HVLP Trim Spray Rough To The Touch. - Painting & Finish Work - Contractor Talk
Old 11-13-2014, 11:26 AM   #1
music9704's Avatar
Trade: class b contractor
Rewards Points: 591
I'm new to using a HVLP. I just sprayed some trim with a HVLP gun; some of the trim very detailed. It looks great, it tightened up to details good, looks smooth. The problem is it doesn't feel smooth, more like 2000 grit sandpaper or like a flat. Like over spray. Here's the technique used.
Acrylic latex satin.
First time. Low air pressure ( too low-45 at compressor)
Paint to thin (about 20%) Used water to thin, added floetrol.
Second time. Put a second regulator at gun, pumped up pressure (45 at inlet, gun full and open)
Thined pain 10%, used less floetrol.
The gun worked a lot better second time, but I got same results both times.
I got a smoother feel with a brush. Like I said tho, the spray looks great, but feels like a flat paint. I understand there's a lot of variables, but any ideas what I'm doing wrong? The gun is the harbor freight cheaper one. The nozzle to small? I read post from painters using it for latex.
music9704 is offline
Old 11-13-2014, 07:39 PM   #2
Accidental Painter
Driftweed's Avatar
Trade: Who's paying?
Rewards Points: 1,262
Re: HVLP Trim Spray Rough To The Touch.
Originally Posted by music9704 View Post
I'm new to using a HVLP. The gun is the harbor freight cheaper one. .
Do you always use the cheapest tools/materials you can find?
To get professional results, use professional tools. I'll almost bet your charging professional rates, aren't you?
Driftweed is offline
The Following User Says Thank You to Driftweed For This Useful Post:
pinwheel (11-14-2014)
Old 11-13-2014, 07:46 PM   #3
nickko's Avatar
Trade: remodeling-cabinet maker
Rewards Points: 765
I used a cheap harbor freight hvlp gun to spray some oil base black impervo because I didn't want to spray it through my asturo gun. It was a mdf raised panel bar front.
It came out great.
Nicko
"Quality work for those who know the difference"
nickko is offline
The Following User Says Thank You to nickko For This Useful Post:
music9704 (11-13-2014)
Old 11-13-2014, 07:52 PM   #4
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 5,803
Not enough paint on the pc. You possibly have dry spray.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 11-13-2014, 08:37 PM   #5
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 2,666
I believe the paint is drying either before as soon as it lands on the surface. I suggest either increase the amount of paint, slow down moving across the work, move gun closer to the work or all three. Thinning the paint too much may also be a problem, better quality hvlp's can spray thicker latex paint.
I found some scraps and practiced with my hvlp's to get the right settings etc to get the finish right. Good luck.
Ohio painter is offline
The Following 2 Users Say Thank You to Ohio painter For This Useful Post:
Danahy (11-22-2014), music9704 (11-13-2014)
Old 11-13-2014, 09:23 PM   #6
nickko's Avatar
Rewards Points: 765
I think those harbor freight guns only come with a 1.5 tip. That is to small to spray latex you need a 2.0 pr bigger.
Nicko
nickko is offline
Old 11-13-2014, 10:42 PM   #7
music9704's Avatar
Rewards Points: 591
First, you don't know anything about me, but your reply says a lot about you. It's not that I feel I owe you any explanation, my reply however, is in hopes you may learn something; maybe how to not be so judgemental.
The gun came in a box of tools purchased at a yardsale. Not that I'm knocking the gun. I have seen more positive reviews about the gun than bad. I've seen pictures of several custom automobiles sprayed with the HF purple guns, that looked great. I've been contracting for over 20 yrs, so I know, most times cheap tools, do cheap jobs. That was why I was surprised about the reviews and pics.
The trim work is in a house I own, so I guess I'm not really charging anyone! I don't bid paint jobs. Sometimes I paint my own contracts. (remodels, turnkey). This would not happen for a HO, because I would have tested it prior (like on my own house). If it did happen, I would fine sand and brush. I guarantee, 90% of the time I am more picky about my work than the HO.
Old 11-13-2014, 11:08 PM   #8
music9704's Avatar
Rewards Points: 591
It came out great.
Nicko
1.5 tip is to small to spray latex you need a 2.0 pr bigger.
