Tub Wall Bull-nose ? - Kitchens & Baths - Contractor Talk
Old 11-26-2015, 03:01 PM   #1
Dave in Pa's Avatar
Trade: restoration/remodeling
Rewards Points: 1,272
I am currently doing the tile on the tub wall on a job. My boss and I see the bull-nose as a different way of doing it, so what is correct, or how should it be done? I have done lots of floor tile, but few tube surrounds, never with the front edging outside of the tub area!
The tile is 10" high to start with a accent strip in the middle going up. I say run the nose from the floor, tub approx. 16" high and run full edge up with a cut at the ceiling, let the joints be staggered.
He wants to start at the floor, run to tub, cut, run 3 full rows to line up with the 3 rows of 10" then 4" of accent, then run with the 10" again, line up the joints of the bull-nose with the tile?
What do you guys do, and what is correct, or looks best??
Thanks, Dave
Dave in Pa is offline
Old 11-26-2015, 04:01 PM   #2
goneelkn's Avatar
Trade: home remodel/repair
Rewards Points: 26
Re: Tub Wall Bull-nose ?
How does the customer want it??
I've done random and matched joints. If done your boss' way, work down so the bottom one is cut. Don't do a random cut to equal top of tub.
goneelkn is offline
Old 11-27-2015, 12:14 PM   #3
CarpenterSFO's Avatar
Rewards Points: 2,044
Though I'm inclined toward your way - the bullnose is a frame, not a continuation of the field - either way is fine. If you do it your boss's way, the 4" piece has to be perfect.
- Bob
CarpenterSFO is offline
Old 11-27-2015, 01:28 PM   #4
avenge's Avatar
Rewards Points: 110
I never match grout lines with the field tiles especially if using an accent tile in the field.
avenge is online now
Old 11-27-2015, 03:40 PM   #5
Fugetaboutit
Lunicy's Avatar
Trade: Professional fixer upper
Rewards Points: 444
Just so you know, sometimes the bull nose isn't the same exact size as the field. Starts looking funky after a few tile.
Lunicy is offline
Old 11-27-2015, 03:40 PM   #6
dsconstructs's Avatar
Trade: Remodel Contractor
Rewards Points: 840
I would run full length bullnose the entire length except for at ceiling/floor as needed. I'd plan it so that a bullnose seam didn't land within that 4" accent area and keep the other seams from lining up as well that way.
dsconstructs is offline
Wobbly shower wing wall Layinpipe Framing 0 02-25-2015 11:26 PM
Leveling wall for tile. DKnafo Tiling 32 06-04-2013 10:56 PM
Retaining Wall Rebuild Dovetailed Landscaping 22 03-31-2012 08:02 PM
New furred 2 x 6 wall infront of concrete block wall. huntch3 Construction 11 03-27-2012 06:39 AM
removing a retaining wall Cache Excavation & Site Work 30 07-16-2008 04:57 PM
