Poolmanct ...speaking Of Engineers ...steel Schedules - Pool Construction & Enclosures - Contractor Talk
Old 02-21-2007, 02:59 PM   #1
dirt diggler's Avatar
Rewards Points: 2,000
had an engineer suggest 16" OC (throughout entire shell - deep end too)
i think that's cuttin it a little short ...
he did say it would have to be #4 (1/2 in.) vs. 3# (3/8)
but i still think that's cuttin it a little short ....
(my typicals are using #4 at 10" OC in shallow and 5" OC in areas deeper than 3') in the least - it's 12"/6"
(walls & floor)
(typical soil is decent here... i have run into some marine clay....)
Ray ... in your opinion, am I being excessive?
dirt diggler is offline
Old 02-21-2007, 03:18 PM   #2
POOLMANinCT's Avatar
Rewards Points: 1,008
Re: Poolmanct ...speaking Of Engineers ...steel Schedules
no, but i hope your not using a tape measure to space you steel LOL
POOLMANinCT is offline
Old 02-21-2007, 03:26 PM   #3
hehhehe ... i use my boot if there's any discrepincy (sp??)
nah--- actually, i start out aiming for 12" but end up at 10 just cuz im bein conservative the whole time
those days are behind me now ... gets subbed from now on.
(though im sure ill still get in the mix every now and then ... )
Old 02-21-2007, 04:26 PM   #4
ruskent's Avatar
Trade: Outdoor D/B
Rewards Points: 1,028
Dirt- What do you sub out, and what do you do in house?
ruskent is offline
Old 02-21-2007, 04:48 PM   #5
well, im caught between 2006/2007
In 2006
Inhouse
design
excavation
rough-in (plumbing & elec fixtures)
steel
grade (inc. plumbing & conduit run)
decking (if brushed concrete only)
equipment set
final grade
subbed
gunite, tile and coping, plaster, decking (if stamped, flagstone, etc)
in 2007
in house: all plumbing/conduit -- will include grading ... decking still (if brushed finished) ...
rest subbed out
any vinyl and fiberglass installs are done entirely in-house ...
cutting steel studs 25BRIAN General Discussion 35 05-02-2012 02:44 PM
glass coated steel haskl33 Excavation & Site Work 3 10-23-2007 10:33 AM
Brick Veneer on steel angle iron sandyman720 Construction 9 07-15-2007 04:20 AM
steel door problem wmerrell Commercial Construction 12 03-24-2007 03:04 PM
Benefits of Becoming a Civil Engineer plazaman General Discussion 8 01-21-2006 02:58 AM
