Help With Polyurethane - Painting & Finish Work - Contractor Talk
Old 05-24-2015, 06:13 PM   #1
Gen. Contractor
Ninjaframer's Avatar
Trade: Residential Light commercial
Rewards Points: 2,610
So I'm refinishing a gun stock and this poly in a can won't dry- I've put 3 light Coates (I thought they were light) and then lightly sanded and put another coat. It's a day later and it's rough and not tacky but for sure not dry. The can said wait 4 hrs between Coates and dry hard in 8. What am I doing wrong and what should I do?
Thanks
"slow makes smooth, smooth makes fast"
Ninjaframer is offline
Old 05-24-2015, 06:14 PM   #2
Gen. Contractor
Re: Help With Polyurethane
Old 05-24-2015, 06:22 PM   #3
Fire up the BBQ
griz's Avatar
Rewards Points: 376
Maybe it old.
Conditions when you sprayed it?
griz is online now
Old 05-24-2015, 06:25 PM   #4
Gen. Contractor
In my garage- it's been between 60-70 degrees. I just bought the can- doesn't have a date on it.
Old 05-24-2015, 06:26 PM   #5
Gen. Contractor
I almost took the stock to the guy I'm building an auto body shop for and had him spray it in clear coat. I wish I would have
Old 05-24-2015, 07:40 PM   #6
Renaissance Man
superseal's Avatar
Rewards Points: 5,836
Originally Posted by Ninjaframer View Post
Hey, that bike doesn't have a backrest... that's a safety issue.
Might have to call Oh**** on that one
supersealconstruction.com
superseal is offline
The Following User Says Thank You to superseal For This Useful Post:
Ninjaframer (05-24-2015)
Old 05-24-2015, 07:51 PM   #7
Gen. Contractor
My wife complains about not having a sissy bar the 2 times a year I talk her into going with me for a ride lol
The Following User Says Thank You to Ninjaframer For This Useful Post:
superseal (05-24-2015)
Old 05-24-2015, 08:32 PM   #8
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 94
My first thought was old as well, but I don't think that's it. Next thought would be too cool. Poly doesn't dry well in cold temps. But I would think 60-70 would be warm enough. Put it in front of a fan & see if it doesn't dry.
pinwheel is offline
Old 05-24-2015, 08:34 PM   #9
Fire up the BBQ
griz's Avatar
Rewards Points: 376
Take that finish in a can off and take the stock to your cabinet guy.
Now if you want to add some color & clear coat go to the body shop guy.
griz is online now
Old 05-24-2015, 08:44 PM   #10
Gen. Contractor
That's not what I want to hear - lol
I spent 6 hrs sanding the old finish off I thought about the cabinet guy first but lacquer isn't very durable and doesn't touch up at all. Isn't that all they put on cabinets is lacquer?
Old 05-24-2015, 08:48 PM   #11
Fire up the BBQ
griz's Avatar
Rewards Points: 376
If it is a working gun go with a hand rubbed oil finish.
Trophy rifle, doll it up and put it in the safe to show off.
Think about going synthetic if it is a working gun.
griz is online now
Old 05-24-2015, 08:53 PM   #12
Gen. Contractor
Ya it's not a trophy- it's a 70's Winchester model 70 (push feed) that I picked up from a kid for $400. It was dinged up pretty good so I thought I'd re-finish it. If it's not perfect I won't cry.
These are the safe queensHelp with polyurethane-imageuploadedbycontractortalk1432518738.260557.jpg
These are the working guns
Calidecks (05-28-2015)
Old 05-24-2015, 08:55 PM   #13
pinwheel's Avatar
Rewards Points: 94
The best thing for rifles is Tru oil. Easy to apply & easy to touchup.
http://www.brownells.com/gunsmith-to...-prod4952.aspx
pinwheel is offline
The Following User Says Thank You to pinwheel For This Useful Post:
Old 05-24-2015, 09:06 PM   #14
Fire up the BBQ
griz's Avatar
Rewards Points: 376
These are the safe queensAttachment 185594
Attachment 185602
Model 70, outstanding weapon....
