How Would You Tackle This? - Painting & Finish Work - Contractor Talk
Old 05-11-2019, 06:59 PM   #1
30 year novice
carzie's Avatar
Trade: Painting contractor
Rewards Points: 2,653
Customer wants siding and windows painted all around but this is really the only concern. This is spring run off so water levels will drop through the summer but there will always be water(approx 6"or there abouts) by the foundation. I've thought about scaffolding but I would need 5 levels to reach the top, a floating dock that is anchored to the bottom, and of course a boom but I'm not positive I can get something that will articulate around the side enough. Jet pack?
carzie is offline
Old 05-11-2019, 07:56 PM   #2
Adamthebuilder's Avatar
Trade: Builder
Rewards Points: 232
Re: How Would You Tackle This?
Can you cantilever off the rear deck, and set a pump jack on top? Is there an old pontoon boast nearby?
Adamthebuilder is offline
The Following User Says Thank You to Adamthebuilder For This Useful Post:
carzie (05-12-2019)
Old 05-11-2019, 08:35 PM   #3
VinylHanger's Avatar
Rewards Points: 10,610
Pump jacks on a block on the riverbed.
VinylHanger is offline
The Following 2 Users Say Thank You to VinylHanger For This Useful Post:
carzie (05-12-2019), mrcat (05-12-2019)
Old 05-11-2019, 09:00 PM   #4
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 4,732
Depending on how firm the soil bed is - when the water level drops down to only 6" in summer, not now of course - I've gotten away with setting an extension off the rear bed of what used to be my pickup. The base of the ladder won't go anywhere when set on the inside corner. As long as 4 wheeler won't sink. You could use the ladder as the right half of a pick setup to cross over the trees, and ladder the right half independently .
Actually one position on the right side looks it would do it...
If you have to bring in a load of crushed gravel, add to cost.
I'm surprised that foundation isn't being undermined.
artinall is offline
The Following User Says Thank You to artinall For This Useful Post:
carzie (05-12-2019)
Old 05-11-2019, 09:00 PM   #5
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 2,794
What's the rush? can it wait?
Ohio painter is offline
The Following User Says Thank You to Ohio painter For This Useful Post:
carzie (05-12-2019)
Old 05-11-2019, 09:22 PM   #6
WBailey1041's Avatar
Trade: Gutters
Rewards Points: 1,581
6 inches only? Trash pump to remove the water and some cheap used pallets and plywood to get out of the mud.
WBailey1041 is offline
The Following User Says Thank You to WBailey1041 For This Useful Post:
carzie (05-12-2019)
Old 05-11-2019, 09:58 PM   #7
TheConstruct's Avatar
Rewards Points: 1,056
A real life moat, neat. I agree with pump jacks if the soil isnt too mucky.
TheConstruct is offline
The Following User Says Thank You to TheConstruct For This Useful Post:
carzie (05-12-2019)
Old 05-11-2019, 10:56 PM   #8
Ed Hartmann's Avatar
Rewards Points: 240
I would go for a tall lift. Obviously the hight will go for outreach not hight. Either that or sandbag the area and get it dried out when it is naturally low and work like normal.
Ed Hartmann is offline
The Following 2 Users Say Thank You to Ed Hartmann For This Useful Post:
Calidecks (05-12-2019), carzie (05-12-2019)
Old 05-12-2019, 07:54 AM   #9
30 year novice
carzie's Avatar
I'm liking the idea of the pump jacks, it's hard to see what the river bed is like at this point but it's a very rocky area (Canadian shield). If you look close there is a small bridge to the left that is over part of the river so there is a constant flow coming in right at the foundation so sand bagging and pumping will not work. Yes it can wait, I'm looking at late August-September when the water should be at lowest point. It's an old grist mill. Here's a pic from the front.
carzie is offline
The Following 2 Users Say Thank You to carzie For This Useful Post:
hdavis (05-12-2019), Ohio painter (05-12-2019)
Old 05-12-2019, 08:25 AM   #10
hdavis's Avatar
Rewards Points: 3,868
I'd be a little leery about pump Jack's if you can't pound in rebar and tie off to it to make sure the base can't move too much.
hdavis is online now
artinall (05-14-2019), carzie (05-12-2019)
Old 05-13-2019, 08:30 PM   #11
Joseph A. Capece
CENTERLINE MV's Avatar
Trade: Builder - General
Rewards Points: 1,432
Wall brackets through the rim joist, aluminum picks, then stage off that. Patch when finished (should be able to do it hanging out of the window or a boat lol....)
Follow us on FACEBOOK
www.centerlinebuilders.net
Martha's Vineyard General Contractors - Builders -
Commercial/Residential - Additions - Renovations
CENTERLINE MV is offline
Old 05-14-2019, 03:07 PM   #12
artinall's Avatar
Another suggestion of winching down a harness off the roof - looks sort of risky. Though used to know an old union painter that would do it all the time.
That pitch could present somewhat of an obstacle.
artinall is offline
How to tackle this finishing timeframe? Ramen Drywall 19 09-15-2017 07:02 PM
Rigging Block And Tackle Joe Wood Tools & Equipment 6 03-02-2017 12:22 AM
Afraid to tackle a deck stain job... bakertime Painting & Finish Work 11 10-13-2013 03:36 AM
block and tackle balance system davinci Windows, Siding and Doors 5 01-17-2011 02:43 PM
The Government plans to tackle false self-employment within the construction industry DanbroConstruct Business 40 08-20-2009 08:45 AM
