Leaving An Inground Pool Empty For How Long? - Pool Construction & Enclosures - Contractor Talk
Old 03-06-2016, 08:35 PM   #1
acro's Avatar
Trade: Electrical
Rewards Points: 661
So I have a pool that has not been opened or used in several years.
We are going to drain it and clean it out
"Liner" is stainless steel. Although "in ground", it is effectively above grade.
What concern should I have regarding the need to get water back in it to keep the sides from deforming or collapsing?
Same concern as if it was a conventional inground?
Deep end is at least 10' deep.
The pool area is above this wall, so groundwater would not be an issue.
acro is offline
Old 03-07-2016, 06:29 AM   #2
hinejs's Avatar
Trade: pool contractor
Rewards Points: 14
Re: Leaving An Inground Pool Empty For How Long?
It's likely that for an immediate need, it's going to be ok to drain. I would not advise keeping it empty any longer than you need to. There are methods to clean and bring back to life without wasting all the water and avoid the risk for structural damage altogether.
Jeremy Hine
-"I fix broken pools, spas, and hot tubs"
Florida Leisure Pool & Spa
hinejs is offline
Old 03-07-2016, 02:44 PM   #3
Peter_C's Avatar
Trade: Home Beautification
Rewards Points: 412
Even though you may think ground water isn't an issue I would error on the side of caution and wait until a while after the rainy season ends.
Peter_C is offline
Old 03-07-2016, 06:24 PM   #4
acro's Avatar
Trade: Electrical
Rewards Points: 661
I would guess there are too many solids in the water to salvage it. I would imagine chemical cost and labor would outweigh just draining and starting over. I am told that in the past neighbors have complained about the smell. Caretaker put over 30 Gallons of bleach in it at that time
The smell is a big concern when we drain it. Probably weight on a good rain to help dilute it
acro is offline
Old 03-07-2016, 07:08 PM   #5
rrk's Avatar
Rewards Points: 76
I once saw a fiberglass pool pop out of the ground in about an hour. I was working inside a house while some landscapers were emptying it instead of cleaning the water that was in there. Trash pumps were going full tilt to empty it and the next I saw the edge of the pool was 5' above ground
rrk is offline
Old 03-07-2016, 07:48 PM   #6
water re-locater
NYgutterguy's Avatar
Trade: Gutter installer
Rewards Points: 1,512
Left my pool empty for a year and finally after a few days of crazy rain the wall collapsed.
If I were you I wouldn't empty it. I didn't open my pool for 4 summers and was nasty green. Took a solid 2 week to get it clear but even the nastiest water with enough chemicals can be re used.
Also costs a crap load to fill
NYgutterguy is online now
Florida Pool Contractor Qualifier Wanted! kelkayne Help Wanted or Looking For Work 3 09-18-2016 05:58 PM
How much do you charge for a swimming pool? 79lance Sandblasting 6 02-19-2016 09:04 AM
Pool concrete cracking Supahflid Pool Construction & Enclosures 2 05-06-2011 07:03 PM
Need pool replastering help CutTwice Pool Construction & Enclosures 0 05-06-2011 12:11 AM
Inground pool light circuit louis bugaj Electrical 28 11-07-2006 11:19 PM
