Frustration With New Titan Hvlp - Painting & Finish Work - Contractor Talk
Old 04-15-2019, 09:17 PM   #1
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 2,720
I recently bought a new Titan Capspray 115 hvlp. Using it recently for the first time I finally got it working after discovering the check valve was installed reversed and it would not spray, ok fix and move on. Today I go to use it again for the second time and the spray was pulsating. Grrr.
Troubleshooting guide says packing nut loose of damaged, ok I tighten it up till it is just snug. Off I go again, pulsating resolved but now paint is spewing out the tip when trigger is released. What gives? I am pi$$ed over this aggravation.
Plan to call rep in the morning.
Ohio painter is offline
Old 04-15-2019, 09:21 PM   #2
Re: Frustration With New Titan Hvlp
I forgot to add I was spraying latex Emerald Urethane at full thickness. #5 tip. The rep assured me the hvlp could handle full thickness latex paint as I had specifically asked.
Old 04-15-2019, 09:23 PM   #3
tjbnwi's Avatar
Rewards Points: 2,120
I've used a Cap Spray system twice.....(these are reasons its only been twice).
It's spitting because the packing nut is to tight, back it off a turn.
It should handle Emerald easily.
tjbnwi is offline
Ohio painter (Yesterday)
Old Today, 11:50 AM   #4
Stelzer Painting Inc.
stelzerpainting's Avatar
Trade: 1721
Rewards Points: 472
I also have the Capspray, and found the design of the gun/pot to be less than ideal, particularly at the check valve interface. Their entire check valve design has been flawed from the start. Never liked the Maxum guns. I even remember cursing my old 4 stage CS 9000 10-15 yrs ago.
I'd agree with the suggestion above about backing off a turn to see if it helps your spitting issue. Just a few more suggestions I've found useful when working with turbine rigs, FWIW...
-Purchase an extra length of hose, which could be had on Amazon or similar for way cheaper than OEM hose. Typically the turbines can run about twice the length of hose as they came with, (usually comes with 15', get another 15', and of that extra 15', incorporate a hose whip, which keeps you from fighting the rigidity of the hose as you work, making it way more user-friendly). One of the biggest challenges when working with turbines to spray modern acrylics, urethanes & hybrids is the hot air from the turbine dries the paint so fast that it creates a sort of dry-spray effect, very rough & gritty look & feel. The extra length of hose will help immensely to cool down the product before it hits the surface.
-When using the rig, set it up in the coolest place possible, which also helps to avoid conditions listed above. The extra length of hose will give you more options.
-Don't be afraid to use retarders, which aids in flow and with the whole dry-spray thing. Always search retarders suggested by manufacturer first, and if no info is given or provided when asked, Butyl Cellosolve is typically a safe bet. Follow instructions regarding how to add the retarder and use no more than what is recommended, or you'll risk compromising the overall integrity of the film.
Congrats on your purchase, BTW. You're about to delve into a world where many painters wished they never delved, (delved?) Achieving good results with modern products is possible with turbines, but takes quite a bit of fine tuning. Record your results when successful. Be systematic when dialing something in by changing just one factor at a time, test, record, rinse repeat. Post some pics of your results. Hope it makes you gobs of $.
Troy Stevens, Stelzer Painting Inc.
www.stelzerpainting.com
stelzerpainting is online now
HVLP upgrade platinumLLC Tools & Equipment 5 03-29-2017 04:10 PM
Spraying Benjamin Moore Advance with HVLP Rustbucket Painting & Finish Work 20 12-02-2016 08:05 AM
Werkmaster Titan Concrete Grinder/ Polishing Machine StainConcrete Contractor Swap 0 03-05-2014 03:59 PM
Graco HVLP 4900, used but NEW to me Aaron Berk Painting & Finish Work 7 01-21-2013 09:38 AM
Titan 440i Filter Replace artinall Painting & Finish Work 10 07-24-2012 10:15 PM
