Leaking Pool Liner - Pool Construction & Enclosures - Contractor Talk
Leaking Pool Liner
Old 08-05-2014, 07:27 PM   #1
TimNJ's Avatar
Rewards Points: 960
Leaking Pool Liner
My liner developed a leak and I really don't want to put in a new one only to close the pool a week later.
Any danger to waiting until next spring to do it? Base is vermiculite/cement.
TimNJ is offline
Old 08-05-2014, 07:47 PM   #2
water re-locater
NYgutterguy's Avatar
Trade: Gutter installer
Rewards Points: 1,512
Re: Leaking Pool Liner
I wouldnt leave it with a hole all winter youre just asking for trouble.
YOutube has some good videos on ways to find the hole and every pool store sells the patch kits and some even come out and do it for you. Liner will never be the same after winter being empty.
NYgutterguy is offline
Old 08-06-2014, 07:12 AM   #3
TimNJ's Avatar
Rewards Points: 960
I plan on having a new liner made and throwing out the old one.
I don't drain the pool down in the winter, only enough to blow all the lines out and fill them with antifreeze.
I was wondering if the water on the base would cause any damage to it??
Probably be kinda nasty and need a good cleaning before the new liner would go in.
TimNJ is offline
Old 08-06-2014, 08:17 AM   #4
water re-locater
Im no pool expert and didnt know a thing about pools until house i bought came with one and i replaced everything but the walls of the pool so treat my advice with caution If you are replacing liner next year i probably wouldnt worry about it. They will add more vermiculite and smooth everything out anyway. Left it empty for a few yeas and had grass growing out of it but after few hours this is how it ended up. Think you should be fine.
sorry pics wouldnt load
Old 08-06-2014, 08:26 AM   #5
General Contractor
greg24k's Avatar
Rewards Points: 48
Tim, call a diver, he will come out, find a leak and fix it right under the water without draining anything... I think they charge in the neighborhood of $200 or something like that.
Someone told me they just had this done, I'm trying to think who it was, everyone I know has a pool. If it comes to me I'll get you the number or try Google it "liner pool repair and diving services NJ" I'm sure you will find someone in your area.
Good luck
greg24k is offline
Old 08-06-2014, 08:35 AM   #6
water re-locater
Good luck
Thats pretty much what my guy locally wanted when i first had issues. 200-300. Guess piece of mind all winter is worth that alone now that i think about it.
The Following User Says Thank You to NYgutterguy For This Useful Post:
greg24k (08-06-2014)
Old 08-06-2014, 08:39 AM   #7
General Contractor
greg24k's Avatar
Rewards Points: 48
This guys are in and out, definitely worth it if the liner is still in decent shape, to get a new one I would assume its a grand or two depending on the pool.
greg24k is offline
NYgutterguy (08-06-2014)
Old 08-06-2014, 08:52 AM   #8
Xtrememtnbiker's Avatar
Trade: General Remodeling
Not to mention cost of water to refill... We worked for a client who I think said it was around $5,000 turn key to re-do his liner. They used the fire hydrant to fill it but some weird thing about that made it cost more cause of the side of the street he was on or something.
Xtrememtnbiker is offline
The Following User Says Thank You to Xtrememtnbiker For This Useful Post:
greg24k (08-07-2014)
Old 08-06-2014, 08:55 AM   #9
water re-locater
I have a 16x36 add exactly what I paid Water trucks were 800 for two loads
Old 08-06-2014, 09:19 AM   #10
If my memory is correct, he said the water cost was around 3k. Sounds like a water truck is much cheaper than fire hydrant. Maybe he had a reason though...
Old 08-06-2014, 09:29 PM   #11
TimNJ's Avatar
Rewards Points: 960
The liner was already having "issues" so I don't plan on saving it.
I filled the pool with my hose. Took an entire day from what I remember.
Had a vacuum running at each end.
Mine is 16x32 sport pool or bow tie pool. It is 6' deep in the middle and the ends are the shallow points (42"). It is designed for laps. That was what the wife wanted so, you know what that means. She's happy doing her laps, me....as my grandson says, "Pops swims like a rock"
TimNJ is offline
Old 08-06-2014, 10:01 PM   #12
water re-locater
Few years ago I had a tiny hole in my liner also
Old 08-06-2014, 10:50 PM   #13
POOLMANinCT's Avatar
Rewards Points: 1,008
Letting a cement / vermiculite bottom winter over with less than 12" of water on the shallow end floor, will likely add 4 to 5 grand to the replacement cost. There is no rebar or steel in in vermiculite or 3 to1 mix subbase, they shatter, shift or turn to mush without water weight.
Not to mention 8lbs per gallon giving the walls lateral support.. If the walls slip, it's time to dig up perimeter & pull them true.
If $ allows replace prior to winter, if not have it patched. Don't leak during a northeast winter.
Ray
......Less with the jaw & More with the paw.....
POOLMANinCT is offline
Old 08-07-2014, 06:17 AM   #14
TimNJ's Avatar
Rewards Points: 960
Ray
That was my concern. If water against the base would harm it.
The pool is still full, just that there is water behind the liner now and it caused the corners to float out. I would not drain the pool down for fear the water table rising in the winter and pushing up the base, not to mention the freeze thaw damage.
TimNJ is offline
Old 08-07-2014, 06:21 AM   #15
TimNJ's Avatar
Rewards Points: 960
How long did it sit??
TimNJ is offline
Old 08-07-2014, 06:34 AM   #16
water re-locater
Couple years. One if the walls collapsed while was empty so ended up being a bit more than just a liner replacement 7 years after new liner it still looks great
TimNJ (08-07-2014)
Question on compacting soil around a pool BCConstruction Masonry 14 09-26-2012 05:38 PM
Local SEO NickWasHere Marketing & Sales 48 04-01-2010 06:48 AM
In ground pool liner mgmmike Pool Construction & Enclosures 9 06-12-2007 08:30 PM
