Shower Base Squeaking - Kitchens & Baths - Contractor Talk
Old 04-03-2015, 11:30 AM   #1
fishaf36's Avatar
Rewards Points: 18
I am installing a round acrylic shower base on a cement floor. The base squeaks really bad. The floor is not level so i started shimming with wood shims. It started to squeak worse. I am getting frustrated with the shims. The base is acrylic with a foam backer. My question is has anybody set this type of base in a mortar bed. I was thinking on using a 1/4 x 1/4 or 1/2 x1/2 trowel. Would I make things worse if I were to do this?
Thanks
fishaf36 is offline
Old 04-03-2015, 12:01 PM   #2
General Contractor
greg24k's Avatar
Rewards Points: 8,660
Re: Shower Base Squeaking
Thanks
Why don't you level the floor, make sure there is no flexing in the subfloor and follow shower pan manufacturer installation instructions. This way you don't have to deal with shims and waste time and money on all other bs.
Good luck
greg24k is offline
Old 04-03-2015, 12:18 PM   #3
dsconstructs's Avatar
Trade: Remodel Contractor
Rewards Points: 870
I always set that type of pan in mortar but no notched trowel. Just mix it up and pourspread it out on the slab where the base will be sitting on it and wiggle/work the pan down to level. Depth of mortar depended on floor level and pan design.
Some of those pans come with a felt sheet to place under the pan, supposed to help eliminate squeaks on slabs....but I've never used it. Mortar takes care of everything and makes for a nice solid base.
dsconstructs is offline
Old 04-03-2015, 02:15 PM   #4
avenge's Avatar
Rewards Points: 298
Slc
avenge is offline
Old 04-03-2015, 03:30 PM   #5
Renaissance Man
superseal's Avatar
Rewards Points: 5,846
I always set my Mustee brand bases in mortar - the one I have at my house will dent soap if you drop it
No dry pack, mix it like brick mortar and get every nook and cranny.
supersealconstruction.com
superseal is offline
Old 04-03-2015, 03:53 PM   #6
Joemack1's Avatar
Rewards Points: 382
Put a piece of plastic over the wet concrete to separate it from the shower pan. If you don't use enough concrete this helps keep the mess down so you can add more concrete.
Joemack1 is offline
The Following User Says Thank You to Joemack1 For This Useful Post:
Old 04-03-2015, 04:53 PM   #7
GO Remodeling's Avatar
Rewards Points: 96
Also, don't step into the pan to squish it down or level it. Once you step out, the pan flexes back up and when dry leaves a hollow spot enough to flex and squeak.
GO Remodeling is offline
Old 04-03-2015, 04:55 PM   #8
Rewards Points: 96
Good enough to read again!!
Old 04-11-2015, 08:09 AM   #9
fishaf36's Avatar
Rewards Points: 18
Thanks for the responses. Put the pan in a mortar mix. Worked well.
fishaf36 is offline
The Following User Says Thank You to fishaf36 For This Useful Post:
dsconstructs (04-11-2015)
DIY shower...had to "share" jarvis design Tiling 12 04-17-2011 01:49 PM
Strange shower leak - need help JSMHDM Plumbing 13 12-06-2010 05:38 AM
Flat Shower Base Slowtrawl Plumbing 3 02-21-2010 11:24 PM
Tiled shower leaks...Could use any advise at all... Jay22 Tiling 17 12-10-2008 07:15 PM
Mix under shower base and tubs Jbrad4d_iv Plumbing 3 04-02-2008 10:35 PM
