Zero Threshold Pan Options - Kitchens & Baths - Contractor Talk
Old 03-10-2016, 03:59 PM   #1
dsconstructs's Avatar
Trade: Remodel Contractor
Rewards Points: 872
Looking for suggestions on zero threshold pans.
Monday I'll be installing a Tuff Form pan, it's going to replace what was a tub/shower. Customer already planned/purchased ahead of time and even demoed the tub/surround before realizing he was in over his head on getting the plumbing changes/blocking etc. So I'll be making that happen, installing the Tuff Form, and surround walls before he takes back over. It's open web joists and and the drain location is barely going to work, and that's after furring out the back wall about 1 1/2" inches.
He also wants to do the upstairs shower with zero threshold and I'm hoping there's something similar to Tuff Form but with a centered drain.....to match what's already there. Since Tuff Form has the offset drain I'm a little concerned if that upstairs gets demoed only to find out similar issues with joists/offset drain location since the layout won't readily lend itself to furring if need be. Open web joists.....so I don't wish to play with those at all either.....
dsconstructs is offline
Novice question - hardwood flooring and exterior threshold furlong General Discussion 29 08-15-2015 08:57 AM
Options when you run into asbestos cutback platinumLLC Flooring 12 02-20-2015 07:15 AM
Exterior wall covering options? bob_cntrctr Construction 8 02-25-2013 08:05 AM
Soffit Options for this home plazaman Windows, Siding and Doors 4 07-11-2012 09:41 PM
Threshold or whole new door / framing? sbellerby Windows, Siding and Doors 12 07-11-2009 08:56 PM
