Bright Red - Painting & Finish Work - Contractor Talk
Bright Red
Old 10-13-2012, 01:08 PM   #1
Lettusbee's Avatar
Rewards Points: 1,740
Bright Red
Any advice for painting over bright red interior bedroom walls?
Painted the room red for our oldest daughter, and I remember it took about 4 coats to finally cover the original white.
Now, another daughter is moving into that room, and wants white walls.
Is this going to be another 4 coat process to completely cover the red?
Thanks,
Lettusbee is offline
Old 10-13-2012, 01:11 PM   #2
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Re: Bright Red
Ask her if she wants pink instead.
I think it depends on the paint, how thick and the shade of red....and how picky you are.
Inner10 is offline
Old 10-13-2012, 01:37 PM   #3
Da Boss....
Schmidt & Co's Avatar
Trade: Painting and wallpaper hanging contractor
Rewards Points: 260
Re: Bright Red
The white will cover much better than the red. Dark, tinted bases like your red are almost clear before they are tinted. And tint covers poorly. Titanium dioxide is what gives a paint good coverage, and it's white.
Just pick a good quality paint and you might make it in two coats, but be prepared to do three because of the drastic color change.
Paul
Schmidt & Co is offline
Old 10-13-2012, 01:55 PM   #4
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Re: Bright Red
Real red is a stock sw color. Paint it grey primer then white.
ohiohomedoctor is offline
The Following 2 Users Say Thank You to ohiohomedoctor For This Useful Post:
hdavis (10-13-2012), ToolNut (10-14-2012)
Old 10-13-2012, 03:39 PM   #5
Drywall & Painting Pro
Sir Mixalot's Avatar
Rewards Points: 8,485
Re: Bright Red
Yep. Tint a stain blocking primer grey and you should be good to go.
-Paul
TextureMaster.com
Checkout my YouTube Channel with 90,000 Subscribers and over 13,000,000 views
My Latest Video: https://youtu.be/E23Y-fw4KCM
YouTube Channel: https://www.youtube.com/paulpeck
Twitter Facebook Instagram YouTube
Sir Mixalot is offline
Old 10-15-2012, 07:44 PM   #6
Gough's Avatar
Trade: painting
Re: Bright Red
I typically have them load primer with as much W as they're allowed to create a "high-hiding" primer. We'd had good luck with that.
Going the other way, from white to red, I learned a trick from an auto painter years ago: paint it black first. In our experience, that saves many coats of red.
Gough is offline
bright nails in pressure treated wood (copper) forrest1848 Construction 27 05-28-2018 12:20 PM
12V 4" recessed lights not as bright as when first installed MasterBuilt Electrical 3 07-02-2012 08:19 PM
I need A Chemical To Turn Patina Copper Back To Bright Penny Color Ed the Roofer Roofing 30 02-19-2010 10:04 PM
