#21 |
LRG WoodCrafting
![]() ![]() Trade: Maker of Fine Sawdust
Rewards Points: 2,685
Re: The War Of Plywood VS Particle Board
My doors and FF's are made from 13/16". It is amazing what that 1/16" does in heft of the door. I use the 5/8" Euro Maple (9 ply, similar to Baltic birch but Maple) just for the labor savings. It is almost as much as solid wood. Latley I have been paying $110 for a 4 x 8 sheet. When I first started buying it it was $77. I've made a few pocket screw drawers, but I find that using dovetails is almost as fast to build.
Sawdust Follows Me Everywhere I can explain it to you, but I can't understand it for you. Sanding is the bane of my existence WWG1WGA http://lrgwood.com Custom Cabinets in Hartford County Connecticut |
Warning: The topics covered on this site include activities in which there exists the potential for serious injury or death. ContractorTalk.com DOES NOT guarantee the accuracy or completeness of any information contained on this site. Always use proper safety precaution and reference reliable outside sources before attempting any construction or remodeling task! |
Advertisement |
#22 |
Still have all my fingers
For water resistance MDF is not a good choice unless you use an MR version. It also has a tendency to split when driving in fasteners however it does have some redeeming qualities. I use premium grade Ranger MDF for some of my finished ends and I have found that it's tough to beat for smoothness and stability.You can also get it in a class 1 fire rated version (Medite) which is required for some commercial applications.
Killing the Earth, one raised panel at a time....... http://bergstromcabinets.com http://minneapoliscabinets.biz http://maplegrovecabinets.com |
#23 |
TKO-TotalKitchenObsessed
Trade: Kitchen and bath design
Rewards Points: 502
I dont understand some of you guys sarcasm to a PB. I do understand and argue it's superiority.
What I want to know is why do those who build cabinets feel their product is superior because they do 3/4" sides and 1/2" back? For farts sake. Explain overkill to me. Some major brands use 3/8ths side panels with quarter inch backs. I have installed more then 6000 kitchens and never ever had a product failure and never in my life did I install a 3/4" box. I do agree with whomever above laughed at the thick maple drawer boxes. To me that is a bit overkill too but all the major manufacturers offer it. Half inch baltic birch is just fine but only if you edge band it. Exposed plys is horrible.
If you don't push to be perfect in everything you do, then you will always remain just average. |
Sponsored Links | |||
Advertisement |
#24 | |
Focusing on solutions.
![]() Trade: hardwood floor contractor & so much more
Rewards Points: 72
Re: The War Of Plywood VS Particle BoardQuote:
#25 |
Trade: contractor
Well I seen a bigfoot once.
#26 |
LRG WoodCrafting
Plywood is inherently stronger. Plywood is lighter in weight, most of my clients believe that PB/MDF is "cheap". PB and MDF will deflect more than the equivalent of plywood. Plywood holds screws better, doesn't crumble. If PB or MDF gets wet it will swell, and then never go back. If plywood gets wet it will swell and then go back to its original size after it dries out.
PB and MDF do have benefits. It is usually a flatter surface and doesn't have waves the way plywood can because of the multilayer cores. I don't like PB or MDF as much as I prefer plywood.
#27 | |
Rewards Points: 502
I would like to say that I was here right after Hurricane IKE. 20,000 homes were destroyed on Galveston Island. When homeowners came back home the first thing they did was try and salvage any valubles. The 2nd thing they did was to throw out everything that was soaked and ruined out to the curb for pick up. Let me tell you that there were just as many so called all wood cabinets at the curb as there were partical board ones. Whatever the case, thanks for chiming in. I would really love to see more from fellow cabinet professionals.
#28 |
LRG WoodCrafting
You can't submerge any woodwork for any amount of time and expect it to survive. A solid wood floor will buckle and twist with just a bit of water. But after it dries out it is possible that you can recover it. If you had a particle board floor it would have turned to mush.
I would have thrown my cabinets out too if they were soaked with foul water.
#29 | |
I am glad you haven't had any failures with your products yet but it only takes one to potentially put you out of business and that is a risk I am unwilling to take.
#30 | |
#31 |
LRG WoodCrafting
Especially when they are gonna buy you new ones.
#32 |
Trade: Flooring & cabinetry
Rewards Points: 268
Jimmy is right that technology changes, so maybe some PB is better than it used to be. I haven't investigated it. But I bet it also costs more than the cheap PB we are all used to seeing, and I'm certain that all cabinet manufacturers have NOT changed to only the best quality stuff. Most that are positioned to be cheap use the cheapest stuff they can get by with.