Nicko
Leo, I may have been moving a bit fast, I tried applying a thick coat. It was night and not the best lighting, and spraying white on white. It was really hard to tell. The places I know that are are think are a bit smoother. I think dry spray as well, I thought floetrol would help take care of this? Thank you.
Ohio, the thinning could have been an issue. Also like you and Nicko said, the gun spraying latex could caused problems. I sprayed oil primer and it flowed well. The latex was harder, the tip is def to small. It keep trying to clog. I should have tested on scrap, I got in a hurry. The oil went well, so I was like heck yeah.....
Old 11-14-2014, 12:17 AM   #9
aptpupil's Avatar
Rewards Points: 1,894
When I had this problem it was rate of application. I slowed down and put it on thicker and it worked well for me. Good luck.
aptpupil is offline
The Following User Says Thank You to aptpupil For This Useful Post:
music9704 (11-14-2014)
Old 11-14-2014, 10:18 AM   #10
txgencon's Avatar
Rewards Points: 432
Sherwin-Williams opened a new store not far from me and had their grand opening a couple of Saturdays back. I stopped by to get 10 gallons of ceiling paint. They had some of their technical people there. Among then was a person whose name tag said she was a chemist. While waiting to have my paint shaken, I overhead her talking to some Hispanics about cutting latex paint. They were discussing using windshield washer fluid instead of Floetrol. Huh? What? When the others walked away, I asked, "Really?" She confirmed that the idea wasn't new to her and said to just be sure to use the 0 degree formulation of the product.
I gave it a shot (literally) and it does seem to work pretty well. The blue tint in the fluid just disappears (if you're wondering about that).
I used to think a lot of the people I encountered were stupid - then I realized how much I was overestimating them.
txgencon is offline
The Following User Says Thank You to txgencon For This Useful Post:
Old 11-14-2014, 10:54 AM   #11
music9704's Avatar
Rewards Points: 591
I just saw this on youtube a few days ago. I was like you; Really? The guy on the video really seemed like he knew what he was doing tho. I'm glad you confirmed.
Old 11-14-2014, 11:26 AM   #12
Railman's Avatar
Trade: Railing
Rewards Points: 543
Windex is mostly ammonia & alcohol, both of which are common in water based paints. They both evaporate faster than water, so it makes sense to me.
It sounds like too much air, for the volume of finish. The finish is drying before it hits the surface. Normally this happens with hot air from turbines, but not with conversion guns. Cut the air, & apply wetter.
Do you have a pressurized cup, or remote cup? With a remote cup (or pot), you can bump product pressure to help atomize, without adding too much air at the nozzle.
Railman is offline
The Following 2 Users Say Thank You to Railman For This Useful Post:
music9704 (12-04-2014), stelzerpainting (12-29-2014)
Old 11-14-2014, 12:18 PM   #13
txgencon's Avatar
Rewards Points: 432
I didn't tell the whole conversation as I was just nuking some coffee in the trailer earlier. Turns out the chemist's name was Chemise (wasn't wearing my glasses) and she was in management (not a chemist). She did seem to know her stuff, though. She explained that the guys to whom she was talking all worked for a big local painter with about 20 crews (name is Hernandez, I think) and he had been using it for years. She said there were a lot of theories about how the practice started. Some think guys confused it with pump saver, some say a painter didn't have water available and he needed to thin his paint and washer fluid was all he had. She also stated that he (Hernandez?) had never had a paint failure claim they could attribute to the fluid. She also said he makes his guys have the store open every can of paint so they can smell it before they will take it out of the store. They do reject some based on the smell. She said she has heard of people using every imaginable fluid to thin water base paints, including Sprite, beer and urine.
txgencon is offline
music9704 (11-15-2014)
Old 11-14-2014, 06:55 PM   #14
rrk's Avatar
Rewards Points: 954
That HF gun is actually not a bad gun at all.
rrk is online now
Old 11-14-2014, 07:01 PM   #15
txgencon's Avatar
Rewards Points: 432
If you're talking about the gravity feed gun, agree. I used it for spraying pigmented shellac primer. Not sure I would use it for latex, though. I have used a HF HVLP pressure feed rig to spray latex. Wouldn't do it again.
txgencon is offline
Old 11-14-2014, 09:46 PM   #16
Accidental Painter
Driftweed's Avatar
You have been doing this 20 years, I have only been doing it 2. You use the garage sale special, I use a titan turbine powered HVLP. why would that be? Because even I realized you cant make a pinto a porsche. If your going to use bottom of the barrel tools, don't expect to get world class results
Will the harbor freight do what you want? sure with a tremendous amount of trial and error, but even then it may not perform the same way twice in a row. You could very well have it dialed in on this use but the next time you use it, you will have to start again. THAT was the point I was trying to drive across. Not necessarily a personal attack on you, but merely pointing out that you are chasing a pipe dream.