Oil finish that bad boy, glass bed it, build a hand load for it & you have yourself a rifleman's rifle.
griz is online now
Old 05-24-2015, 09:52 PM   #15
Gen. Contractor
Limited edition (500 made) model 70 in 257 Roberts- controlled round feed. Glass bedded, trigger job and custom load developed by Professional Ballistics inc. topped with Swarovski 3-9
My baby
Original floor plate, I took it off and replaced it with a plain one (to flashy for me)
griz (05-25-2015)
Old 05-24-2015, 09:55 PM   #16
Fire up the BBQ
griz's Avatar
Rewards Points: 376
and you are trying to spray poly that baby.....
griz is online now
Old 05-24-2015, 09:57 PM   #17
Gen. Contractor
Different model 70
Re finish is a 7mm mag
I was just showing off with the 257 bob
Old 05-24-2015, 11:05 PM   #18
Radical Basement Dweller
Robie's Avatar
Rewards Points: 5,552
Maybe the humidity is the problem.
What I would do.....
Let it cure....for however long it takes.
Use some #0000 steel wool to get it back to baby-butt smooth.
Buy a can of whatever sheen you want polyurethane...a pint will be too much.
Mix a batch of 50% poly and 50% naphtha in a clean container and get a rag of old t-shirt "dog's nose wet" and apply it to the stock....be fast and don't worry much about what you missed.
Let it dry 2-3 hours...do it again...let it dry....do it again. A gun stock should take you no more than 30 seconds to apply. Use a fresh rag each time as the old one will get stiff.
After the 3rd coat, scuff with #0000 steel wool and repeat all 3 coats. After 6 coats total, you may want to call it a day, but the more you apply, with scuffing on the 3rd coat...the deeper and better the finish will be.
Let your final finish cure for a week or so. If you can't smell it...it's cured.
Apply a good paste wax, again with #0000 steel wool.
Next...show off your finishing skills. It will be a great looking, hand-rubbed looking finish. Guaranteed.
If you tell the truth, you don't have to remember anything.
Mark Twain
Robie is online now
The Following 3 Users Say Thank You to Robie For This Useful Post:
B.D.R. (05-25-2015), Metro M & L (05-25-2015), Ninjaframer (05-25-2015)
Old 05-25-2015, 09:17 AM   #19
hdavis's Avatar
Rewards Points: 1,554
Ninja, the spray poly can and does wind up soft or gummy. I've never figured out why - possibly humidity, possibly solvent in the wood, but I think it's actually the product. It will harden up after a couple months.
You're better off, IMO, using a brush on urethane, but thin it at least 4 oz per quart. Thinner than that can be better, and the first coat is a very thin sealer coat. You generally don't want much build, but you still have to put on a few coats for a decent finish. Checkering gets a sealer coat , and any excess is blotted off. You can't put much finish on checkering without it losing the crispness.
hdavis is online now
Old 05-25-2015, 09:34 AM   #20
hdavis's Avatar
This looks like a correct finishing schedule.
I sometimes apply with 0000 steel wool and wipe off, but that's a lot of coats to get much final finish, and it's very technique sensitive and you have to move very fast.
slab jacking with polyurethane foam AustinDB Concrete & Paving 3 02-12-2015 09:46 AM
4 hour old blue tape pulling polyurethane off of 5 day old refinished hardwood Ethos Flooring 43 08-17-2014 10:51 AM
Polyurethane Crown Molding dreamzdecora Finish Carpentry 4 09-24-2013 07:03 PM
Problems with Polyurethane over Sanding Sealer Luke S. Painting & Finish Work 16 09-18-2013 08:00 PM
Polyurethane to shiny Hometown Painting & Finish Work 13 12-17-2008 08:35 PM
