Funky Ceiling - Painting & Finish Work - Contractor Talk
Funky Ceiling
Old 06-09-2013, 09:18 PM   #1
Anderson's Avatar
Trade: Home improvement contractor
Rewards Points: 1,196
Funky Ceiling
Came across this the other day and before I try and fix it I think it would be best to understand what happened. I think it was a level 5 tape job and maybe it was painted before it was dry.
I just cant figure how they could have sanded it flat enough to paint and yet the mud didnt bond at all to the sheetrock
Funky Ceiling-img_20130608_163338_963.jpg   Funky Ceiling-img_20130608_163352_524.jpg
Anderson is offline
Old 06-09-2013, 09:21 PM   #2
donerightwyo's Avatar
Trade: custom builder
Rewards Points: 144
Re: Funky Ceiling
No tape on the seams? Looks like the mud didn't even stick to the nails?
I can't compete with hacks.
donerightwyo is offline
Old 06-10-2013, 07:11 AM   #3
painterman's Avatar
Trade: Historic Restorations
Rewards Points: 288
Re: Funky Ceiling
could this have been done in the winter months looks like the mud froze
painterman is offline
The Following User Says Thank You to painterman For This Useful Post:
donerightwyo (06-10-2013)
Old 06-10-2013, 11:36 AM   #4
Pete'sfeets's Avatar
Trade: house painting and miscellaneous repair
Re: Funky Ceiling
I was thinking the same thing. It looks like a garage and may not have the same kind of heating. If it was just painted over damp mud it would mean most all the corners would fail as that is where it was most wet and if neither of those , then it is water damage that wasn't ever attended to,, because some people only fix stuff when it is really really obvious. It may still be leaking.
If paint covers all sins ,,,then I guess I should be covered
Pete'sfeets is offline
Old 06-10-2013, 08:21 PM   #5
Anderson's Avatar
Re: Funky Ceiling
it is a garage there was no water damage from above, just complete seperation of the joint compound from the sheetrock. I guess it could have frozen
Anderson is offline
Old 06-17-2013, 11:03 PM   #6
Derek1157's Avatar
Trade: Painter/Remodeler/Funnyman
Rewards Points: 81
Re: Funky Ceiling
Wow!!
Looks like no drywall primer was used either. What a mess! When the paint comes off in sheets, it usually means no primer. Did the mud maybe dry too much before applying it to the substrate? Is the sheetrock old or new? If it's old, it may have needed a primer too.
Derek1157 is offline
Paint chipping Dpear Painting & Finish Work 8 05-28-2013 11:23 AM
fine line bolt slot suspended ceiling diffuser Rich D. HVAC 4 01-03-2013 01:32 AM
Room Too Small for Coffered Ceiling?? vettefan77 Remodeling 11 12-18-2012 08:32 PM
Crown molding on concrete ceiling CadetC Finish Carpentry 13 09-15-2012 09:14 PM
