Paint Bubbling Up - Painting & Finish Work - Contractor Talk
Paint Bubbling Up
Old 04-15-2019, 05:20 PM   #1
BLI's Avatar
Rewards Points: 12
Paint Bubbling Up
I had this happen on a small scale once. I painted over an already painted wall. A small area about 3x4” bubbled up, the old paint that was on the wall separated from the drywall and made a bubble. I scraped it off let it dry out spackled the area primed it and re painted it. Today a customer wanted a few visible drywall seems feathered out before painting. I skim coated the seems with spackle to repair the area. I looked at it a few hours later and the wall was all bubbled up under the spackle. Some areas like 12x12” and others anywhere from 3” to 6” circles. The spackle was starting to dry and I could push on the bubbles. I’m assuming the paint that was under the spackle got moist and separated from the wall. I bought it to the homeowners attention and he said the same thing happened when another room in the house was painted and he showed me some other spots that still had bubbles in it from previous painting. Does anyone know what causes this, was primer not used when the house was built? I’m not looking coward to going back tomorrow and painting the room.
BLI is offline
Old 04-15-2019, 06:52 PM   #2
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 2,550
Re: Paint Bubbling Up
Contamination or incompatibility of some sort.
Gonna have to prime the whole job with 1-2 coats of BIN Shellac based primer or Cover Stain oil based primer.
Only way to get out of there.
Steve
We Fix Houses is offline
Old 04-15-2019, 07:05 PM   #3
BLI's Avatar
Rewards Points: 12
I guess I’ll try painting one wall and see what happens first
BLI is offline
Old 04-15-2019, 07:29 PM   #4
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 14,963
Just had this issue with a water damaged wall. The paper of the drywall separated from the gypsum when it got wet from the new mud being applied over it to skim it. I ended up ripping the paper off where it bubbled and then using hot mud to repair the bubble.
Sno says he cuts the bubble down the center and pushes mud under the bubble and then knifes it flat and skims over it. I tried that with one of the bubbles I had and it worked. It was more of a pain to do than just rip off the paper.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
Old 04-15-2019, 07:33 PM   #5
BLI's Avatar
Rewards Points: 12
It could also be the drywall paper separating and bubbling, I didn’t mess with it today figured I’d let it all dry out.
BLI is offline
Old 04-15-2019, 07:35 PM   #6
BLI's Avatar
Rewards Points: 12
If it is the paper I’ll try that thanks
BLI is offline
Old 04-16-2019, 05:37 AM   #7
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 3,020
Bubbling under the sparkle is a [email protected] situation.
If I thought it was going to be an extensive issue and did not want to fix each bubble that might occur then I would prime the whole wall / walls with SW shellac primer. Nasty stuff. I think someone else here has said BIN which I don't use.
These primers will create a barrier that you can then paint over without the paint penetrating into the layers underneath creating the bubbles. Good luck.
Ohio painter is offline
The Following User Says Thank You to Ohio painter For This Useful Post:
hdavis (04-16-2019)
Old 04-16-2019, 07:32 AM   #8
Porterfarm's Avatar
Trade: Handyman/ Home Improvement Contractor
Rewards Points: 28
It could be wall paper paste residue...any good oil primer will fix that if that's what it is.
I always prime before paint when removing paper. And I always talk to the paint store personal. So I just had this conversation last week, because I have a few rooms that had paper removed by others. The occupant has breathing issues. I was assured that latex will not work. The moisture re-activates the glue making bubbles. And it may not occur right away. They say it can happen months later.....They did recommend this water based product that goes on clear, it's a wall paper product that I could use...( Sorry I forget the name, but will look into it more next week when I'm ready to start painting.
Porterfarm is offline
Old 04-16-2019, 09:27 AM   #9
hdavis's Avatar
Rewards Points: 3,086
The clear product is Gardz.
hdavis is offline
Old 04-16-2019, 09:33 AM   #10
hdavis's Avatar
You can also have bubbling due to a poor PVA primer on new drywall. You can peel the paint off pretty easily.
The first thing to do here is figure out what is separating from what and why. Peel a bubble off and see what you have.
hdavis is offline
Old 04-16-2019, 09:37 AM   #11
hdavis's Avatar
A lot of times you can glue bubbles down using a wall paper paste syringe. Just inject into the bubble.
hdavis is offline
Old 04-16-2019, 10:18 AM   #12
BLI's Avatar
Rewards Points: 12
Checked it today it’s the paint coming off the drywall. The paper is fine. I removed the bubbles and re spackled the areas. So far when painting the walls I’m not having an issue.
BLI is offline
The Following User Says Thank You to BLI For This Useful Post:
hdavis (04-16-2019)
Old 04-16-2019, 10:27 AM   #13
hdavis's Avatar
Poor primer, or the drywall didn't get cleaned well enough before painting, or both.
hdavis is offline
Old 04-16-2019, 10:33 AM   #14
BLI's Avatar
Rewards Points: 12
That’s what I’m thinking, hopefully some isolated spots that were dusty when originally primed/painted
BLI is offline
hdavis (04-16-2019)
Are you loyal to your paint brand/supplier? Grateful_Monk Painting & Finish Work 23 04-24-2014 06:31 AM
Drywall Patch Flashes Through Paint BobbyCA Painting & Finish Work 18 05-04-2013 07:04 AM
Metal Roof Paint - animal safe artinall Painting & Finish Work Picture Post 5 04-25-2013 09:45 PM
Behr paint is great... lol Mike Finley Painting & Finish Work 132 08-14-2010 10:13 AM
Best Paint for a Historic Home fatal_degree Painting & Finish Work 15 04-23-2010 08:09 AM
