How Long Before I Can Paint New 'old School Plaster' - Painting & Finish Work - Contractor Talk
Old 08-04-2010, 08:54 PM   #1
President
CarrPainting's Avatar
Trade: Residential Repaints
Rewards Points: 1,316
Question
I have to do a patch in a very small bathroom. They explicitly asked for real plaster... I can do the work, no problem. My question is however, how long do I have to wait before I can safely paint it?
I am using rocklath base coat and then top coating it with lime and plaster of paris... how long should I let it 'dry' for?
Also, no one can explain this to me, why cant you paint latex directly over fresh old school plaster? why must it be oil?
CarrPainting is offline
Old 08-05-2010, 03:49 PM   #2
Rewards Points: 2,000
Re: How Long Before I Can Paint New 'old School Plaster'
In the olden days,
it was a week.
neolitic is offline
Old 08-05-2010, 04:39 PM   #3
Workaholic's Avatar
Trade: Painting Contractor
I would say a week or two.
Sean
Workaholic is offline
Old 08-05-2010, 04:57 PM   #4
D & S Painting's Avatar
We're doing a 200 yr old farm house right now and they just had all the old ceiling torn out and new plaster ones installed. You should wait at least 2 weeks for the plaster to "cure", the oil primer prevents alkaline in the plaster from bleeding through. I used S/W Low odor multi purpose oil primer and you can re-coat in 2 hours with a latex finish.
D & S Painting is offline
Old 08-05-2010, 05:23 PM   #5
Licensed, Bonded & Insur
ewingpainting's Avatar
Rewards Points: 264
Some paint vendors have flat products that can paint over in 24hrs. Frazee paints and Dunn Edwards have those product. I think SW might too.
You can also use a patching compound called rapid set. Its considered a plaster too without the alkaline and has added dryers. It also has terific adhesion. You can paint over that within 6hrs.
Riverside County Painters
ewingpainting is offline
Old 08-05-2010, 06:46 PM   #6
Maxi-Pier Tech
essrmo's Avatar
Trade: foundation specialist
Rewards Points: 810
28 days to reach full compressive strength.
since they are both water base,
you can paint it after 24 hours
we're not in Kansas anymore Toto
essrmo is offline
Old 08-10-2010, 12:59 AM   #7
radhika's Avatar
Trade: http://www.chevytruckforsaleinusa.com/
It simply depends on the type you are using for it and the time is decided onto it may be 10 days,,,
radhika is offline
Paint or stain on hardi plank? Jer Painting & Finish Work 28 02-17-2017 08:29 PM
Paint or stick with solid color stain? JL1 Painting & Finish Work 46 01-16-2014 06:58 AM
Paint Shaver vs Infrared Paint Removers Goochie Painting & Finish Work 12 09-11-2012 04:05 PM
Venetian Plaster Glossary Plaster Ayn Faux Finishes 3 04-27-2011 08:46 AM
here's a painting price list...... Jer44 General Discussion 9 02-17-2009 08:30 AM
