Paint Chipping, No Primer? - Painting & Finish Work - Contractor Talk
Old 06-02-2015, 10:46 AM   #1
ChicagoHandyman's Avatar
Trade: General
Rewards Points: 30
When we started sending this wall paint started to flake off the more we scraped the more chips off with ease. It looks like no primer was applied to this wall.
Does anybody have a solution to expedite the preparation of this wall so we can put paint on?
ChicagoHandyman is offline
Old 06-02-2015, 11:00 AM   #2
Quality_PTG's Avatar
Trade: Painting and Decorating
Rewards Points: 258
Re: Paint Chipping, No Primer?
Have 2 guys sand with 100 and 120 sandpaper. Prime, major patching prime again then finish
Quality_PTG is offline
The Following User Says Thank You to Quality_PTG For This Useful Post:
ChicagoHandyman (06-02-2015)
Old 06-02-2015, 04:28 PM   #3
30 year novice
carzie's Avatar
Trade: Painting contractor
Rewards Points: 2,653
About the only thing you can do is crape until it stops coming off, sand it good, lock it down with an oil primer, patch, sand, prime....etc. Is there paint under the stuff that's chipping off? I'm thinking it's a classic case of latex on top of oil.
carzie is offline
The Following 2 Users Say Thank You to carzie For This Useful Post:
ChicagoHandyman (06-02-2015), Danahy (06-05-2015)
Old 06-02-2015, 04:34 PM   #4
Rewards Points: 258
From the looks of the picture it's going straight to bare drywall. Maybe they put a pearl or satin with no primer
Old 06-02-2015, 04:45 PM   #5
Trade: General
Rewards Points: 30
it was chipping off to the paper. We scraped 50% of it and then hit it with a primer/sealer. then spackle, sand, spackle, primer paint.
Thanks everyone. between you and the guy at sherwin williams, we are gonna get this one knocked out.
Old 06-02-2015, 05:41 PM   #6
Caslon's Avatar
Trade: State Licensed Painting Contractor
Rewards Points: 3,246
Lock it down with BIN primer. It'll dry hard like a turtle shell.
Caslon is offline
The Following User Says Thank You to Caslon For This Useful Post:
ChicagoHandyman (06-03-2015)
Old 06-04-2015, 06:58 PM   #7
kingcarpenter's Avatar
Trade: G.C./carpenter
Rewards Points: 544
Use Glidden gripper as your only primer and you will never have a problem. You can't pull it off with a front end loader and it will stick to any surface bar none. Have seen this happen more than once. Several things will cause this. Sprayed when texture/compound not completely dry with high humidity, too much water or bad mix from supplier. As mentioned above water over oil.
kingcarpenter is offline
Old 06-05-2015, 12:18 AM   #8
Caslon's Avatar
Actually, no offense to the Gipper (Glidden) but over those areas where he wasn't able to remove all the badly adhering paint, a hard "turtle shell" coating using pigmented shellac gives him the best chance of locking down those areas AND providing a super "hard coating" if it gets bumped up against. Of course the idea is to get off all the old paint that isn't sticking worth a damn, but sometimes that just isn't possible.
Caslon is offline
Old 06-05-2015, 12:38 AM   #9
mnld's Avatar
Trade: drywall junky
Rewards Points: 498
Gripper is one of the best primers out there for most surfaces. However it doesn't seal down loose material. For that I use guardz or oil.
mnld is offline
The Following User Says Thank You to mnld For This Useful Post:
Nick33 (06-10-2015)
Old 06-05-2015, 12:39 AM   #10
mnld's Avatar
Rewards Points: 498
Oops, didn't see Caslon's last post.
mnld is offline
Old 06-06-2015, 08:13 PM   #11
Rewards Points: 544
Basically I was trying to get across to the op if they use gripper from jump they wont have this problem. Agreed it needs to be locked down in this situation. Last mess I had like this was painted wet where gc was pushing closing. I didn't paint it but had to fix it. Sorry for not being a little more clear
Old 06-08-2015, 03:42 PM   #12
Stelzer Painting Inc.
stelzerpainting's Avatar
Trade: 1721
Rewards Points: 492
Gardz. Wonderful stuff.
https://www.rustoleum.com/product-ca...urface-sealer/
Troy Stevens, Stelzer Painting Inc.
www.stelzerpainting.com
stelzerpainting is offline
The Following User Says Thank You to stelzerpainting For This Useful Post:
Nick33 (06-10-2015)
paint over eggshell MarkJames Painting & Finish Work 17 08-12-2013 11:50 PM
Paint on underside of shingles? climb.on Painting & Finish Work 31 08-28-2012 07:57 PM
Behr paint is great... lol Mike Finley Painting & Finish Work 132 08-14-2010 10:13 AM
Primer / Sealer VS Flat paint A+ Texture Painting & Finish Work 20 05-01-2009 08:37 PM
