Excavation 2 - Pool Construction & Enclosures - Contractor Talk
Excavation 2
Old 02-23-2007, 11:11 PM   #1
denick's Avatar
Rewards Points: 1,000
Excavation 2
Do your pool excavations require that fill material be hauled away?
How many cubic yards on average?
Do your job sites usually allow more than 1 truck to be used to haul fill out?
Do you haul fill in a percentage of the time?
Do you have your excavator haul in stone for beneath the pool?
Nick
"Every day I remind myself that my inner and outer life are based on the labors of other men, living and dead, and that I must exert myself in order to give in the same measure as I have received and am still receiving" Albert Einstein
denick is offline
Old 02-24-2007, 12:49 AM   #2
dirt diggler's Avatar
Rewards Points: 2,000
Re: Excavation 2
I give the clients two options. They can either pay to haul it away ... or they can pay for extra time in grading out excavated dirt (if their yard size allows for it)
Usually, I count on around 15-20 truck loads for hauling out (20 ton loads each)
So that's about 300 tons ... which is about i guess 200 cub yards????
best to do T&M (imo) so you don't get stuck coming up short on a lump sum.
haul fill in a percentage at a time ... i don't understand what you mean here ...
yes - you can have more than one truck going in and out ...
yes, after the pool is excavated -- I smooth out a base of 57 stone. I do this a thickness of at least 6 inches.
Most of the time I can get it spread out with the bucket
Other times, I have to jump in the hole and shovel it
Almost always end up having to jump down anyways and rake it out
I like doing it b/c it gives a more firm base than just leaving it as "dirt."
Also, when it rains or if there is groundwater --- it won't turn into a mud pit and it's just more comfortable to walk around in
dirt diggler is offline
Old 02-24-2007, 09:56 AM   #3
ruskent's Avatar
Trade: Outdoor D/B
Rewards Points: 1,028
Re: Excavation 2
Dirt what is the average size of your pools?
ruskent is offline
Old 02-24-2007, 10:16 AM   #4
denick's Avatar
Re: Excavation 2
dirt, out of 100 pools you did last year how many did you have to import fill for?
And how many CY did you bring in?
Nick
denick is offline
Old 02-24-2007, 10:19 AM   #5
Re: Excavation 2
Right now, i consider an average size to be 800 sq ft
but there is no "typical"
they always end up being a little bigger (just in case someone wants to take the time and figure out - "hey, this pool's only 798 sq. ft. --- you owe me 2 more sq. ft.)
so in design, I'll add a little bit more sq. footage (i.e. I'll design it at 820)
even with a perfect excavation --- a large rain can come through the next day and cave a section of a wall in. Essentially a "florida hole"
what REALLY sucks is having the steel in and then this happens. Leads to a lot of hand work ... and if severe enough (thankfully haven't had to do it yet) - redo the steel
So ... from now on ... I make sure to get steel in quickly, and gunite asap
Part-time excavation business Big Chris Excavation & Site Work 24 03-04-2007 07:11 PM
Excavation 5 denick Pool Construction & Enclosures 2 02-24-2007 11:54 PM
excavation 4 denick Pool Construction & Enclosures 14 02-24-2007 11:19 PM
Success of Excavation Companies mattbatson Excavation & Site Work 32 12-15-2006 08:09 PM
looking to buy excavation business sutton82 Excavation & Site Work 8 06-29-2006 02:31 PM
