Behr Al In One Paint & Primer. What Garbage - Painting & Finish Work - Contractor Talk
Old 09-22-2010, 01:40 AM   #1
rstarre's Avatar
Rewards Points: 93
I am remolding a kitchen in an old house for a female cousin. The kitchen has plaster walls with a lot of cracks in it and had a rough texture from old wallpaper glue that was painted over. So I put 1/4 drywall over it. She insisted her son would paint the walls and ceiling to save some money. Plus he was painting the rest of the house for her at the time. If this wasn't a relative, I would have never agreed to this. For years she has always used Behr Paint. So she bought the Behr Satin Paint and Primer In One at 31 dollars a gallon. Her son painted the new drywall in the kitchen. When the son took the 3m blue tape off the trim, about a 1/4 wide line of the paint peeled about a right of the brand new drywall. She blamed it on the tape. I didn't pay to much attention to that since she insisted her son paint, he can fix it. A week later I am installing crown molding on the new cabinets. The cabinet next to the wall was a normal 12 inch in depth wall cabinet. The next cabinet was a 15 inch depth, so I had a 3 inch bump out. I fitted the crown molding on the cabinet before I nailed it and was a hair snug against the wall. When I took it down I noticed the paint had peeled right off the wall where the molding had touched it. The paint looked like it was rubberized and I probably could peel it all off the whole wall if I took the time to do so. I never seen paint peel off of new drywall. My cousin plans on calling Behr to try and get a refund.
rstarre is offline
Old 09-22-2010, 01:44 AM   #2
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Re: Behr Al In One Paint & Primer. What Garbage
Which is exactly why I'd use a sealer over fresh drywall first.
These "all-in-one" products are DIY specials!
Angus
angus242 is offline
The Following 2 Users Say Thank You to angus242 For This Useful Post:
RCPainting (09-22-2010), Steve Richards (09-22-2010)
Old 09-22-2010, 05:15 AM   #3
Big Shoe's Avatar
Rewards Points: 2,110
DITTO
Big Shoe is offline
Old 09-22-2010, 06:33 AM   #4
Joe C's Avatar
Trade: Painting Contractor
Did anyone clean the walls after sanding the joints? If you paint right over all the dust from sanding, this kind of the thing can happen.
Joe C is offline
Old 09-22-2010, 08:54 AM   #5
Paint Dribblz's Avatar
Rewards Points: 25
Sounds like not only another adhesion problem with behr paint but also that the painter didn't handle the job right. I would never use a 2-in-1 on new drywall. ALways a good drywall primer>1-in-2 or Primer>2coats laytex. Calling for money back is the normal Behr procedure.
Paint Dribblz is offline
Old 09-22-2010, 05:04 PM   #6
rstarre's Avatar
Rewards Points: 93
The walls were vacuumed with a shop vac to get all the dust off. The pantry was painted with the same paint. The drywall was not replaced in there. The walls had flat paint on it. You can peel it off the walls in there also. The peeled paint is soft and pliable. It is like it never hardened. So it isn't a prep issue of the new drywall. Called Behr and was told maybe there wasn't enough hardener put in the paint when it was made. They said if my cousin sends them the sales slip from Home Depot, they will refund her money for the three gallons.
rstarre is offline
Old 09-26-2010, 01:43 AM   #7
Particulate Filter
Metro M & L's Avatar
Trade: Flooring
Rewards Points: 1,484
The behr paint peels for easy color changes. It's a new proprietary technology. Patent pending.
Metro M & L is offline
The Following User Says Thank You to Metro M & L For This Useful Post:
SubwayGuy (09-30-2010)
Old 09-26-2010, 10:17 AM   #8
Steve Richards's Avatar
Trade: hack painting
HA!
Thank You to Metro M&L
Steve Richards (today)
Steve Richards is offline
Old 09-26-2010, 10:26 AM   #9
Andrew M.'s Avatar
Rewards Points: 150
We all know that prep is the most critical factor. With these so-called clean air paints I have found they take a long time to harden but tack try fast I suppose to limit the VOC's,, even BE 123 primer does now even more it seems. Primer coat is to me critical and I almost always primer at least 1 coat on anything now, would never even think about new drywall without a PVA or similar sealer first.
Another HD gimmick to attract DIY'ers to the store. Should sell it next to the ryobi & wagner hand held airless sprayers.
Andrew M. is offline
Old 09-26-2010, 01:49 PM   #10
DeanV's Avatar
Trade: Painter
Rewards Points: 572
Of course, 3 gallons of new paint over the existing problem will not fix anything. How long was the cure time on the paint when you put up the crown?
DeanV is offline
Old 10-03-2010, 07:54 PM   #11
New Quirky Carpenter
William James's Avatar
Trade: Trim Carpentry and Remodeling
Rewards Points: 538
I was doing some service work, and the HO painted her bathroom with the Behr AIO. Same as your example, peeling at joints where it was taped. It was previously painted and some mudding was done. It seemed to adhere to the painted surface ok, it doesn't need primer. But any spots where it was compounded was peeling right off.
She had a hard-time getting her money. She went back, got more with a credit, and had same issue. I think she ended up getting a check for someone to paint it.
Guilford, CT Remodeler and Carpenter Web-site [email protected]
Facebook
The great use of life is to spend it for something that will outlast it.
William James is offline
Old 10-03-2010, 09:51 PM   #12
Someday people will learn.
How's that?
Old 10-03-2010, 09:53 PM   #13
semi-skilled laborer
ModernStyle's Avatar
Trade: Professional Painting
Rewards Points: 1,186
If the wall is already painted you dont normally need a primer, has anyone ever looked at the back of a can to see if it tells you to use a primer on new drywall, seems alot of the products out there dont live up to their hype if you read the back of their can.
The box stores like to push primer on people, if you are going white over white they will still try and sell you some primer.
OwensboroPainting.com
ModernStyle is offline
Old 10-04-2010, 10:30 AM   #14
johndaprano's Avatar
Trade: Contractor
Rewards Points: 25
Thank you for this listing. I am debating on going with the Behr all in 1 product or Sherwin Williams Duration.
johndaprano is offline
Old 10-04-2010, 10:47 AM   #15
Landmark Prop's Avatar
Trade: Property Management
The hardware store here charges almost double what regular paint costs for the all-in-one paint. I guess they figure people value their time enough to pay $80/gal
Landmark Prop is offline
Trim problem - behr premium paint and primer in one badbear Painting & Finish Work 13 05-26-2013 05:29 PM
Paint Shaver vs Infrared Paint Removers Goochie Painting & Finish Work 12 09-11-2012 04:05 PM
SW Duration paint-use primer or not? stromer Painting & Finish Work 10 11-13-2010 10:53 PM
here's a painting price list...... Jer44 General Discussion 9 02-17-2009 08:30 AM
