Range Hood Required For Elec Range? - Kitchens & Baths - Contractor Talk
Old 02-19-2015, 05:34 PM   #1
Justin K
builder2345's Avatar
Trade: Remodeling & general contracting
Rewards Points: 269
I'm trying to find out if a range hood or any means of exhaust is actually required for an electric range/ oven in a kitchen. I've looked in the 2009 Codebook, and haven't found the direct answer yet. It states what kind of piping to use for ductwork and that it has to be vented outdoors, but I haven't found where it says if its required. I'm assuming its required, but I would like to know for sure.
Thanks
builder2345 is offline
Old 02-19-2015, 05:54 PM   #2
TimberlineMD's Avatar
Rewards Points: 738
Re: Range Hood Required For Elec Range?
IRC does not require venting. If you do vent then it has to be vented to the outdoors unless manufacture allows its appliance to be ductless
It's easy to have a business that is busy.. it's harder to have a business that makes a profit
TimberlineMD is offline
The Following User Says Thank You to TimberlineMD For This Useful Post:
builder2345 (02-19-2015)
Old 02-19-2015, 06:16 PM   #3
Justin K
Rewards Points: 269
Is it not required just for electric? Or gas as well?
Old 02-19-2015, 06:22 PM   #4
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,006
Not required for any type of range. However, your local code could require it. Best to check with your AHJ.
Tinstaafl is offline
The Following 3 Users Say Thank You to Tinstaafl For This Useful Post:
builder2345 (02-19-2015), Chopsaw Chick (02-20-2015), m1911 (02-19-2015)
Old 02-19-2015, 06:52 PM   #5
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 890
How about a OTR with charcoal filters, that does not vent to the ext, Of course the filter is for the cook top and not the micro
sunkist is offline
Old 02-19-2015, 07:48 PM   #6
cleveman's Avatar
Trade: custom home building
Rewards Points: 2,624
I recently installed a otr microwave under a 30x30 cabinet, so it comes down 46" from the ceiling. Usually I do it under a 30x24 cabinet, but some short people aren't comfortable with a hot cup of coffee up high in the air.
I think I missed the manufacturer's rec'd min height above the range by an inch. It will be interesting to see if the exhaust comes on automatically a lot.
I checked it a bit and all cooking can be done in that height alright, but it does look 6" below normal of course.
cleveman is offline
Old 02-19-2015, 07:53 PM   #7
rselectric1's Avatar
Rewards Points: 950
Also, pull the specs on the range itself. Depending on the manufacturer, sometimes they will have some comments on any venting required for that particular unit. I seem to recall that when I've needed to check, it's somewhere around page 10-20 where they show clearances above the range.
rselectric1 is offline
Old 02-19-2015, 08:06 PM   #8
trussme's Avatar
Trade: Remodeling Company
Rewards Points: 562
If it dosen't come with a vent, then you don't need one in a residential setting.
trussme is offline
Old 02-19-2015, 09:04 PM   #9
Justin K
Rewards Points: 269
Thanks, glad I asked
range hood 60" above cooktop? Cache HVAC 18 07-04-2014 05:58 PM
I could use some help on a range hood… DaVinciRemodel Remodeling 34 07-31-2013 07:33 AM
fancy range hood aib1015 Finish Carpentry 23 05-29-2013 09:17 PM
Range Downdraft Vent DEKAN Kitchens & Baths 1 09-05-2008 08:17 PM
Venting large kitchen range hood ChuckEA HVAC 5 01-12-2006 11:53 PM
