Screws For Cabinets - Kitchens & Baths - Contractor Talk
Screws For Cabinets
Old 02-28-2011, 04:01 PM   #1
Old Crow's Avatar
Trade: General Contractor and Remodeling Contractor
Rewards Points: 91
Screws For Cabinets
Do you all use trim head screws or normal bugle head screws to fasten cabinets together? I have always used trim head to hide to screw. Just wondering if bugle head would be better.
Old Crow is offline
Old 02-28-2011, 05:13 PM   #2
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 388
Re: Screws For Cabinets
Have a look at this thread.
Tinstaafl is online now
Old 02-28-2011, 05:42 PM   #3
Old Crow's Avatar
Rewards Points: 91
I am not talking cabinet to wall i am talking about cabinet to cabinet through the stile. I always use grks or fast caps to screw into studs.
Old Crow is offline
Old 02-28-2011, 06:05 PM   #4
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 388
Sorry about that. Trim head here, whatever I can do to make the fasteners as nearly invisible as possible. They shouldn't need to have an incredible amount of holding power.
Old Crow (02-28-2011)
Old 02-28-2011, 06:09 PM   #5
Construction Connoissuer
CCCo.'s Avatar
Trade: Construction Remodeling - Renovations Repairs
Location: Kirklin, IN "Proudly Serving Central Indiana Area"
Rewards Points: 1,320
I always used "cabinet" screws, but now that you mention it,
you guys might have me rethinking it the next time I need to do it.
James Crow - Crow Contracting Company, LLC - Central Indiana Remodeling Contractor
Facebook l Youtube l Merchant Circle
Home, Kitchen & Bath Remodeling - ~ - Facility Maintenance & Repair Solutions
Want to contact us? - Call ~ 765.279.8271
CCCo. is offline
Old 03-03-2011, 10:44 PM   #6
Denis421's Avatar
Trade: Kitchen Installs
I use GRK exclusively, including their trim screws for cab to cab mating. Those along with the "Pony Cabinet Clamps" (Google it) makes for a perfect installation. They not only clamp the cabs together, they also line up the faces. On a second note, just putting my two cents in (new to here) I don't use the prepacked 2" wide shims to level base cabinets. Granite tops are heavy and the sides of the cabinets tend to mold to these narrow shim pieces. This leads to stressing the top. I use the bundled shims, they have more surface.
Denis421 is offline
Old 04-29-2011, 10:05 PM   #7
Giving it my best
RS Sam's Avatar
Trade: Cabinet Maker and Residential Remodeler
Rewards Points: 512
Exactly
RS Sam is offline
Old 04-29-2011, 10:14 PM   #8
Carpe Diem
angus242's Avatar
Trade: Smile 4 Tile
Rewards Points: 1,114
I use these screws for hanging cabinets.
Use these for connecting cabinets.
Angus
angus242 is offline
Old 04-30-2011, 08:20 AM   #9
Kent Whitten's Avatar
Rewards Points: 2,040
Trim heads (grk) for stile to stile. Try to get them under the hinges, angle top and/or bottom. Sometimes mid stile. Color match Mohawk stiks fill the counter sink on obvious ones almost disappear.
SalmonFallsCabinetry.com
Kent Whitten is offline
Old 05-15-2011, 05:16 AM   #10
Veterans Drywall Repairs
vetsdrywall's Avatar
Trade: Owner/carpenter/drywaller
Angus is 100& on this one- if you use anything else...well, you just wouldn't want to!
vetsdrywall is offline
Old 08-16-2011, 09:14 PM   #11
pro
hangit's Avatar
Trade: wallpaper & fabric installation
Rewards Points: 527
What size for the stiles? 8x2, 8x2.5?
Couldn't find the GRK 3" cab screws anywhere in Atlanta, even after calling the rep. He kinda made it sound like no one really uses them cause they're not familiar with the best.
These are for my kitchen I'm doing myself, used the 3" Grip Rite exteriors, grabbed great.
Now just gotta find & know what size trim heads to pull the faces together.
hangit is offline
Old 08-17-2011, 06:29 PM   #12
pro
hangit's Avatar
Rewards Points: 527
hello, :tap::tap::tap: is this thing on? Anyone, best size trim head to pull the stiles together?
hangit is offline
Old 08-17-2011, 07:04 PM   #13
WildWill's Avatar
Rewards Points: 504
Assuming you have 1 1/2" stiles you would use the 2 1/2" GRKs. I only install one lower at a time and then tie the stiles together, then the next lower etc... As for the uppers, I install them first and I do so as a unit. So I join them all together, then install the lot. All the doors, and shelves are removed and I have the screws in the back waiting for when we lift it. Best to have everything done before getting the unit in the air.
WildWill is offline
Old 08-17-2011, 07:05 PM   #14
dsconstructs's Avatar
Trade: Remodel Contractor
Rewards Points: 842
2 1/2" here
dsconstructs is offline
Old 08-17-2011, 08:47 PM   #15
pro
hangit's Avatar
Rewards Points: 527
Thanks! I'll get the 2.5's tomorrow.
I'm doing these by myself, so it's one at a time. Got all the uppers up, except one over the fridge. Previous owner must have had a Jenn-Air or Sub-Zero, the outlet is about 8' up the wall.
I assembled these in my l/r and I think I might have to dis-assemble part of the corner base, think it's too big to get thru the doorway from the d/r to the kitchen.
I do wallcovering and originally from Fla where I helped a buddy who does high-end cabinets & furniture. That experience is all coming back (except for the screw size), and I'm actually having fun.
Thanks again!
hangit is offline
Old 08-17-2011, 09:03 PM   #16
Can I get an Amen?
Aaron Berk's Avatar
Trade: Custom Woodworks
Rewards Points: 1,060
I use glue and dowels
JK trim heads work the best, and I love my cabinet claws (pony clamps) for positioning
Aaron Berk is offline
Deck Screws vs Joist Nails subybohn Decks & Fencing 105 06-25-2018 06:54 AM
Vinyl Window Screws Wayfarer Doors Windows, Siding and Doors 12 11-23-2010 12:11 AM
Laminating screws secure? Ted White Drywall 10 05-17-2010 12:33 PM
GRK Torx-Head Screws - Anyone Else Like Em? BuildersII Tools & Equipment 25 02-20-2010 11:50 AM
Slotted screws and other peeves! WNYcarpenter General Discussion 31 10-10-2009 11:30 AM
