HVLP Or Airless - Painting & Finish Work - Contractor Talk
HVLP Or Airless
Old 09-05-2018, 08:39 AM   #1
rblakes1's Avatar
Rewards Points: 4,252
HVLP Or Airless
Hey guys,
I was hoping you could share thoughts/ experiences on the two options. I've never sprayed before, but I'd like to get into it. I have access to a Graco FinishPro 7, or if I went airless I'd probably go with the Graco UltraMax.
My main uses would be trim/ built ins. In the past, it was always just let the painters brush and roll, but I'd like to get into the higher quality finishes.
If anyone has any suggestions on where to read up/ videos to watch, I'd appreciate that, too.
Thanks!
Rich
rblakes1 is offline
Old 09-05-2018, 06:29 PM   #2
Idothat's Avatar
Trade: Home improvement of all types
Rewards Points: 1,220
Re: HVLP Or Airless
An airless is more versatile
If all you were doing was cabinets or built ins the hvlp can give a better Finish and more control ,but it is much slower on large areas
Airless sprayers are all about tip selection and pressure settings
The hvlp guns typically have adjustable fan settings and produce a finer mist
Airless sprayers you must change tips to adjust the fan
Hvlp is more sensitive to paint viscosity, you have to thin a lot of paints
to use them
Airless sprayers will usually spray without thinning
If the smoothest finish is the goal hvlp is the way to go
However, airless sprayers can produce fine finishes with the right tips
Idothat is offline
The Following User Says Thank You to Idothat For This Useful Post:
MarkJames (09-05-2018)
Old 09-05-2018, 08:11 PM   #3
Can I get an Amen?
Aaron Berk's Avatar
Trade: Custom Woodworks
Rewards Points: 1,060
Re: HVLP Or Airless
I use HVLP for almost all my painting.
I've got a 4900 graco pro cart.
If I did it all over again, I might get an Airless Air Assisted.
But I REALLY love my HVLP
Aaron Berk is offline
Old 09-05-2018, 08:14 PM   #4
Caslon's Avatar
Trade: State Licensed Painting Contractor
Rewards Points: 1,368
Re: HVLP Or Airless
Thanks!
Rich
YouTube? They gotta a whole lot of ways and means there.
Caslon is offline
Old 09-05-2018, 08:19 PM   #5
Can I get an Amen?
Aaron Berk's Avatar
Re: HVLP Or Airless
Most recent use of my HVLP
SW all surface enamel (oil) un thinned
On an exterior garden gate
Other picture is Sherwood lacquer on a replacement cabinet box
The Following 2 Users Say Thank You to Aaron Berk For This Useful Post:
asevereid (09-06-2018), rblakes1 (09-05-2018)
Old 09-05-2018, 08:29 PM   #6
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 56
Re: HVLP Or Airless
Why limit yourself to just one finishing option? We've got airless, air assist airless, several gravity feed hvlp & a graco ultramax. All have different applications depending on finish & results we're trying to acheive.
What finish are you wanting to spray cabinets with? Latex, or lacquer base?
pinwheel is online now
The Following User Says Thank You to pinwheel For This Useful Post:
overanalyze (09-07-2018)
Old 09-05-2018, 08:29 PM   #7
Idothat's Avatar
Re: HVLP Or Airless
The main tip I can give for spraying is lots of light.
When spraying you need to look more at the sheen of the surface that you are spraying ,and not the color
A glancing light that lets you see the texture of the paint as it is applied will give better results
Always test on something other than your work piece
Practice practice practice
Idothat is offline
The Following 2 Users Say Thank You to Idothat For This Useful Post:
Old 09-05-2018, 08:35 PM   #8
Idothat's Avatar
Re: HVLP Or Airless
A very good point . The materials used often dictate the equipment
Idothat is offline
Old 09-05-2018, 08:44 PM   #9
tjbnwi's Avatar
Rewards Points: 422
Re: HVLP Or Airless
The Graco GX-19 is probably the best choice for what you describe without getting into multiple systems to start.
