Help Matching Cabinet Finish/Stain? - Page 2 - Painting & Finish Work - Contractor Talk
Old 07-24-2017, 08:08 PM   #21
MTN REMODEL LLC's Avatar
Trade: Remodel and new build Colorado @ 7651 FT
Rewards Points: 1,428
Re: Help Matching Cabinet Finish/Stain?
Originally Posted by tjbnwi View Post
How close do you think this is?
Hard to tell in the photos, but it does have a pink undertone.
Stain is the last thing you want to use to achieve the color you want.
TOM/ TJB.... Thanks......
I think your second picture sure looks pretty much dead on..... can ya tell me the recipe and application technique.
Peter
Never stop learning (xcep fer speling en typeing)
MTN REMODEL LLC is offline
Old 07-24-2017, 08:10 PM   #22
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 834
So what are you using to achieve the white?
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is offline
Old 07-24-2017, 08:11 PM   #23
Originally Posted by hdavis View Post
Just to come back to it, this was almost 100% sprayed, so it would be a tinted product sprayed on.
HD..... Would a pickling have been dusted on followed by a clear finish.... or do you think a tinted "clear" finish was sprayed.
TIA
Old 07-24-2017, 08:16 PM   #24
Originally Posted by Railman View Post
After you get the general tone right, you will probably have to amber tone it to kill the brightness of a pickle finish. The original finish probably had a slight pink cast to it, that over time diminishes. Reds fade fast.
I would start with the white pickle, & add a little light brown pigment stain to help with the aging effect. Just buy the pickle, & add others to adjust/match.
Originally Posted by rrk View Post
Always sprayed on very popular a while ago, many many suppliers carried them. Any of the door manufacturers can match it, the pinkness turn a little yellow with the sun
Rail and RRK..... You're right.... in a certain light, I detect a hint of pink... not that I like that, but that is what I have to match/mimic... and I see a amber yellow quite a lot.
Thanks....
Old 07-24-2017, 08:19 PM   #25
Yes...That sounds like my stuff.... Really popular around here in the 90's... but I've been to SW/BM and alot of cab/MW shops.... and just have not found anybody that can tell me.
Thanks...
Peter
Old 07-24-2017, 08:32 PM   #26
tjbnwi's Avatar
Rewards Points: 208
Primer, either SW MP or SW W&W depending on how much titanium white I want. As you pointed out some boards are much more red, so I mix a touch of BAC green in a few ounces of primer for those boards. Spray bottle with water and a wet chip brush to "work" the blend.
Wet brush, dip in primer work in, us water bottle to "adjust" the primer viscosity on the wood.
This is the only way I've found that I can get things to match existing and get a good blend.
And a lot of practice....
tjbnwi is offline
MTN REMODEL LLC (07-24-2017)
Old 07-24-2017, 08:32 PM   #27
LEO....
To date, I've used pickling (or white wash..can't remember) by Minwax, and by Old Masters, and some pickling from BM, a custom mixed stain from SW, with and without a sanding sealer, and finished off with clear semi Minwax poly and/or Minwax water poly (I forget their name for it).
I've tried a semi-transparent tinted Olympic deck stain... that actually has come the closest with a oil poly top coat.
I'm brushing and no longer have my sprayer.
I'm currently (in the garage drying now) trying the Olympic water stain mixed/tinting the Minwax water poly.
I don't have any oil base tints here to try anything else.
Basically, the pickling are coming out too white (even after two oil poly coats) and too definitive in the grain....
These cabinets almost appear to have been fogged in a white tint finish, rather than stained.
Thanks
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
BlueRidgeGreen (07-24-2017)
Old 07-24-2017, 08:39 PM   #28
tjbnwi's Avatar
Rewards Points: 208
Try the primer, keep the brush water wet. Be patient, you may not think it's white enough. What until it dries to make the determination. You can always add more color.
Get a 2 ounce bottle of green dye so you can mix a little bit in primer to kill any red boards.
tjbnwi is offline
Old 07-24-2017, 08:54 PM   #29
Wet brush, dip in primer work in, us water bottle to "adjust" the primer thickness on the wood.
Tom.... Thanks again.... but a few comments and mostly questions....
I'm in a small town/ 80 miles to Vegas/ but I do have a SW here.
Just went out in garage and grabbed the $15 quart of krap he mixed for me my first try (Wood Classics Oil Pickled White that he tinted orange... even gave him existing door and oak to test on).
But with your advice, I'll go back... but I want to know what I'm talking about with them (as i doubt they'll know).
Is MP their all purpose primer (think I've used it before)... what is WW and which is more titanium and which is less.... I think I want less white.
And BAC is their oil pigments aren't they.... are they ok in latex...???
Did you brush/wipe that second pic and finish off with a oil or water poly...?
Tia
Peter
(PS: I just x-posted and saw your recent comment....thanks...but still haavethe couple of above questions.
Old 07-24-2017, 09:01 PM   #30
MarkJames's Avatar
Rewards Points: 94
How many cabs do you need, anyway? Would a complementary finish work, like if you're adding an island, etc?
MarkJames is offline
Old 07-24-2017, 09:30 PM   #31
tjbnwi's Avatar
Rewards Points: 208
MP is multi purpose. It is a brighter white. W&W is Wall and Wood, slightly duller. The white's will be brighter, not deeper.
See if they'll give you a shot of Color Cast green tint. The colorants are very concentrated.
Brush blended, all of my topcoats are waterborne.
That cabinet is sprayed KA+ BRE (bright rubbed effect)
tjbnwi is offline
Old 07-25-2017, 05:33 AM   #32
bywater's Avatar
Trade: Country Contractor
Rewards Points: 38
Would a water base dye in water base poly get your pinkish top coat? The dye would have to be ordered, I'ts not common in hardware stores.
