Filling Nail Holes On Pre-painted Off Color Trim - Painting & Finish Work - Contractor Talk
Old 04-03-2015, 09:59 AM   #1
Livin the dream...
Spencer's Avatar
Trade: Finish Carpentry
Rewards Points: 5,514
What do you guys do to fill hole on pre-painted trim that isn't straight white?
I've got some trim that is more like a peach color that I'm installing to match existing trim in the house. I really don't want to have to paint everything again if I don't have to...
I do have the fancy new caulk mixer that color matches. I'm considering trying that but I'm afraid it will look "smudgy."
Spencer is offline
Old 04-03-2015, 11:01 AM   #2
Trailer park boy
shanekw1's Avatar
Rewards Points: 371
Re: Filling Nail Holes On Pre-painted Off Color Trim
Glue it on?
"Industry without art is brutality"
shanekw1 is offline
Old 04-03-2015, 11:13 AM   #3
Lazy Millennial
Youngin''s Avatar
Rewards Points: 646
If it's not very much trim you could glue the miters as usual, use trim clamps to keep them tight, moulding glue on the back and tape to keep it aligned.
Originally Posted by mnld View Post
Home Depot... you can glue it, we can help!
Youngin' is offline
Old 04-03-2015, 11:13 AM   #4
avenge's Avatar
Rewards Points: 118
I don't use pre painted trim but if I had to i'd end up painting it anyway so what's the point of using it.
avenge is offline
Old 04-03-2015, 12:44 PM   #5
Livin the dream...
Spencer's Avatar
By pre-painted I mean that I sprayed it all before hand in the shop. I'm trying to avoid brushing on another coat.
Spencer is offline
Old 04-03-2015, 12:47 PM   #6
slowsol's Avatar
Rewards Points: 2,248
Whatever you put on will inevitably fade/yellow/something. Even if it looks good now, it won't in the future.
With that said, I'd probably get some of the Minwax nail filler in white and try to tint it with the paint until it matched.
-John
slowsol is offline
Old 04-03-2015, 12:54 PM   #7
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 100
Worst case scenario, if you don't get good results with the caulk, you still have the option of giving it another coat, right?
pinwheel is offline
The Following User Says Thank You to pinwheel For This Useful Post:
Spencer (04-03-2015)
Old 04-03-2015, 02:20 PM   #8
avenge's Avatar
Rewards Points: 118
Still has to be painted, there's nothing that won't discolor down the road.
avenge is offline
Old 04-03-2015, 02:23 PM   #9
Livin the dream...
Spencer's Avatar
This may be a dumb question but how much can a hole the size of an 18 gauge brad really yellow? Again keep in mind we aren't talking white it's more of a deep tan color.
Lewis Carpentry
Spencer is offline
Old 04-03-2015, 02:50 PM   #10
Always Learning
overanalyze's Avatar
Trade: Builder/Remodeler
Rewards Points: 1,158
I quit trying to do pre-finished painted trim. It just is a pain. I'll one coat, install, then final coat on smaller jobs. Maybe I'll two coat the top edge so I just have to paint the face surface.
overanalyze is offline
Old 04-03-2015, 04:10 PM   #11
FrankSmith's Avatar
Rewards Points: 5,124
It needs to get final painted after install. There is no way painted trim can look complete without being caulked and painted in place. Caulked nail holes look bad even when painted over. You can see every one. I don't think it's a good idea to use strictly a brad nailer to install trim anyways. 16 Gauge nails hold a lot better for you base and outer edge of casing.
FrankSmith is offline
Old 04-03-2015, 04:12 PM   #12
avenge's Avatar
Rewards Points: 118
The same as a 16 gauge.
avenge is offline
Old 04-03-2015, 05:29 PM   #13
kingcarpenter's Avatar
Trade: G.C./carpenter
Rewards Points: 544
Caulking the holes will look like fido's arse. Any caulk shrinks unlike putty. Try what slowsol said about tinting the putty or glazing compound. Theres no getting away from painting it again to make it right. Take it from me I did punch warranty due to an injury for a very long time. Can't come up with anything I haven't tried to save time on punch lists. Good luck.
kingcarpenter is offline
Old 04-03-2015, 07:13 PM   #14
Eaglei's Avatar
Trade: carpenter & Masonry
Rewards Points: 1,510
Mohawk wax stick , lots of colors and doesn't shrink .
Eaglei is offline
Old 04-03-2015, 07:20 PM   #15
LRG WoodCrafting
Leo G's Avatar
Trade: Maker of Fine Sawdust
Rewards Points: 699
I'm sure the color is in here somewhere.
Sawdust Follows Me Everywhere
WWG1WGA
Carpenter by day.
Mad scientist by night.
http://lrgwood.com
Leo G is online now
The Following 3 Users Say Thank You to Leo G For This Useful Post:
Eaglei (04-03-2015), FrankSmith (04-03-2015), Texas Wax (04-03-2015)
Old 04-03-2015, 08:34 PM   #16
FrankSmith's Avatar
That stuff is goof for filling nail holes. It doesn't caulk where the material meets. For example casing to jamb. Looks finished on pre stained but not pre painted.
Old 04-03-2015, 10:02 PM   #17
DeanV's Avatar
Trade: Painter
Rewards Points: 572
i am sorry, but just filling nail holes with caulk, not caulking joints, caulking joints but not painting them, etc are all going to give substandard results.
DeanV is offline
The Following 2 Users Say Thank You to DeanV For This Useful Post:
FrankSmith (04-04-2015), stelzerpainting (04-06-2015)
Old 04-06-2015, 10:46 AM   #18
Stelzer Painting Inc.
stelzerpainting's Avatar
Trade: 1721
Rewards Points: 530
Not only will unpainted caulk discolor/fade at a different rate than the paint, it's also a dust magnet, so every piece of flying debris that hits the unpainted caulk will stick to it.
Pre-painting trim can save time overall, but I'd never pre-paint in lieu of post-painting. I suppose if I were doing apartments or real low-end homes, then it might be a different story. It all comes down to what expectations your customer has, understanding what your finish will look like once you've decided on a system to use, and effectively communicating those standards to your customer to insure their expectations will be met.
Troy Stevens, Stelzer Painting Inc.
www.stelzerpainting.com
stelzerpainting is offline
Filling old core drill holes in hospital groundzero2121 Commercial Construction 7 08-14-2012 01:32 PM
Carpenters and Nail Bags Jaws General Discussion 95 06-11-2012 05:15 AM
Number Of Bored Holes In 2 x 6 Stud marvel32 Carpentry 10 10-27-2011 09:05 PM
Hammer or Auto Hammer, Nail gun etc. What do you prefer? jtancun General Discussion 20 07-09-2011 11:35 AM
The elusive nail punch Pete'sfeets Painting & Finish Work 5 04-28-2011 11:40 PM
