Need Help W/ Ext Paint Bubbling! - Page 2 - Painting & Finish Work - Contractor Talk
Thread Tools
Old 09-18-2010, 07:44 AM
Steve Richards's Avatar
Trade: hack painting
Re: Need Help W/ Ext Paint Bubbling!
Originally Posted by RadRemod View Post
the back of the bubble it was white, the previous color. Appears to go at least a coat or two beneath my new coat.
Suggests the problem isn't with your paint
Previous painter had just scraped and painted(college pros)
hmmm...
Steve Richards is offline
Old 09-18-2010, 09:53 AM
Trailer park boy
shanekw1's Avatar
Rewards Points: 371
I agree, but from where? And yes I already have soffit vents running around my home, but not siding vents.
How old is the house?
If there is no vapor barrier on the inside, moisture could be going through the walls from the interior of the house.
"Industry without art is brutality"
shanekw1 is offline
The Following User Says Thank You to shanekw1 For This Useful Post:
WarnerConstInc. (09-19-2010)
Old 09-18-2010, 10:11 AM
If that's the case, would he need to put siding vents every 16", towards the top of each wall?
More vents that that?
..or something else completely?
Old 09-18-2010, 11:58 AM
Paint Dribblz's Avatar
Rewards Points: 25
If you post pictures of the issue we might be able to help more. My solutions stop if you have vents running your soffits because that should reduce the heat coming out of the attic down the wall boards. Maybe pics of what it looks like when you strip the bubbles off and some pics of the overall house where the issues are coming up.
To me though, it's sounds like you shouldn't be having this problem, but that's why we are all here, to sort issues out. I'd love to keep updated with this for my future encounters. I'm sure everything here you have heard from your paint reps so its really a guess and check I believe now. The question is how much time do you have to put into your house...
Paint Dribblz is offline
Old 09-18-2010, 12:35 PM
RadRemod's Avatar
Rewards Points: 150
Shane- the house was built in 1964
Dribblz-I'll try to get some pictures taken and up today. I'm planning on being at the house for a while now so I'd like to find and fix the problem not just the symptom. Then I wont have to screw with it again. Also it will give me a game plan if it happens to someone else.
RadRemod is offline
Old 09-18-2010, 08:45 PM
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
your neighbors havent had new windows put in recently have they?
Tom Struble is offline
The Following 2 Users Say Thank You to Tom Struble For This Useful Post:
aptpupil (09-23-2010), CookeCarpentry (09-21-2010)
Old 09-18-2010, 09:32 PM
RadRemod's Avatar
Rewards Points: 150
No old crappy aluminum Ibelive. Why?
RadRemod is offline
Old 09-19-2010, 12:22 AM
Gough's Avatar
Trade: painting
hmmm...
That it was older paint under the bubble suggests that it wasn't moisture either. Those would almost always go down to bare wood.
Gough is offline
Old 09-19-2010, 10:32 AM
Good point.
Maybe the previous painter oil-primed too soon after washing?
Maybe the previous painter's finish didn't adhere to their primer?
In either case, sounds like wetting it with paint caused it to let go and form blisters.
But why wouldn't these blisters have shown up a long time ago after a good rain?
Hey Rad, does it ever rain there?
Old 09-19-2010, 10:50 AM
Gough's Avatar
Trade: painting
Good point.
As someone pointed out earlier, this seems to be more of a problem with darker colors. Sometimes, those are solvent blisters, caused by the surface of the fresh paint drying to quickly and trapping water underneath before it can evaporate. Since the OP said that the failure happened between layers of older paint, it sounds more like an incompatability problem in the older paint. I could see it being one of those issues that you mentioned, Steve. The higher surface temperatures as a result of the darker paint could be what caused the problem to show up now.
Gough is offline
Old 09-19-2010, 01:14 PM
RadRemod's Avatar
Rewards Points: 150
Good point.
Steve- We do get a good amount of rainfall over here in OR.
You guys may be on to something with the dark paints. I'm kind of wondering if the college pros paint used was crap and didn't adhear well. I did scrap every single bubble or pealed spot. I'm wonderingif the new darker paint is heating up and lifting the bad paint.
So do I purchase a Paint shaver pro for $8-900 or reside for $20-2500?
I'm just not sold on the siding vents and I think it would look like ass having vents every 16" on the walls.
RadRemod is offline
Old 09-19-2010, 02:09 PM
They can be painted to match...
(of course since they're plastic, they'll probably peel)
then you can come back here and start another successful thread
Old 09-19-2010, 02:31 PM
RadRemod's Avatar
Rewards Points: 150
Just got a few photos! The first is the bubbles on the house. Second a single bubble and third that bubble scraped with only a 4" putty knife in about 5 seconds!
Just noticed something that might help. Its only about 70 degrees here in Salem,OR today but the brown paint is hot to the touch. However the area of paint that I stripped to white paint the other day is still cool. Both are in direct sunlight!
I'm wondering if the dark paint is heating up too much and releasing an old failing layer of paint. Almost like using a heat gun on it. What do you think?
Need help w/ ext paint bubbling!-house-buubles.jpg   Need help w/ ext paint bubbling!-paint-bubble.jpg   Need help w/ ext paint bubbling!-scraped-bubble.jpg
RadRemod is offline
Old 09-19-2010, 02:36 PM
Sounds good to me.
Is the "white" the previous paint, or your primer?
Old 09-19-2010, 02:57 PM
RadRemod's Avatar
Rewards Points: 150
The white is a previous layer of paint(not sure how deep). My primer was tinted a brown to be about 50% as dark as my top coat.
RadRemod is offline
Old 09-19-2010, 05:36 PM
Gough's Avatar
Trade: painting
I think you've found the problem. The clapboards look to be in pretty good shape, so they may be worth stripping. If it were my place, I'd strip the siding using heat plates and scrapers, sand, prime, and paint. More importantly, if it were my place, I wouldn't have to worry about RRP.
Gough is offline
Old 09-19-2010, 06:15 PM
Trailer park boy
shanekw1's Avatar
Rewards Points: 371
Looks like someone put latex over oil, to me.
shanekw1 is offline
Old 09-19-2010, 08:11 PM
hmmm..
easy enough to check w/some alcohol.
Hey Rad, if you wipe your hand across that white, does any chalk come off on your hand?
Old 09-19-2010, 08:35 PM
RadRemod's Avatar
Rewards Points: 150
Steve- Just went out and rubbed my hand on the white paint and got a little white residue on my finger tips.
What are you thinking?
RadRemod is offline
Old 09-19-2010, 09:43 PM
Right now, I'm thinking: "I wonder if he's washed his hand yet"?
I'm also thinking I wish Rad had checked his siding for chalking before he put away his house-washing equipment.
Flat paints chalk, especially on the sunny sides, and worse if it's crappy paint.
I confess I'm not familiar with Miller's Acrilite primer...I suggest you see what it says on the can about putting it on chalking surfaces (some primers are ok w/it)
(might google "paint chalking" too.)
Most importantly remember.... If I had any really good advice, I probably wouldn't be here giving it away for free.
Thread Tools
Rate This Thread
Paint or stick with solid color stain? JL1 Painting & Finish Work 46 01-16-2014 06:58 AM
Behr paint is great... lol Mike Finley Painting & Finish Work 132 08-14-2010 10:13 AM
Paint sprayer yields "orange peel" finish BRUCE R Painting & Finish Work 5 05-01-2010 04:42 PM
Best Paint for a Historic Home fatal_degree Painting & Finish Work 15 04-23-2010 08:09 AM
blistering paint GWHRsuperhero Painting & Finish Work 9 03-06-2007 08:43 PM
