Baseboard Thickness - Painting & Finish Work - Contractor Talk
Baseboard Thickness
Old 11-27-2014, 03:56 PM   #1
jfishel's Avatar
Rewards Points: 22
Question
Baseboard Thickness
I have always figured a 1 1/2" overhang on the top of a piece of furniture should allow it to be pushed right up to the wall with no gap, but is this enough? Too much? A lot of newer construction has 1/2" - 3/4" MDF baseboard that can flex vertically to cover up gaps due to floor height inconsistencies, but I have seen quarter round used to seal off that gap where solid wood was used, particularly in older houses. At least, I assume that's what that strip is for.
Is thicker common? Should I be going with 2" overhang, or even more? In my mind, clearance for outlet access is secondary to interior volume, so I'm looking for the minimum overhang for 99% of construction.
Any help would be greatly appreciated!
jfishel is offline
Old 11-27-2014, 04:06 PM   #2
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
Re: Baseboard Thickness
1/2 to 3/4 for base. 3/8 to 1/2 for shoe.
jlsconstruction is offline
Old 11-27-2014, 04:21 PM   #3
Roofcheck's Avatar
Trade: Know it all
Rewards Points: 2,054
Most furniture I have seen and in my house does not sit up to the wall.
Roofcheck is offline
The Following User Says Thank You to Roofcheck For This Useful Post:
CarpenterSFO (11-27-2014)
Old 11-27-2014, 07:10 PM   #4
jfishel's Avatar
Rewards Points: 22
jlsconstruction: Thanks for the info! Is this just what's currently available or what has been pretty much standard for the past 50+ years?
Roofcheck:
That's pretty true for a lot of furniture, from plain particle-board box furniture to super-fancy solid-wood stuff with fat feet. It's fine for most people, but it absolutely drives me nuts to keep having pencils roll off and fall into cracks, or small objects tip back and hang over the edge, leaning against the wall.
Of course for electrical cords the gap is very useful because the cord can go over the edge wherever the appliance rests. But the owner should be able to choose whether to push it all the way back or leave that gap, so it makes more sense to have the overhang than to not have it.
I admit this is a nit-picky thing to be considering, but I want to get it right.
jfishel is offline
Old 11-27-2014, 07:14 PM   #5
stacker of sticks
Rewards Points: 590
Usually what I put in now is 1/2" base with 3/8th shoe. I remodel houses mostly, and they have 3/4 base with 1/2 shoe
Old 11-27-2014, 09:21 PM   #6
jfishel's Avatar
Rewards Points: 22
Sounds like 1 1/4" is a pretty good bet, then. To be safe, I'll keep my extra 1/4", but more would probably be excessive.
Thanks for the help!
jfishel is offline
The Following User Says Thank You to jfishel For This Useful Post:
jlsconstruction (11-27-2014)
Old 11-29-2014, 09:20 PM   #7
topsail's trimcat
woodworkbykirk's Avatar
Rewards Points: 384
95% of hte baseboard i use is 3/4 " thick and base shoe is 11/16"
the biggest worry about baseboard thickness for me is the comparison to the thickness of hte casing to baseboard.. if the base is thicker than the casing a plinth block should be used for the casing to sit on.. otherwise you have to either return the baseboard or make a bevel cut on the end so it doesnt stand out proud of the face of the casing where they meet
woodworkbykirk is offline
what type of glue is best for Boral trim and can it be thickness planed? dale rex Carpentry 15 08-04-2014 06:22 PM
Inside corners on baseboard and crown otislilly Finish Carpentry 147 05-19-2014 07:07 AM
Masking Baseboard Depth Issue awaberski Finish Carpentry 50 04-21-2014 07:14 AM
Flooring Co. didn't scribe baseboard, should they pay to cover with 1/4 round? Erikfsn Flooring 44 04-17-2012 10:24 PM
Removing baseboard before tile installtions.. Floormasta78 Tiling 24 10-03-2011 02:19 AM