Let's say, for example, you do dial it in with a specific formula of air to material ratio and write it all down and feel confident about going to do actual work with it and IT FAILS MISERABLY. Now you are stuck on a job, and losing time and money quickly. Do you repeat the same mistake and buy another cheapo tool and cross your finger? Or will you have to take a massive loss and buy LEGITIMATE equipment and relearn how to use it?
Would you seriously show up to brush a house with a chip brush? Same thing here when spraying paint.
I hated spending over $1000 on my HVLP (at first) but am VERY thankful I did now that I use it more often.
Old 11-15-2014, 02:11 PM   #17
music9704's Avatar
Rewards Points: 591
You havline en doing this 20 years, I have only been doing it 2. You use the garage sale special, I use a titan turbine powered HVLP. why would that be? Because even I realized you cant make a pinto a porsche. If your going to use bottom of the barrel tools, don't expect to get world class results
I am NOT a paint contractor. 2yrs; I have probably lost more money in tools than you have spent at this point. I guess I could have used the craco airless (I have never used) or the other airless (I don't remember the name of) I just bought the second one because I was in a pinch on a job, I think it was about $400. They were at the other house. The plan was to brush, and spray the fireplaces. I found the hvlp at the project house shed so........I actually hadn't decided if I was going to spray the FP myself. I'm not a painter or paint contractor. I am a decent painter (better than a HO but not a pro). If it's something I feel I can't do, I sub out. IE. Gloss doors, most jobs that will be sprayed....I will paint some of my own contracts, not all. I understand what you are saying, but I have no intent on buying a 1000 sprayer, cause painting is not my gig. I don't have a problem spending money on tools.
Old 11-15-2014, 02:28 PM   #18
music9704's Avatar
Rewards Points: 591
Yes I agree, not that I'm a true painter... It's not a bad gun, used for the right thing. I don't think it was ment for latex. The job looks great, if no one touches it.lol I will be moving in this house, so.... My wife threatened me if I repaint. I've been on this way to long as is. She said I was OCD about perfection. I'll probably repaint at the same time I paint the next two rooms. Maybe she'll not notice.
Old 11-24-2014, 07:42 PM   #19
Finish Carpenter
TBFGhost's Avatar
Trade: Finish Carpentry, Reno
Rewards Points: 2,760
Its not bad, I used them for years, but when I switched to a Devilbiss Finishline 4, the difference was night and day. I won't go back. Faster fluid delivery, better atomization, lower over spray, better part availability, this list goes on. I want to get a Techna next.
PLC Custom Interiors and Woodworking
Lebanon, NJ (908)246-3797
https://www.facebook.com/PunchlistCarpentry?ref=hl
TBFGhost is offline
The Following User Says Thank You to TBFGhost For This Useful Post:
Old 11-24-2014, 09:40 PM   #20
CarpenterSFO's Avatar
Rewards Points: 2,044
Several threads mention floetrol. I never use it when spraying. I don't think that a properly sprayed finish needs it.
- Bob
CarpenterSFO is offline
The Following User Says Thank You to CarpenterSFO For This Useful Post:
Ben Moore Aura as a trim paint?? Dorman Painting Painting & Finish Work 10 03-19-2013 09:35 AM
Looking for a fresh idea to trim out entry door AustinDB Finish Carpentry 17 02-01-2013 03:12 AM
Spray trim in empty duplex... jkohio Painting & Finish Work 7 10-14-2010 12:28 AM
Trim detail sans fascia crovello Carpentry 19 10-28-2009 08:01 PM
Proposals...... AAPaint Painting & Finish Work 3 08-25-2007 08:47 AM
