
JumboJack is offline
Old 03-19-2010, 04:31 PM   #3
The Brains
JKBARR127's Avatar
Trade: carpenter
Rewards Points: 150
i didn't want to say anything but it would suck to get a ramp built and have it suck. The people ur building it for should be building it themselves.
in case you have no idea what your doing ur gonna want two layers of ply. the grain of the base layer running perpendicular to the direction of the rider and the grain of the top layer running parallel to the rider and perpendicular to the base layer. Masonite board is good if its an indoor ramp. spar urethane works well for paint an acrylic enamel. if using Masonite seal all sides and edges.
this is something that would be better built by a rider or skater as they know the function and not just the idea. There are prints available. For more help im sure you would be better of on a skate site or ramp builders forum. there are plenty out there.
just wondering if you have taken measures to ensure the customers dont come after you when someone breaks an arm or neck.
good luck
Its no good-Take it down
JKBARR127 is offline
Old 03-19-2010, 05:12 PM   #4
Motorboatin' son of a ...
BKFranks's Avatar
You should be using a product like Ramp Armour or Skatelite Pro for that. These products are specifically manufactured for the outdoors and harshness of skating in which any type of paint would not hold up.
BKFranks is offline
Old 03-20-2010, 12:57 AM   #5
KennMacMoragh's Avatar
Trade: Repair/Remodel
Rewards Points: 3,278
Doubt the homeowner would want to pay the money for those manufactured ramp materials. If it was for a professional skateboard ramp, then yeah. But if it's for someones kid in their back yard, probably not.
I helped my cousin build a skateboard ramp for himself once. We didn't paint it or anything, and used one layer of quarter inch plywood for the ramp. I thought it would need two layers, but he looked at other skateboard ramps and swears that's how they're all done, one layer of quarter inch. It worked pretty cool until his mom made him tear it apart, took up too much room in the garage.
I don't see how the paint or stain being slippery would cause a problem skate boarding on it. I would think you'd want it slippery so if you fall you'd slide down the ramp and not hurt yourself so much.
KennMacMoragh is offline
Tags
non-slip , paint , ramps , skateboard , wood
Exterior House Paint UniqueInteriors Painting & Finish Work 27 08-14-2009 01:57 PM
Provide the paint? zipicus Painting & Finish Work 4 07-06-2009 06:15 PM
why is latex paint peeling?? Zeebo Painting & Finish Work 24 05-28-2009 06:59 AM
Painting Wood Stove... Al Taper Painting & Finish Work 11 10-14-2008 10:30 PM
paint bubbles on door jambs moe2424 Painting & Finish Work 10 10-13-2008 09:05 PM
