Help Matching Cabinet Finish/Stain? - Painting & Finish Work - Contractor Talk
Old 07-24-2017, 01:36 PM   #1
MTN REMODEL LLC's Avatar
Trade: Remodel and new build Colorado @ 7651 FT
Rewards Points: 1,428
Hi Guys/Ladies....
Been awhile since I've been around. I've retired and sold/bought/moved to warm country in Nevada... but I'll always miss and call Colorado home. Hope everyone is doing well.
In process of RR on "new" 20 year old home.
I'm having a he11uva time trying to match this homes existing oak cabinetry.
As background... these were production built (extensive thru the area) and are 1996 version (so likely some aging affect). I have tried to find/pin down the manufacturer or the finisher without any success.
I had one person think they remember that it was called something like "Pearl/Perlized" oak finish.
It is Oak with what at first appears to me to be a white wash effect and likely a white pickling.
I've tried Old Masters/Minwax/white pickling/Another brand recommended by local Jones BM dealer/custom mixed SW stain/..... with both a poly semi gloss and a water poly semi finish.
Actually, the closest I have come is with an Olympic custom tinted semi-solid deck stain... wiped on-off and a oil poly.
But in examining the finish up close, and considering it is production built, I'm wondering if it somehow done with a tinted finish (laquor or poly), and not stained at first at all.
If looked at closely, there seems to be no distinct stain coloring, either in the grain necessarily, or in any corners. It is almost like a whiteish tint evenly all over.
In the cabinets I've made, I have tried to use the lightest oak I could find/cull.
Does anyone know how these were done and how I can replicate better, or any other suggestions as to product or technique that I can try.?????
I've tried to show pics in different light.... it is very light with some tan tint.
Thanks in advance for any/all help or advice.....
Peter
Help Matching Cabinet Finish/Stain?-kit-cab-stain-7-medium-.jpg   Help Matching Cabinet Finish/Stain?-kit-cab-stain-14-medium-.jpg   Help Matching Cabinet Finish/Stain?-kit-cab-stain-17-medium-.jpg   Help Matching Cabinet Finish/Stain?-kit-cab-stain-6-medium-.jpg   Help Matching Cabinet Finish/Stain?-kit-cab-stain-4-medium-.jpg
Help Matching Cabinet Finish/Stain?-kit-cab-stain-3-medium-.jpg   Help Matching Cabinet Finish/Stain?-kit-cab-stain-18-medium-.jpg
Never stop learning (xcep fer speling en typeing)
MTN REMODEL LLC is offline
Old 07-24-2017, 02:00 PM   #2
Texas Wax's Avatar
Rewards Points: 2,286
Re: Help Matching Cabinet Finish/Stain?
Minwax pickled oak.
Did an office in the mid 90's to match the 'blonde' finish of the late 50's. And that's the stuff in the images. Sherwinn Williams may have something close also. But theirs is more white pigment, with less 'transparent' stain/oil look.
...as the page loads, so go the days of our lives, at CT
Texas Wax is offline
Old 07-24-2017, 02:27 PM   #3
KAP's Avatar
Trade: Custom
Rewards Points: 144
Going to be near impossible to positively ID stain color/finish based on a pic...
You didn't say what you needed it for, but to save you time, send one of your drawer fronts to one of the following door makers to color match...
www.eliaswoodwork.com
www.walzcraft.com
www.conestogawood.com
All three have stain colors in that family, and are pretty accurate with their results...
KAP is offline
The Following User Says Thank You to KAP For This Useful Post:
MTN REMODEL LLC (07-25-2017)
Old 07-24-2017, 04:07 PM   #4
hdavis's Avatar
Rewards Points: 386
Use the back of a door and do some light sanding with fine sandpaper to see what's under that pickled look. It could be something, it could be nothing, but you need to have that part close to get the final look. Pay special attention to how the grain was handled.
hdavis is online now
Old 07-24-2017, 04:09 PM   #5
bywater's Avatar
Trade: Country Contractor
Rewards Points: 38
I think thats called a pickled finish. Check WoodCraft.
Heres one, there may be more on there. I just didn't look real hard.
https://www.woodcraft.com/products/g...702d6593003350
bywater is offline
Old 07-24-2017, 04:24 PM   #6
TEXAS WAX.... Thanks.... I had tried Minwax, but went and checked and not sure if I used their water whitewash product or their #260 Pickled white Oak.
I don't think I realized they had two similar/but diffrenet product. The closet BB store is 40 miles.... hope they have both... worth a test.
(Actually, several months ago, I faked some oak laundry room cabinets pretty well as they are not in the same room.... but these cabinets I just made will be contiguos to existing cabinets on the island.)