I’m in the same boat as Pin, I have just about every spray option available to me.
tjbnwi is online now
overanalyze (09-07-2018), pinwheel (09-05-2018)
Old 09-05-2018, 08:51 PM   #10
rblakes1's Avatar
Re: HVLP Or Airless
And I'm guessing most of them are wrong! Lol
rblakes1 is offline
Old 09-05-2018, 08:58 PM   #11
rblakes1's Avatar
Re: HVLP Or Airless
I'm not opposed to eventually getting more than one system, but for just starting out I wasn't sure if one would be better than the other.
Finishes is another thing for me to learn about. I'd probably lean towards latex to start until I can get enough practice with lacquer based
rblakes1 is offline
Old 09-05-2018, 09:00 PM   #12
Idothat's Avatar
Re: HVLP Or Airless
Really ,to be honest, you don't need to spend a lot of money if , you don't want to.
I've got a cheap HF gravity feed that I've sprayed everything from cars to cabinets with , and only spent about $25 on it
Idothat is offline
Old 09-05-2018, 09:02 PM   #13
rblakes1's Avatar
Re: HVLP Or Airless
I learned a while ago that direct light doesn't show nearly as much as indirect light and shadows do 👍
Which ever option I go with, I plan on practicing a lot with projects around my house
rblakes1 is offline
Old 09-05-2018, 09:04 PM   #14
Idothat's Avatar
Re: HVLP Or Airless
Lacquer is actually very forgiving , it dries fast, and sands well
Idothat is offline
pinwheel (09-05-2018), rblakes1 (09-05-2018)
Old 09-05-2018, 09:11 PM   #15
rblakes1's Avatar
Re: HVLP Or Airless
Good to know.
One thing I want to avoid in regards to built ins is the inevitable scraping off of paint as they are used. As I mentioned, in the past I would build them then the painters would come in and brush/ roll, and the finish on the shelves and occasional counter would never hold up well.
rblakes1 is offline
Old 09-05-2018, 09:16 PM   #16
pinwheel's Avatar
Rewards Points: 56
Re: HVLP Or Airless
If you're spraying small projects, cabinets, doors, builtins, ect & not full rooms & large areas, I'd probably steer you towards the Graco ultramax if you're starting with latex. The Low pressure FF tips do a really nice job of laying a smooth finish.
If you're going to start playing with lacquers, here's a nice set of gravity feed hvlp guns that won't break the bank. We've got 4 of these guns that we spray everything from stains, to clear lacquer to to tinted lacquers (paint) to poly
https://www.amazon.com/DeVilbiss-802.../dp/B000KSTFJO
Old 09-05-2018, 09:45 PM   #17
tjbnwi's Avatar
Rewards Points: 422
Re: HVLP Or Airless
If there is a PPG dealer near you give Breakthrough a shot
There are SW products Iíd recommend but donít want to put you through dealing with a products finishes store....
Old 09-05-2018, 09:49 PM   #18
Idothat's Avatar
Re: HVLP Or Airless
If you go with an air gun , good water filters are a must
Idothat is offline
Old 09-05-2018, 11:01 PM   #19
rblakes1's Avatar
Re: HVLP Or Airless
Looks like either option is a bit of a drive, closest stand alone ppg is in philly and sw product finishes is about an hour and a half. Plenty of standard SW stores around though.
I did grab the wall and wood primer based off your recommendations though
rblakes1 is offline
Old 09-05-2018, 11:11 PM   #20
rblakes1's Avatar
Re: HVLP Or Airless
This is the graco hvlp I have access to. Not sure if it's the 7, 9, or 9.5. I might see if I can grab it tomorrow to test it out
rblakes1 is offline
hvlp vs. airless for spraying trim Traditions Painting & Finish Work 14 05-26-2017 12:58 PM
HVLP or airless for fine furniture clear finish Klantaff General Discussion 19 04-23-2017 08:55 AM
Spraying Benjamin Moore Advance with HVLP Rustbucket Painting & Finish Work 20 12-02-2016 08:05 AM
Graco HVLP 4900, used but NEW to me Aaron Berk Painting & Finish Work 7 01-21-2013 09:38 AM
Airless vs hvlp for cabinets? MakeItHappen Painting & Finish Work 6 04-21-2010 10:58 PM