Trial and error is the only way to match a finish.
bywater is offline
Old 07-25-2017, 07:04 AM   #33
LRG WoodCrafting
Leo G's Avatar
Rewards Points: 834
No such thing as a white dye.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is offline
Old 07-25-2017, 08:40 AM   #34
Railman's Avatar
Trade: Railing
Rewards Points: 1,235
We don't do any whites these days, but.....
White pickle uses a white pigment. We sometimes just used a little white primer, as per our supplier George Cash's advice. For the pinkish cast, Leo may be right on fresh red oak. The red will come from the oak. Our mixes went onto poplar to mimic the look of a pickle maple, & oak. If you do add red, it only takes maybe a 1/2 ounce red stain per qt. to get effect.
We always had to do a final wipe to raise the white up on pickle finishes, regardless of application technique. It was the only way to keep it consistent.
Railman is offline
The Following User Says Thank You to Railman For This Useful Post:
MTN REMODEL LLC (07-25-2017)
Old 07-25-2017, 10:17 AM   #35
Texas Wax's Avatar
Rewards Points: 2,286
Originally Posted by MTN REMODEL LLC View Post
TEXAS WAX.... Thanks.... I had tried Minwax, but went and checked and not sure if I used their water whitewash product or their #260 Pickled white Oak.
I don't think I realized they had two similar/but different product. The closest BB store is 40 miles.... hope they have both... worth a test.
Amazon will save you a trip
Solvent based 260 is likely your best bet. At least for the closest starting point. Then use previous advice like adding a touch of primer to get more white, for example.
Other consideration will be top coat and how it tints. Light stains and white in particular really tend to show the 'color' / tint of the top coat. If the original was a high build lacquer, gonna have a warm look as opposed to the waterbased poly's which push it cooler toward blue. You have 'some' control on the back end too in getting a better match.
...as the page loads, so go the days of our lives, at CT
Texas Wax is offline
The Following User Says Thank You to Texas Wax For This Useful Post:
Old 07-25-2017, 11:00 AM   #36
MARK...... Good out-of-box thinking... I did wish I could.... I'm adding small 10" bar pullouts to existing string of 4 cab island. (Changing out mismatched granite and going two tier bar top.)
(Thought about complete remodel/update.... but not a good economic feasable investment considering market etc)
Best
Help Matching Cabinet Finish/Stain?-img_4710-medium-.jpg
Old 07-25-2017, 11:25 AM   #37
Agreed.
As I said, the last thing you want to use to achieve MTN's color is stain, especially a factory mix.
Everyone... THANKS.... Great Ideas/Help
I've got a bunch of attempts to try.... but I did learn some things last night.
I do believe it was not a pickling stain and clear coat... probably a tinted laquor spray on...??
1) I sanded down last night an old dishwasher panel that I had saved (and forgotton) and it is definately a tinted surface coating. There was no stain below the surface coat. (I don't know how to tell if it was a laquor.
2) Plus it makes sense just by examining it... no distinct staining in the graining and just a general even white haze over entire surface.
3) Plus I pulled a few more doors/hinges and found where the hinge bore had not been hit by the spray and it was not a stain.
OK... I'm a GC and not an accompliced finish painter. Plus when we retired I sold a whole lot of my shop in downsizing, and don't have a HVLP anymore...and would not know how to tint out or spray laquor.
Can you think of how I could mimic/fake that finish...???
especially maybe with a brush on poly. Can I get tints (maybe white and brown?????) for Minwax oil poly and lay it on very carefully.... much like their Polyshades product. What tints would you advise.
Would you advise I hit the bare Oak with some diluted bleach at first.
Would you advise that I hit the raw oak with a sanding sealer.
Do you have an idea of a better alternative advisable product and technique.
Thanks in advance for any/all advice everyone.
Best
Peter
(TEXAS WAX/RAIL..... I also tried some water base Olympic deck stain tinting a water base poly last night.... and that combination does come out alot brighter white and much cooler than probably my laquor finish. I am going to try a couple of top coats of oil poly and see if that warms it up.)
Old 07-25-2017, 11:52 AM   #38
tjbnwi's Avatar
Rewards Points: 208
Bleach and wood bleach are 2 different things.
tjbnwi is offline
Old 07-25-2017, 12:23 PM   #39
hdavis's Avatar
Rewards Points: 386
I doubt they bleached these originally. Laundy bleach is sodium hypochlorite, wood bleach is oxalic acid. Two part wood bleach is hydrochloric acid & hydrogen peroxide (I think ).
Laundry bleach degrades the wood fibers.
hdavis is offline
Old 07-25-2017, 12:29 PM   #40
hdavis's Avatar
Rewards Points: 386
In general, the safest thing to do with something like this is put a sealer coat on, so if you screw up, you can wipe / wash off your tinted layer. You just have to make sure your solvent for the tint coat won't take off your sealer.
I don't see how you'd get a match brushing your tint coat on, but maybe....
If you have to, even a cheap airless is capable of getting a coat on, you just may have to thin it to work. By cheap, I mean I once used a $20 (on sale) HF airless 2200PSI.
hdavis is offline
Cabinet Matching pricing help JonWosLLC Carpentry 4 03-19-2013 05:05 PM
Matching kitchen cabinet AustinDB Carpentry 14 02-03-2013 05:09 AM
The Showcase Cabinet Kent Whitten Carpentry Picture Post 54 12-30-2012 02:30 PM
Jorgy cabinet claws have gotten exspensive Jasen Finish Carpentry 4 09-22-2012 01:17 PM
