Shower Tear Out/re Build - Kitchens & Baths - Contractor Talk
Old 02-21-2011, 09:06 PM   #1
Pro Grade Flooring LLC
Ed4x4's Avatar
Trade: Flooring: Carpet, Wood, Laminate
Rewards Points: 77
Ive got a question, not so much about a shower build, but shutting the water off. This is my first tear out and rebuild, so far they've all been new construction. I've got one to go bid on and Im curious how to go about dealing with the water being shut off. Its a bath/shower wall, so no pan to deal with, just the walls.
This is an older house, and it does not have a shut off at the shower, just a house shut off. Im timing the job for three days max, hopefully just two. But how do you guys go about shutting off an occupied house for two days. The homeowners arent going to like it, but I dont have a choice.
Carpet, Wood, Laminate, Tile
Ed4x4 is offline
Old 02-21-2011, 09:08 PM   #2
Level 27 Contractor
Bastien1337's Avatar
Trade: Renovation
Re: Shower Tear Out/re Build
shut off the water in the house,
cut water in bath area,
install shut off for that area,
turn water in house back on,
work on bathroom at your leisure
Sebastian
Check out my gallery here http://on.fb.me/I2XylV
Check out my blog here http://sebastianbethke1337.wordpress.com/
Bastien1337 is offline
Old 02-21-2011, 09:08 PM   #3
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Shut offs? Three days? Good luck......
http://www.ohiohomedoctorremodeling.com
ohiohomedoctor is offline
Old 02-21-2011, 09:09 PM   #4
katoman's Avatar
Trade: carpenter
Rewards Points: 2,000
Easy, I'd have my plumber install a shut off valve.
katoman is offline
Old 02-21-2011, 09:09 PM   #5
avguy's Avatar
Trade: A/V, Renovation
Rewards Points: 250
Shut it off long enough to rough in and cap off the lines or to add some valves that allow you turn off the supply to the shower.
( I put effort into using good grammar, and 3 guys beat me to the punch )
Philip LaDue
Empire State Light and Sound
646-397-5028
avguy is offline
Old 02-21-2011, 09:10 PM   #6
Chief Reporter of Spam
Tech Dawg's Avatar
Trade: Kitchen and Bathroom Remodeling
Rewards Points: 1,290
Shut off the main and cut your supply lines and add some ball valves or your shower valve should have shutoffs on it... you can buy them that way.
Todd
Alone Eagle Remodeling, LLC
Tech Dawg is offline
Old 02-21-2011, 09:10 PM   #7
katoman's Avatar
Trade: carpenter
Sebastien beat me by one minute.
katoman is offline
The Following User Says Thank You to katoman For This Useful Post:
Bastien1337 (02-21-2011)
Old 02-21-2011, 09:14 PM   #8
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
The shower valves I deal with have a built in shut off right on the valve.
Turn water off, install new valve, have valve shut offs...off, turn water to house back on. Install capped stubs for shower head and tub spigot. When time to install final fixtures, remove shower valve stub (save for future use) and cut cap off tub spigot. Install finish plumbing, turn on valve shut offs.
Angus
angus242 is offline
Old 02-21-2011, 09:15 PM   #9
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Or what everyone else has just said in the previous 3 minutes
Angus
angus242 is offline
Old 02-21-2011, 09:16 PM   #10
Tech Dawg's Avatar
In the right situation I can move really quick and accurate to do a swanstone tub replacement with walls and valve in a day...but usually 2 or 3 days... I honestly don't see how your gonna do this in 2 if your tiling, good luck!
Todd
Old 02-21-2011, 09:17 PM   #11
Level 27 Contractor
Trade: Renovation
these are the shark-bite caps, they are super easy and fast to use, just slip them on and work away. when you are ready to deal with that pipe shut the main water off and slip off the cap and go.
best part about it is the cap is reusable
now thats using your a$$
Sebastian
The Following User Says Thank You to Bastien1337 For This Useful Post:
Ed4x4 (02-21-2011)
Old 02-21-2011, 09:29 PM   #12
Ed4x4's Avatar
Rewards Points: 77
I dont think the plumber will be an option. I've tried talking them into it but they're selling the house and want to put as little as possible into it.
Thank You! Thats exactly what I need! Did not know about these, but thats perfect. Awesome.
Ed4x4 is offline
The Following User Says Thank You to Ed4x4 For This Useful Post:
Old 02-21-2011, 09:32 PM   #13
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
I would make sure those quick connects are acceptable for this scenario.
Some plumbers are not a fan of those. What if the seal blows out in a few years?
Angus
angus242 is offline
Old 02-21-2011, 09:34 PM   #14
Level 27 Contractor
Trade: Renovation
what if a joint isnt soldered all the way and it fails in a few years, what if someone drives a screw through a pipe during a future renovation.
what if a pex connector isnt crimped all the way..............
Sebastian
Old 02-21-2011, 09:35 PM   #15
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 438
Gonna be tough to do that job in two days without a plumber. The fact that you never heard of a sharkbite, nor had any idea how to bypass the water tells me you are gonna be on the plumbing for a while. Not sure what your daily rate is, but a plumber would be in and out in a jiffy!
Warren is online now
The Following User Says Thank You to Warren For This Useful Post:
tazmanian (02-24-2011)
Old 02-21-2011, 09:36 PM   #16
Tech Dawg's Avatar
For all that, shut the water off once and use the Sharkbite Ball Valves....
Todd
Old 02-21-2011, 09:39 PM   #17
Level 27 Contractor
Trade: Renovation
dont know if this is available by you but you can use it as well same type of system
http://www.dahlvalve.com/products/quickgrip.aspx
Sebastian
Old 02-21-2011, 09:39 PM   #18
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Even a properly installed quick-connect seal can fail. Just sayin....
A plumber would (should) test his installation.
A future renovator shouldn't be a concern to the OP. However, any place where a line is run should have a screw protector installed.
Angus
angus242 is offline
Old 02-21-2011, 09:41 PM   #19
Level 27 Contractor
Trade: Renovation
im starting to think that if angus didnt come up with the smart idea, he gets argumentative
Sebastian
Old 02-21-2011, 09:44 PM   #20
katoman's Avatar
Trade: carpenter
Just my opinion, but I tell the HO what's needed, not the other way around. If I need plumbing done, the plumber comes. Period.
I won't do plumbing due to the liability issues.
katoman is offline
The Following 2 Users Say Thank You to katoman For This Useful Post:
Bastien1337 (02-21-2011), MAULEMALL (02-24-2011)
High ceilings and frameless shower skipdow Kitchens & Baths 9 10-14-2010 10:16 PM
Re-tile a shower joekool02 Remodeling 38 09-23-2010 04:30 AM
Unique advice on mudding shower pans. bob_cntrctr Tiling 29 08-01-2009 09:59 PM
leaky shower head Sir Plums Alot Plumbing 3 04-07-2009 08:25 PM
Questions on Tiled Shower ksensen Remodeling 10 09-10-2007 08:54 AM
