Divided Light Doors... - Painting & Finish Work - Contractor Talk
Old 04-02-2019, 07:04 AM   #1
Radical Basement Dweller
Robie's Avatar
Rewards Points: 2,524
For you pros out there...
These are true divided light doors.
How long would it take you to paint what is shown in the picture...2 coats?
If you tell the truth, you don't have to remember anything.
Mark Twain
Robie is online now
Old 04-02-2019, 07:13 AM   #2
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 16,091
Re: Divided Light Doors...
Bank on one lazy day, as a semi-pro.
MarkJames is online now
Robie (04-02-2019)
Old 04-02-2019, 09:51 AM   #3
Idothat's Avatar
Trade: Home improvement of all types
Rewards Points: 68
Assuming everything is prepped and clean and ready to paint , about 30- 45 minutes a coat , one side , including door edges and jamb .
If prep is required, it depends on what it needs.
Idothat is online now
The Following User Says Thank You to Idothat For This Useful Post:
Robie (04-02-2019)
Old 04-02-2019, 11:13 AM   #4
VinylHanger's Avatar
Rewards Points: 11,248
I'd figure an hour or so a side. Just use the right brush.
VinylHanger is offline
The Following User Says Thank You to VinylHanger For This Useful Post:
Robie (04-02-2019)
Old 04-02-2019, 05:41 PM   #5
Robie's Avatar
Took me about 90 minutes per door; too slow.
The doors were older and just needed to be vacuumed, scuffed and painted.
I didn't worry much about all that cutting in and just scraped the paint off the glass after I was done.
Mark Twain
Robie is online now
Old 04-02-2019, 07:16 PM   #6
MarkJames's Avatar
That sounds about right, including the window scraper clean-up.
Old 04-02-2019, 08:15 PM   #7
Robie's Avatar
I know painters that would have done very little scraping afterwards.
Mark Twain
Robie is online now
MarkJames (04-02-2019)
Old 04-02-2019, 08:36 PM   #8
MarkJames's Avatar
I can do that without scraping, and probably so can you. What paint and what brush did you use?
hdavis (04-02-2019)
Old 04-02-2019, 08:48 PM   #9
Robie's Avatar
ProMar 200...semi...2" Purdy 2" sash
Mark Twain
Robie is online now
Old 04-02-2019, 09:29 PM   #10
Sometimes it is a balance of cutting in slowly and carefully, or scraping a little glass.
The Following 2 Users Say Thank You to VinylHanger For This Useful Post:
hdavis (04-02-2019), Robie (04-03-2019)
Old 04-02-2019, 10:05 PM   #11
hdavis's Avatar
Rewards Points: 892
Old exterior wood windows are the worst. First coat should overlap the glass slightly, and second coat should overlap the first coat onto the glass. Scraping it is suboptimal, you put the paint on and leave it.
hdavis is online now
Old 04-02-2019, 10:13 PM   #12
hdavis's Avatar
Rewards Points: 892
Sometimes you can borrow from pinstripers and choke up on the brush, then drag your little or ring finger along the top of the mullion to get a clean line.
Robie (04-03-2019)
Old 04-02-2019, 10:18 PM   #13
hdavis's Avatar
Rewards Points: 892
One thing to keep in mind, as you age, your hand may become less steady. You just adjust how you do things.
Best 12V cordless drill LIGHT ??? lewisthepilgrim Tools & Equipment 10 12-19-2013 10:11 PM
Best method to paint new wood pre-hung doors BElliottP Painting & Finish Work 7 12-17-2013 06:36 AM
Light activated exterior lighting wallmaxx Electrical 9 05-10-2013 04:50 PM
Mortar in Fireplace doors 6stringmason Masonry 8 07-12-2012 08:23 PM
