Applying Krud Kutter - Painting & Finish Work - Contractor Talk
Old 07-22-2019, 08:47 AM   #1
artinall's Avatar
Trade: Repairs & Finishing
Rewards Points: 1,030
Name fits. Went through some jugs of KK recently and it does what they say. Can honestly say that the solution exceeded my expectations in removing nicotine.
While being reasonable; this might be helpful to some;
- buy many rolls of paper towels for larger projects, discard into a ready lined trash can when wiping.
- do NOT let dry on surfaces like glass or fiberglass (especially at full strength). It may prove more than difficult to get off, possibly etching. Glass may need to be razored. Fiberglass...?
- their red label packaging in the spray bottles does seep away from the inside onto wherever you are setting. Cutting this liner off prevents from happening (mentioned elsewhere here on CT?).
- maker warns that it is an eye and skin irritant. Rubber gloves are a must (cause ear aches?).
- some believe in the extra step/rinse wipe afterward and some don't.
Do believers have a lot of time on their hands?
Anything to add?
artinall is offline
Old 07-22-2019, 09:40 AM   #2
hdavis's Avatar
Rewards Points: 2,076
Re: Applying Krud Kutter
Serious cleaning I put it in a pump up 1 gallon garden sprayer or a 2 1/2 gallon deck sprayer. Deck sprayer is usually for floors.
Scrubbing or wiping I'll use something with a handle as much as possible. Paper towels are for smaller areas.
hdavis is offline
artinall (07-22-2019)
Old 07-22-2019, 11:13 AM   #3
artinall's Avatar
Actually I used paper towels on everything from natural stained windows, trim..to ceiling fans. Going over 2 - 3 times. Was seriously thick..clogged fast..
artinall is offline
Old 07-22-2019, 12:51 PM   #4
hdavis's Avatar
Paper towels except in large flat surfaces like ceilings and walls. For those, I use one designed For floors that you can quick change a Terry cloth cleaning towel. I just buy stacks of the towels and launder them.
hdavis is offline
Old 07-22-2019, 05:33 PM   #5
Caslon's Avatar
Trade: State Licensed Painting Contractor
Rewards Points: 1,366
I've used KK. I prefer JASCO'S No Rinse TSP Substitute. Concentrated, cuts thru smoke/nicotine like you wouldn't believe. KK costs $7.09 per spray bottle. JASCO concentrate make up to 5 gallons for the same price. At Ace Hardware, Tru Value, Amazon, to name a few.
Caslon is offline
The Following 3 Users Say Thank You to Caslon For This Useful Post:
artinall (07-22-2019), hdavis (07-22-2019), MarkJames (07-22-2019)
Old 07-22-2019, 07:12 PM   #6
Ohio painter's Avatar
Trade: Painting and wallpaper
Rewards Points: 2,976
I have used KK several times and it does get the job done. TSP is my go to cleaner and then KK if something heavier duty is needed. I do rinse it afterwards.
Ohio painter is offline
Old 07-22-2019, 08:28 PM   #7
Caslon's Avatar
You can vary the concentration of JASCO in water, making it stronger than KK in some regards. I rinse after JASCO. No-Rinse means you use it at its most diluted, which I never do.
Caslon is offline
Old 07-22-2019, 08:54 PM   #8
Mike-B's Avatar
Rewards Points: 1,248
KK is sold in 1 gallon concentrate for about $14. You mix up a few ounces with water and put in your own spray bottle. It goes a long way.
Never tried the TSP substitute but based on your review may give it a shot.
Sent from my SM-G970U using Tapatalk
Mike-B is offline
Old 07-22-2019, 09:30 PM   #9
artinall's Avatar
KK claims it is eco friendly. Do you rinse to get away the final residue? Or neutralize?
artinall is offline
Old 07-23-2019, 12:13 AM   #10
Caslon's Avatar
Did not know KK came in concentrate, thanks. KK may have surfacants and other chemicial ingredients that JASCO No Rinse TSP concentrate may not have. Either of these products work well. TSP powder is almost archaic. Spic and Span was green colored scented TSP powder.
Caslon is offline
Old 07-23-2019, 05:57 PM   #11
Talking Head
EthanB's Avatar
Rewards Points: 438
I use Dirtex as a standard, light duty, cleaner for paint prep. Used a ton of TSP in the day but the rinsing is a bear and more moisture is rarely a good thing.
Planer.....
EthanB is offline
The Following User Says Thank You to EthanB For This Useful Post:
MarkJames (07-23-2019)