Reality is if you know the details of some of the brands you can upgrade to plywood on some brands for very little difference. One brand we carry is Armstrong. To price we take list price x our multiplier, which varies depending on which particular cabinet we are pricing. Usually the upgrade to "Allwood" is 1 point more. (For example, 43% for PB, 44% for plywood.) And Jimmy is right, not all plywood is equal. But if you are buying plywood cabinets who are getting their plywood for the sides on their cabinets from Lowes or HD I bet you have bigger problems. I'm with the people in his client base that think I should have him doused with holy water if he tells me to buy PB cabinets. If there is enough water damage anything is going to fail. But too many times that screws have wallowed out of particle board to make me feel good about it. Personally, if I'm going to invest the money in a new kitchen, what's maybe 1/2% more on a job to do plywood? Let's say you are doing a $14,000 kitchen remodel. To upgrade from PB to plywood on Armstrong cabinets might be as little as $150 to a customer. I usually actually eat it and just upgrade them without even telling them except to let them know they are getting an "Allwood" cabinet. Now let's say it's a $40,000 remodel and the upgrade might be $300 to the client. Wouldn't you do it? Granted, a lot of brands really jsck up plywood sides. That's why you need to work with someone who knows details on products to gived the pros and cons. |
#33 |
LRG WoodCrafting
And before you tell us that PB and MDF are real wood, let me just say it isn't wood unless it has grain and fiber direction.
#34 | |
Rewards Points: 502
Every now and then I would talk to a customer who was told a cabinet had to have 3/4" sides or the weight of the granite would crush it. Since I am most familiar with Merillat brand, the oldest and largest cabinet company on earth, I can tell you they install millions and millions of boxes each year. Their PB side panels are 3/8" thick (upgraded plywood sides 1/2"). Never has one ever failed due to thin side panels by the weight of granite. In short lengths, using proper cabinet joinery and a combination of hot melt glue and staples a PB box carcus is just as strong as any plywood box. And it is more stable then a plywood box. We have sent back cabinets with wood sides that were warped. I can say back up....those who assembled those boxes should have discarded these warped panels or I can say this problem never happens with PB. Maybe the plywood panels warped well after assembly and during delivery. Whatever the case I'm glad to hear your other views on this topic.
#35 |
Rewards Points: 2,000
Nice to see opposing points of view, i personally prefer plywood for all the reasons already listed here, the general public, for the most part associates PB with crap, and rather than educate them since i prefer plywood, i most often use it, dont get me wrong, there is a time and place for PB, but IMO cabinets are not the best place to use PB.GMOD
#36 | |
Rewards Points: 502
#37 |
LRG WoodCrafting
I still cringe at the amount of plastics used on the exterior of the vehicles today. On the interior it is fine because you can mold it to the intracate shapes required by the designs of today's cars.
Now, if they built everything out of credit card plastic then those things would be indestructible.
#38 | |
Nobody follows AWI specs? Really......I think there are a several thousand architects in this country that would beg to differ. Out of the thousands of blueprints that I have worked off of over the years I have never seen a KCMA spec even mentioned. Would you be comfortable having your kids play around a 5 x 8 granite island top supported by 3/8" PB cabinets? If your answer is "we do it all the time and we have never had a problem" then I would seriously look at taking out one hell of an insurance policy
#39 | |
Rewards Points: 502
I believe you are one of those cabinet sales people who are misleading your customer for your gain. Quality cabinets will get a KCMA sticker. 6000 kitchens and 29 years and I have never seen an AWI sticker. I am not even aware of AWI making any guidelines for cabinet manufacturers to follow. If they do then no one is following their guidelines. 3/4" boxes are overkill and a waste of money for the consumer and a waste of material. All that aside, if I was still installing full time and I came across a product with half inch backs that I had to cut out pipe and outlet holes for I would quickly stop using that product. Half inch backs are even more dumb then 3/4" sides. Why not just do 2" thick face frames? It would make a stronger box.....right?
#40 | |
You're also wrong about something else too.....I am not a salesman,I am a cabinet maker. This stuff sells itself Advertisement
Display Modes | Rate This Thread |
Thread | Thread Starter | Forum | Replies | Last Post |
Particle Board question please | davinci | Construction | 18 | 09-19-2012 07:45 AM |
determining skirt board height | romoranger | Finish Carpentry | 2 | 07-07-2009 01:46 PM |
Tips for removing Glued Particle Board? | redragon19 | Flooring | 3 | 03-17-2009 09:38 PM |
Plywood over particle board | PA woodbutcher | Flooring | 5 | 03-11-2009 06:09 AM |
Plywood direction effect on floor bounce over I-Joist | personalt | Framing | 25 | 12-31-2008 05:28 PM |
Go to Page... |
