Shower Walls - Kitchens & Baths - Contractor Talk
Shower Walls
Old 02-18-2012, 11:33 AM   #1
madmanski123's Avatar
Shower Walls
When you use Densehield in the bathroom for shower walls (tiled after), does anyone put building paper on the studs first, then the denseshield?
madmanski123 is offline
Old 02-18-2012, 11:35 AM   #2
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
Re: Shower Walls
What would be the reason to do that? DensShield already contains a waterproof coating.
Angus
angus242 is offline
Old 02-18-2012, 11:37 AM   #3
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Re: Shower Walls
Or the more obvious if water gets that far your shower has failed and needs replaced.
ohiohomedoctor is offline
Crack in prefab shower pan. Can it be repaired? wopachop Plumbing 30 09-30-2011 08:26 AM
Tub Shower Valve for shower only... Repairman615 Plumbing 6 05-30-2011 02:05 PM
Strange shower leak - need help JSMHDM Plumbing 13 12-06-2010 05:38 AM
GreenBoard vs. DuraRock/Mud walls For A Steam Shower Longghairr General Discussion 19 11-06-2009 12:05 AM
39in Kohler shower with walls zukkoor Contractor Swap 15 02-01-2008 09:58 AM
