Interior OSB Finish Ideas - Painting & Finish Work - Contractor Talk
Old 06-10-2015, 06:01 PM   #1
Jimbo2015's Avatar
Trade: solar
Rewards Points: 178
The house is built with Sips panels so the whole interior walls are OSB.
Trying to come up with alternative ideas to finish them, to avoid having to hang sheetrock or something else. Any ideas are appreciated.
My first thought was to maybe have the walls skim coated or painted where the osb chips don't show thru
spray a texture splatter coat and knock it down
Jimbo2015 is offline
Old 06-10-2015, 06:06 PM   #2
Box Builder
Morning Wood's Avatar
Rewards Points: 9,696
Re: Interior OSB Finish Ideas
Drywall is your best bet. Otherwise horizontal or vertical wood, wainscoting etc. going to take a lot of paint to cover OSB and have it not look like OSB. Alot of paint. Alot.
Morning Wood is online now
Old 06-11-2015, 01:02 AM   #3
Caslon's Avatar
Trade: State Licensed Painting Contractor
Rewards Points: 3,246
Yikes, drywall over it all? I've not dealt with this situation but drywall will prove costly. A texture splatter over a skim coat might be cheaper. The texture splatter afterwards would cover up imperfections in the quick skim coat.
Caslon is offline
Old 06-11-2015, 02:50 AM   #4
Walraven's Avatar
Trade: carpenter/joiner
Rewards Points: 372
Id hang plasterboard over it before i bothered to skim it.
Why not look into what you can do to make a feature of it stain and clear coat?
Walraven is offline
Old 06-11-2015, 06:22 AM   #5
Jimbo2015's Avatar
Trade: solar
Rewards Points: 178
Found this idea, the osb was stained a dark color, then with a short nap roller painted white.
They said it celebrates the osb rather than hides it.
What do you think, may work for tall cathedral ceilings in this build
Old 06-11-2015, 08:39 AM   #6
tccoggs's Avatar
Rewards Points: 874
I'm my area this wouldn't pass code for flame spread reasons. If its living space you need to cover the osb with drywall.
tccoggs is offline
Old 06-11-2015, 10:34 AM   #7
Jimbo2015's Avatar
Trade: solar
Rewards Points: 178
So I Googled "Flame Spread Index" and found this doc from the American Wood Council:
www.awc.org/Publications/dca/dca1/DCA1.pdf
They say that "most tested wood products have a flame spread index less than 200, making them acceptable under current building codes for a wide range of interior finish uses."
so I think that it meets code from what I read.
Old 06-11-2015, 01:16 PM   #8
Walraven's Avatar
Rewards Points: 372
Yeah that looks pretty cool.
Walraven is offline
Old 06-12-2015, 08:39 AM   #9
deter's Avatar
Trade: Project Managment & hack-of-all-trades
Rewards Points: 44
drywall it. Seriously, do you want the inside of the house to look like a garage with painted OSB?
deter is offline
Old 06-12-2015, 08:48 AM   #10
Box Builder
Cover that crap up man. You can put anything on there. You have infinite nailing locations
The Following User Says Thank You to Morning Wood For This Useful Post:
slowsol (06-12-2015)
Old 06-12-2015, 09:01 AM   #11
Drywall Slave
blacktop's Avatar
Trade: drywall contractor
Rewards Points: 214
There Is an alternative ! If your willing to pay for it. This process can work over brick.Block.Wood...etc. The seams on that osb will need to be taped and one coated tho. [imo] http://www.frescoharmony.com/index.php/galleries
Don't quote me on this !! But I think this is around $2 a ft. So you do the math ...Fresco or Drywall it And finish it off smooth.
I know this tho...Drywall over that osb will make for some nice flat ceiling and walls.
"Always listen to your heart . Always listen to your dog ." Quote. Gauge key .
blacktop is offline
The Following User Says Thank You to blacktop For This Useful Post:
mnld (06-12-2015)
Old 06-12-2015, 09:09 AM   #12
Drywall Slave
blacktop's Avatar
Rewards Points: 214
Check out Nick's You tube channel ..He has a vid where he trowels over a ply board kitchen ceiling . Turns out nice! And he has a large variety of colors to choose from.. After the sealer goes on ...No painting..
No sanding either.. I'll say that again...No sanding involved !!! Plus you get to kick the painter to the curb!!
blacktop is offline
mnld (06-12-2015)
Old 06-12-2015, 05:15 PM   #13
Jimbo2015's Avatar
Trade: solar
Rewards Points: 178
the point of the thread was ideas to avoid drywall,
that what the client wants.
input along those lines are appreciated.
so far they like stain with white paint over for the ceilings.
Yes they will save money doing that way, if fact the roof panels can be stained & painted while on the ground super fast before hoisting up.
No scaffolding etc only thing to do is caulk the seams, but the 10 roof panels are 8' X 18', not that many seams.
Old 06-12-2015, 06:07 PM   #14
Drywall Slave
blacktop's Avatar
Rewards Points: 214
Exposed osb . That's fancy.
But... It's not mine to ask why!
blacktop is offline
Porter Cable "Bammer" 15 ga Angled Finish JR Shepstone Tools & Equipment 7 03-11-2013 07:48 AM
Basement finish rex Construction 45 09-15-2012 03:53 PM
Bostich Cordless Angled Finish Nailer ? MF Custom Tools & Equipment 19 09-14-2012 10:08 PM
Gloss Lacquer to Satin Lacquer Finish ak_aiken Painting & Finish Work 7 08-05-2009 10:34 AM
What is waterborne hardwood floor finish? hardwoodfloors Flooring 3 07-14-2009 10:03 AM
