Raising A Counter Top - Kitchens & Baths - Contractor Talk
Old 11-19-2012, 04:50 PM   #1
nwksremodeler's Avatar
Trade: a little bit of everything, roofing, windows, doors, kitchen & bath remodels
Rewards Points: 244
A customer is dead set on installing a solid wood floor in their kitchen. I have told them that this will cause clearance issues for the dishwasher, stove and refridgerator. Yet they remain adamante that I will make it happen one way or another. The only solution that I have come upon since the cabinets are built ins is to add a spacer between the cabinet and the countertop, and cutting the cabinet above the fridge. But I just have not convinced myself that this is going to look respectable or is truely a good option. Any one got a better idea? The cabinets are maple face frames that were just refinished a year ago so it should not be to hard to match a spacer.
nwksremodeler is offline
Old 11-19-2012, 04:55 PM   #2
master hacker of wood
FRAME2FINISH's Avatar
Trade: restoration carpentry
Rewards Points: 1,730
Re: Raising A Counter Top
Yea rabbet out a wood moulding paint a contrasting color or stain easy peasy make that money
FRAME2FINISH is offline
Old 11-19-2012, 05:25 PM   #3
Anderson's Avatar
Trade: Home improvement contractor
Rewards Points: 1,196
whats on the floor now
Anderson is offline
The Following User Says Thank You to Anderson For This Useful Post:
bconley (11-19-2012)
Old 11-19-2012, 05:31 PM   #4
bconley's Avatar
Trade: Kitchen and bath design+remodel
Unless the cabinets are set on the subfloor, removing the existing floor will buy you some height and make the other transitions better
bconley is offline
Old 11-19-2012, 07:05 PM   #5
Chief Reporter of Spam
Tech Dawg's Avatar
Trade: Kitchen and Bathroom Remodeling
Rewards Points: 1,282
I always find it strange when people are adamant about the one aspect that causes 8 other things to go wrong
I delt with this before while doing a tile floor in a kitchen so they wanted me to make a removeable board with tile set on it and caulked around the edges ilo grout so if the dishwasher needs removed they can cut the caulk and slide it out, all that being said, it was a rental and the landlord is one of my friends
He also had a radiator in which the feed pipes were strapped with no access and wouldn't move up so that section got a piece of Corian glued to the subfloor which made up the exact height of the old floor and was trimmed out with corian at the edges where the tile met up with it.
Todd
Alone Eagle Remodeling, LLC
Tech Dawg is offline
Old 11-19-2012, 07:09 PM   #6
Tech Dawg's Avatar
In your situation, I think id pass on the job unless they want a new countertop.
You could raise the cab height with 1/2 or 3/4 wood, set new tops and then use a trim or countertop material to cover the wood strips.
Todd
The Following User Says Thank You to Tech Dawg For This Useful Post:
chris klee (11-19-2012)
Old 11-19-2012, 08:35 PM   #7
Rewards Points: 244
The current floor is glue down carpet, a 1/4" tall. My guess is that its glued right to the subfloor. The cabinets are also set on the subfloor.
Old 11-19-2012, 10:47 PM   #8
Anderson's Avatar
If they have to have it then give them a price to take out all the cabs and reinstale just make sure to tell them any damage will be extra.
Anderson is offline
Old 11-19-2012, 11:47 PM   #9
Holder of hands
skcolo's Avatar
Trade: Custom builder/remodeler
I guess you could tell them to buy a new dishwasher and hope for the best.
I just finished a kitchen that was done that way. Lousy cuts around the old cabinets with 3/4" quarterround. Of course, I had to install new cabinets and make it all look good, fix the dishwasher opening so that the dishwasher was level with the floor, and make everything look like the hardwood was not installed after the cabinets.
skcolo is offline
Old 11-20-2012, 01:34 AM   #10
General Contractor
Doctor Handyman's Avatar
Rewards Points: 408
Not sure what the current opening height is but standard is 34 1/2". Most DW are 33 7/8" so you normally have a 5/8" clearance. Assuming solid strip flooring is 3/4" your shy just an 1/8".
If they are adamant about wood flooring I would discuss with them that wood and water environments don't play well together. Perhaps an engineered wood flooring that is 3/8"-1/2" thick is available in a style they like. Or better yet the new wood look tiles but by the time you do cbu's your back to 5/8-3/4" again.
Easiest approach would be an ADA compliant DW that is typically 32 1/2". Made by most manufacturers. Second outside the box option is a single DW drawer.
Let us know what you end up doing.
Doctor Handyman is offline
The Following User Says Thank You to Doctor Handyman For This Useful Post:
Metro M & L (11-20-2012)
Old 11-20-2012, 05:55 AM   #11
Focusing on solutions.
pinwheel's Avatar
Rewards Points: 94
You've obviously never messed with built in cabinets built in the 70's. You're option, is not an option.
If I'm not mistaken, they now make dishwashers just for this situation.
pinwheel is online now
Old 11-20-2012, 06:11 AM   #12
Kent Whitten's Avatar
Rewards Points: 2,040
Solid wood floor over carpet? Did I miss something?
SalmonFallsCabinetry.com
Kent Whitten is offline
Old 11-20-2012, 06:42 AM   #13
Tech Dawg's Avatar
There's no way to know any measurements until the tearout is complete. The customer has to be willing to deal with any solution in that situation
Todd
Old 11-20-2012, 07:53 AM   #14
rrk's Avatar
Rewards Points: 3,234
There are many dishwashers that will fit in that situation, I did a kitchenaid a few months back that I was sure would not go but it did. I know a bosch wont fit.
Some of them have long front feet which allows for clearance, my plumber sometimes removes the feet and installs bolts from the opposite direction and slips a piece of flattened pipe under the bolt. Getting them out he just cuts the feet off or cuts the frame.
3/4" is not a problem most of the time, he has run into problems when the hardwood is installed over vinyl.
rrk is online now
Old 11-20-2012, 11:50 AM   #15
Superior Firepower
skyhook's Avatar
Trade: GC HVAC/R Lic. since 1985
Rewards Points: 3,880
Lightbulb
Reminds me of a quote by Zig Ziglar,
You can get everything you want if you just give people what they want.
skyhook is offline
The Following User Says Thank You to skyhook For This Useful Post:
Kent Whitten (11-20-2012)
Old 11-28-2012, 05:39 PM   #16
B.D.R.'s Avatar
Trade: renovation carpenter
Rewards Points: 1,990
Fir up the top of the cabinets with 3/4 plywood and add a trim detail. same colour, or contrasting . People may look at it and go" WOW". Maybe not.
B.D.R. is offline
Old 12-15-2012, 06:16 PM   #17
charimon's Avatar
Trade: Tile and Tool junkie
Rewards Points: 1,168
Have them buy a NEW dishwasher and have it installed, by the time it goes bad they will be ready for new countertops anyway. Besides taking the countertops off now to raise them is no more work than taking the countertops off later to remove and replace the washer.
"The key is to allow only the complexity that the customer is willing to pay for."
charimon is offline
open minded customer likes counter top idea but not sure if it will work Randal Kitchens & Baths 3 11-28-2011 03:31 PM
Counter flashing chimney ? enforcer Roofing 22 11-09-2011 02:55 AM
Advise for counter top LeoMajor Kitchens & Baths 7 08-22-2010 03:27 PM
Replacing counter top Cjeff General Discussion 5 07-14-2010 07:46 PM
Counter Top Old Crow Remodeling 6 03-23-2010 04:51 PM
