Covering Paneling - Painting & Finish Work - Contractor Talk
Covering Paneling
Old 07-30-2016, 04:16 PM   #1
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 2,958
Covering Paneling
Had planned to prime and paint panelling in a dry basement for a customer, part of a much larger job.
Customer now is less enthused about painted panelling. The panelling could be removed as one option, most likely block behind it.
Another is to remove panelling and hang new drywall, drop ceiling would have to come out and be reinstalled.
I wondered about hanging liner paper and then painting. I have hung liner paper under wallpaper and been pleased with the result, but the two layers of paper makes the grooves disappear, I am not sure only liner paper will do so, especially over a larger area.
I am just trying to provide a few options. Any thoughts?
Thanks.
Ohio painter is offline
Old 07-30-2016, 04:46 PM   #2
slowsol's Avatar
Rewards Points: 2,248
Re: Covering Paneling
I have seen paneling skimmed and textured. Looked pretty decent.
-John
slowsol is offline
The Following User Says Thank You to slowsol For This Useful Post:
hdavis (07-30-2016)
Old 07-30-2016, 05:16 PM   #3
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 996
I worked on one 3-4 years ago where we just did a smooth skim coat. Holding up great so far.
Right now, working on one that had paneling applied over drywall. The basement flooded, and they cut everything off about 10" up, including the furring strips.
We hung new drywall right over the paneling with a PT strip behind the floating bottom edge to maintain spacing from the block. Butted the sheets against the ceiling grid and dressed up with 1/4 round. It actually looks pretty doggone nice.
Tinstaafl is online now
Old 07-30-2016, 08:38 PM   #4
hdavis's Avatar
Rewards Points: 1,278
Skimming is the go to for something like this.
hdavis is online now
Old 07-31-2016, 12:27 AM   #5
zmusashi's Avatar
Trade: carpentry, remodeling
Rewards Points: 59
What's the best method for skimming old-school paneling? 3' fiberglass mesh tape and regular compound? Thanks for advice!
zmusashi is offline
Old 07-31-2016, 01:56 AM   #6
m1911's Avatar
Trade: finish carpenter
Rewards Points: 15,632
Fiberglass mesh and standard mud don't belong together. Fiberglass mesh should be used with setting mud.
Originally Posted by tipitop View Post
That guy in video have mental issues plus eat hole turtle from some reason
m1911 is offline
Old 07-31-2016, 05:14 AM   #7
Thanks for the replies, I wondered about skimming. Are you priming the paneling before skimming?
Old 07-31-2016, 05:29 AM   #8
PRP's Avatar
Trade: Painting Contractor
Rewards Points: 132
Prime with oil before skimming. Keeps the paneling from absorbing water from the mud.
PRP is offline
The Following User Says Thank You to PRP For This Useful Post:
Ohio painter (07-31-2016)
Old 07-31-2016, 06:36 AM   #9
General Contractor
greg24k's Avatar
Rewards Points: 8,674
Another option is a 1/4" sheetrock over it tape and paint.
greg24k is online now
Old 07-31-2016, 11:56 AM   #10
zmusashi's Avatar
Rewards Points: 59
If I oil-prime the paneling, can I skim the recessed vertical seams with regular compound, and mesh is unnecessary? I'd like to skip the Durabond of course if possible!
Additionally, my client would like to install paneling to match the original 1/4" plywood paneling after water damage many years ago. I found a source for this, 1/4 ply with paper faced laminate, however the supplier told me it can't be painted. One pro told me I could prime it with bonding primer and then paint it, but I'm wary- any insights?
Thanks everyone!
zmusashi is offline
Old 07-31-2016, 12:20 PM   #11
PRP's Avatar
Rewards Points: 132
Thanks everyone!
I have done it that way, but would recommend at least putting mesh tape on seams where sheets meet. Also make sure paneling is fastened well. JC will be fine for skim.
PRP is offline
Old 07-31-2016, 12:43 PM   #12
slowsol's Avatar
Don't put 3' mesh over all the paneling. If you're going to do that, just hang 1/4" board as stated above. Tape the joints. Skim everything else. Durabond is not the only setting type compound.
-John
slowsol is offline
Old 07-31-2016, 01:25 PM   #13
hdavis's Avatar
Now I'm not sure what the questions are...
You want to skim the existing paneling, which covers the whole wall, then put up new paneling over it? Explain, please.
Old 07-31-2016, 08:02 PM   #14
Caslon's Avatar
Trade: State Licensed Painting Contractor
Rewards Points: 1,366
Seems it would be better to skim coat over what's behind the paneling.
Caslon is offline
Old 07-31-2016, 08:48 PM   #15
hdavis's Avatar
Sometimes you pull a panel and OMG, so back on it goes....
Agility (08-02-2016)
Old 07-31-2016, 08:49 PM   #16
slowsol's Avatar
The glue they used for the paneling is usually the pain in the butt (you have to scrape and then it tears off the paper). And around here the board behind the paneling has no tapered seams, isn't taped, and is pieced in like crazy.
-John
slowsol is offline
hdavis (07-31-2016)
Old 07-31-2016, 09:00 PM   #17
hdavis's Avatar
Around here a lot is over busted up plaster...
Old 08-01-2016, 01:18 AM   #18
zmusashi's Avatar
Rewards Points: 59
Existing paneling is partly over rock (on garage wall at least) and is about 36' straight paneling sheets including 6 panel-skinned doors, plus the stairwell, which is nicely done and more intricately cut to fit. Raw framed walls to cover amount to 60'.
Would be nice to either get new paneling to match, then prime and paint both new and old paneling with confidence, or to skim existing paneling at stairwell and either skim or remove other existing paneling and tape the rock behind it (or re-rock/ rock over it).
Existing Basement Pics: http://www.fentonfurrer.com/photo-album
Again, manufacturer says this new 1/4" plywood paneling I found- which matches existing paneling- has a paper faced laminate isn't meant to be painted. Seems a little difficult to believe but who wants to forge ahead on that caution?! So, my options seem to be to skim existing paneling, apply bonding primer and then paint new paneling, OR to install rock on raw walls and tape and skim existing paneling.
Thanks everyone
zmusashi is offline
Old 08-01-2016, 02:12 AM   #19
VinylHanger's Avatar
Rewards Points: 13,022
That seems like a lot of effort to keep some ass looking paneling. I would just cover it with 3/8, cheaper than 1/4, put in a new door, hang the rest of the basement, tape, texture and call it nice and new.
If it was some exotic paneling that floated here on the ocean, maybe, but that ain't it.
VinylHanger is online now
The Following User Says Thank You to VinylHanger For This Useful Post:
zmusashi (08-01-2016)
Commercial Real Estate Loan Originator Covering all 50 states JonCasillas New Member Introductions 0 03-15-2013 06:01 PM
Exterior wall covering options? bob_cntrctr Construction 8 02-25-2013 08:05 AM
Where to find cheap wood paneling ProWallGuy Remodeling 10 09-07-2009 07:29 AM
Wall liner over paneling? mdshunk Wallpaper 8 01-31-2009 12:08 AM
Wall liner for covering wood paneling? benjmo Wallpaper 1 01-25-2006 11:49 PM