Old 07-24-2017, 04:28 PM   #7
www.walzcraft.com
KAP... Thanks.... I'm pretty new here, and I carried the cab front into both SW and Jones BM... but neither were worth a darn. Back in Colorado, I did have a good stain guy I could count on.
Thanks for the references, maybe I will have to, but then I can't really inspect what they come up with
Old 07-24-2017, 04:31 PM   #8
HDAVIS.... Good idea.... I'm going to go do it... at least I should be able to tell if the whitewash is in the finish or on the wood as a stain.
Never thought of that.... carefully upclose looking at it, I can't see/detect actual stain in the grain, nor in any corners.... I did notice a little at the rail/stile joint one one cabinet, but that could be just a slight buildup of pigmented clear finish.
Maybe sanding will confirm.....
Best
Old 07-24-2017, 04:33 PM   #9
Railman's Avatar
Trade: Railing
Rewards Points: 1,235
After you get the general tone right, you will probably have to amber tone it to kill the brightness of a pickle finish. The original finish probably had a slight pink cast to it, that over time diminishes. Reds fade fast.
I would start with the white pickle, & add a little light brown pigment stain to help with the aging effect. Just buy the pickle, & add others to adjust/match.
Railman is offline
The Following 2 Users Say Thank You to Railman For This Useful Post:
hdavis (07-24-2017), MTN REMODEL LLC (07-24-2017)
Old 07-24-2017, 04:44 PM   #10
hdavis's Avatar
Rewards Points: 386
Sometimes you can pick up clues on the bottoms / sides of drawers, but a little sanding is pretty definitive.
Old 07-24-2017, 05:13 PM   #11
KAP's Avatar
Trade: Custom
Rewards Points: 144
They can all provide sample chips to ship back with your drawerfront...
At lease you have options if your trial and error doesn't yield the results you want...
KAP is offline
Old 07-24-2017, 05:19 PM   #12
hdavis's Avatar
Rewards Points: 386
Just to come back to it, this was almost 100% sprayed, so it would be a tinted product sprayed on.
MTN REMODEL LLC (07-25-2017), rrk (07-24-2017)
Old 07-24-2017, 06:10 PM   #13
rrk's Avatar
Rewards Points: 62
Always sprayed on very popular a while ago, many many suppliers carried them. Any of the door manufacturers can match it, the pinkness turn a little yellow with the sun
rrk is online now
Old 07-24-2017, 06:58 PM   #14
tjbnwi's Avatar
Rewards Points: 206
How close do you think this is?
Hard to tell in the photos, but it does have a pink undertone.
Stain is the last thing you want to use to achieve the color you want.
Help Matching Cabinet Finish/Stain?-img_3058.jpg   Help Matching Cabinet Finish/Stain?-img_3060.jpg   Help Matching Cabinet Finish/Stain?-img_3083.jpg   Help Matching Cabinet Finish/Stain?-img_3084.jpg
tjbnwi is online now
Old 07-24-2017, 07:17 PM   #15
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 830
2 part bleach, takes the color out of the oak. Pickling stain, has to be made right to avoid the pink tone, has to be made to go on oak. Couple of clear coats.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
Old 07-24-2017, 07:22 PM   #16
tjbnwi's Avatar
Rewards Points: 206
The one I did needed a very slight pink tinge to match existing.
Old 07-24-2017, 07:46 PM   #17
LRG WoodCrafting
Leo G's Avatar
Rewards Points: 830
The pink usually comes from the wood. You need some green to kill it.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 07-24-2017, 07:55 PM   #18
tjbnwi's Avatar
Rewards Points: 206
Agreed.
As I said, the last thing you want to use to achieve MTN's color is stain, especially a factory mix.
Old 07-24-2017, 08:04 PM   #19
LRG WoodCrafting
Leo G's Avatar
Rewards Points: 830
Well, a pickle is a white stain.
WWG1WGA
Carpenter by day.
http://lrgwood.com
Leo G is online now
Old 07-24-2017, 08:07 PM   #20
tjbnwi's Avatar
Rewards Points: 206
I've never used a stain to create a pickled finish.
Cabinet Matching pricing help JonWosLLC Carpentry 4 03-19-2013 05:05 PM
Matching kitchen cabinet AustinDB Carpentry 14 02-03-2013 05:09 AM
The Showcase Cabinet Kent Whitten Carpentry Picture Post 54 12-30-2012 02:30 PM
Jorgy cabinet claws have gotten exspensive Jasen Finish Carpentry 4 09-22-2012 01:17 PM
