Help With Polyurethane - Page 2 - Painting & Finish Work - Contractor Talk
Old 05-25-2015, 09:39 AM   #21
Railman's Avatar
Trade: Railing
Rewards Points: 1,053
Re: Help With Polyurethane
You need heat, & air movement.
Best solution would be to put the stock in a make shift oven. You could use a cardboard box, or anything big enough to hold the stock. Then use a small electric heater, or brooder lamp, but be careful of temps as as not to start a fire!
My boys have used a small bathroom with a small heater for similar type projects during winter months to get poly to cure out. 70deg is borderline for poly, especially if the humidity is high.
Railman is online now
The Following 2 Users Say Thank You to Railman For This Useful Post:
Metro M & L (05-25-2015), pinwheel (05-28-2015)
Old 05-27-2015, 11:33 PM   #22
Gen. Contractor
Ninjaframer's Avatar
Trade: Residential Light commercial
Rewards Points: 2,610
Originally Posted by Robie View Post
Maybe the humidity is the problem.
What I would do.....
Let it cure....for however long it takes.
Use some #0000 steel wool to get it back to baby-butt smooth.
Buy a can of whatever sheen you want polyurethane...a pint will be too much.
Mix a batch of 50% poly and 50% naphtha in a clean container and get a rag of old t-shirt "dog's nose wet" and apply it to the stock....be fast and don't worry much about what you missed.
Let it dry 2-3 hours...do it again...let it dry....do it again. A gun stock should take you no more than 30 seconds to apply. Use a fresh rag each time as the old one will get stiff.
After the 3rd coat, scuff with #0000 steel wool and repeat all 3 coats. After 6 coats total, you may want to call it a day, but the more you apply, with scuffing on the 3rd coat...the deeper and better the finish will be.
Let your final finish cure for a week or so. If you can't smell it...it's cured.
Apply a good paste wax, again with #0000 steel wool.
Next...show off your finishing skills. It will be a great looking, hand-rubbed looking finish. Guaranteed.
Worked fantastic- thanks!
"slow makes smooth, smooth makes fast"
Ninjaframer is offline
The Following User Says Thank You to Ninjaframer For This Useful Post:
Robie (05-28-2015)
Old 05-28-2015, 06:22 AM   #23
Radical Basement Dweller
Robie's Avatar
Rewards Points: 662
Looks nice.
How many coats did you end up with?
“Now is no time to think of what you do not have.
Think of what you can do with what there is”
― Ernest Hemingway, The Old Man and the Sea
Robie is online now
Old 05-28-2015, 09:22 AM   #24
Gen. Contractor
10 or so
slab jacking with polyurethane foam AustinDB Concrete & Paving 3 02-12-2015 09:46 AM
4 hour old blue tape pulling polyurethane off of 5 day old refinished hardwood Ethos Flooring 43 08-17-2014 10:51 AM
Polyurethane Crown Molding dreamzdecora Finish Carpentry 4 09-24-2013 07:03 PM
Problems with Polyurethane over Sanding Sealer Luke S. Painting & Finish Work 16 09-18-2013 08:00 PM
Polyurethane to shiny Hometown Painting & Finish Work 13 12-17-2008 08:35 PM
